Question about Whirlpool Duet GHW9150P Front Load Washer
Open the door on my Duet front load washer
Error code F-21, I found lots of good info on how to fix this but for right now I just need to rescue my clothes. It's too late to do a repair right now, besides I don't have the proper screw driver to get off front panel. Any other way to open the door?
    Genius:
  • Whirlpool Master
  • 1,585 Answers
Remove lid its fiddly but can b done from top
Posted on Apr 16, 2015
  • 213 Answers
SOURCE: whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Posted on Nov 26, 2007
  • 185 Answers
SOURCE: Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Posted on Mar 28, 2008
  • 1028 Answers
SOURCE: Fdl Code on whirlpool front load washer
remove bottom panel reach up to bottom of door lock there is a small tab pull it down door will come open..if after opening you finda lot of water still in machine suspect pump plugged worse case bad control bd
Posted on Jul 26, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
SOURCE: is door reversible on duet model GHW9100LW1
The way my laundry room is set up I have to have the washer door open on the right. There is not way to switch it. My w/d are stacked and the door to the laundry room is on the left; if they open to the left it will always block the door when it is open. My dryer opens to the right which is the way I want both of them.
Posted on Oct 16, 2012
Duet GHW9150P Front Load Washer: Whirlpool Duet Washer - Error F21 (What is this) ...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. F-21 filter blocked.
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code f 21 on whirlpool duet front load washer
cannot open door on washer it is locked and chothes are inside
Jan 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load - Code F 32 - Cannot open door
F32 is the code for Pressure Switch Failure. Which is only found on a tech computer. Remove the top panel from the washer by removing the three screws in the top back of the washer. Inside the back right corner is a round plastic box, either black or white, that is the pressure switch box. Check to make sure all the quick connect wires are connected and tight. Unplug washer to reset it. If the cycle fails still with the F32, you'll need to get a new Pressure switch box. If that doesn't fix it then it could be the control box( the bigger rectangular box in the front right that the wires connect to.) Good Luck and Happy Washing
Sep 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
DUET ERROR CODE f21
your correct so lets fix it...take bottom acess panel of ..theres three screws,,,ok ready clean that pump filter it right in front of you twist it out always unplug first unplugged good,,now while your down there with the filter out,,check booth black hose to make sure theres no coin or hair clips while you have it open,,onthejob
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door locked/ cycle won't complete
If you need to get the washer door open, there is a manual release lever that you can use. The following links explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Now, with your clothes rescued, the next link explains the "F11" error:
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
I know it seems like a lot with the second link. In most cases I have found, the CCU is the cause of the F11 error code, but read through the information carefully and doublecheck everything. It can be replaced if you wish to perform the repair yourself. I hope this helps you.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer sport ht - error codes
FYI: The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground. Just thought this would be helpful as I just did this as of 5 min ago. Should take 10 min. or less.
May 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fault code f21
There is a clog in your hose. It happened to me, same washer. I took the hose off and blew into it, the clog came out.
Dec 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Duet sport with an error code
I have a Whirlpool Duet and the washed load would stop and give me a F-21 error. I tipped the washer back a little and removed the three screws on the front bottom cover. There is a large white drain value, turn and open the drain (make sure you have a pan or something to catch the water and any junk inside) to remove the water. Attached to the drain is a black hose with an expanded section, squeeze this to find any loose socks, under clothes etc. I acually found three socks, a battery, a pair of tweezers and a few coins. This F-21 error is a drainage problem, don't call the repair center and pay for a serviceman, it is easy to fix yourself. I hope this helps!!
Dec 08, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
