Fault no c5 - Heating & Cooling
    Master:
    Sergeant:
  • 388 Answers
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.
Air Conditioning Tamarac
Posted on Apr 15, 2015
Why my nokia c5 screen shows startup fails contact the retailer
There is a fault in the phones hard ware or computer that needs to be repaired. return to the retailer for repairs.
Aug 07, 2016 | Nokia C5 Cell Phone
I have a problem with my c5, it has a running issue where by i get a fault code saying i have a anti polution fault where a code comes up as injector 2 curcuit open.
If replacing the injector did not fox the fault then the fault is in the wiring to the injector . Loose /broken wiring or loose faulty connections at the ECM. Check for dirty /wet connections in the wiring loom.
Jul 03, 2014 | 2003 Citroen C5
Hi I have a C5 2005 turbo Diesel that is blowing
Hi Paul
You have a faulty starter motor,Common fault on the c5 starter sounds ok but is drawing too much power,And blows the 20 amp fuse for ecm
Oct 20, 2013 | 2005 Citroen C5 2.0
C5 is showing
C5 generally indicates a motor fault, specifically overheating. things that might make motors overheat are worn bearings and restricted ventilation
Mar 31, 2013 | AEG Lavamat Lavalogic 1600 Front Load...
It stalls when stepping on the accelerator in cold weather after starting up in the morning
Check the hoses at the inlet manifold and throttle body aren't loose or leaking (vacuum leak)
faulty fuel pump or pressure low
blocked injector or fuel injector system fault
fuel pipe damaged or blocked
Jan 09, 2013 | 2011 Citroen C5 Tourer
My nokia c5 will not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 30, 2012 | Nokia C5 Cell Phone
Nokia c5 is doing only vibrating.
you will need to set your volume to a higher level in order to hear it try changing your profile to either normal or loud, if you have done this and it still only vibrating there will be a fault with your speaker and will need to be fixed or replaced.
Aug 18, 2012 | Nokia C5 Cell Phone
When i insert the head phone in my c5 Nokia mobile, person on the other side can hear me but i am not able to hear anything
Check with another headphone to confirm If the fault stays then it is possible there are problems on the headphone sockets. if not the headphone is defective.
Also if there are same issues with the phone speaker/mic , then it can be related to the circuit. try and open menu - settings and restoring the phone to factory settings.
Jul 12, 2011 | Nokia C5 Cell Phone
Shows error code of c5 on copier
iron on top of the drum unit is fault replace it with another one it work.
Feb 23, 2008 | Toshiba 1370 Black and White Copier
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
