Question about Yamaha Rx-v465/rxv465 Home Theater Receiver
My Yamaha RX-V465 will not stay on. It seems to short out every time and nothing else is hooked up.
    Scholar:
  • 127 Answers
If it is not working even without any cables attached, you can check the connectors (especially the speaker ones) for little pieces of cable strands which might short-circuit the connectors.
If nothing like that is found, the short-circuit is inside the receiver and you should contact service center for repair.
Posted on Apr 14, 2015
    New Friend:
This is a common problem, one of the capacitors is faulty on the power board and needs replacing. Worth taking to a shop and have done, parts are around £1 and takes about an hour to do (removing the case, pcb, solder new part and re assemble)
Posted on Sep 28, 2016
I have a Yamaha Rx -V465 AV receiver When turn the system on it will not stay on. I switch outlets it would do the same.
First disconnect all speaker cables and all input cables (optical, HDMI, everything expect power). If receiver powers off itself immediately even without anything connected, it is faulty and you need to send it for repair.
If it works without cables, then you probably have bad cables and/or short-circuit in the speaker connection and receiver is turning off to prevent damage. Double-check your connection and that no speaker "+" cable has a contact with any "-" cable or connector. Even one little strand of cable touching the opposite polarity connecter is enough to cause a short-circuit.
Sep 12, 2014 | Yamaha Rx-v465/rxv465 Home Theater...
Can I hook up my yamaha receiver to soundbar
can I hook my yamaha rx-V465 to my vizio soundbar? When I soldered the rca plugs on to the speaker wire and connected my center channel on the receiver now ther receiver randomly shuts itself off.
Nov 21, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
I have a Yamaha RX-V465 receiver. Is the newer YDS-12 docking station compatible with this receiver? the YDS-12 seems to accept newer IPods.
Yes, it is compatible.
http://usa.yamaha.com/products/audio-visual/accessories/yds-12_black__u/?mode=model
It has 2 modes of operation. For RX-V465 you need to select mode B. In this mode it is compatible with YDS-11, which is supported for RX-V465. But iPhone is not officially supported in this mode. But I have found on Yamaha website FAQ, where they claim that iPhone switched to Airplane mode worked well.
http://faq.yamaha.com/us/en/article/audio-visual/accessories/yds-12_black__u/4742/4061
Nov 11, 2010 | Yamaha RX-V463 Receiver
I have yamaha rx-v465 receiver and yds-11 docking station. how can i get tv{through hdmi 1}to display what's on ipod.i have nano w/video camera{newest one]. is this possible
I think it is not possible, because RX-V465 does not have HDMI-video processing. It can only pass-thru the HDMI video to HDMI-out, but not alter the signal in any way.
If it should support TV output with YDS-11, it will work only via analog video out (s-video / composite / component).
Dec 30, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Best way to hook up TV with one HDMI to blue ray DVD and RX-V465 receiver with Direct tv
Has Direct tv STB HDMI output?
Best is to connect all your sources (BD, DVD, STB, PS3) to yamaha receiver and connect yamaha hdmi-out to TV's HDMI-in.
Dec 29, 2009 | Yamaha RX-V463 Receiver
I have a PS3 hooked up via HDMI to my Yamaha RX-V465.When I play a blueray disc the signal info shows PCM.Shouldn't it show Dolby Digital or True HD?
Your PS3 probably has a setting for what digital bitstream it produces. Check it out. Dolby Digital is probably what you want.
Dec 27, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Jun 05, 2009 | Yamaha RX-V463 Receiver
Open Questions:
See all Yamaha Rx-v465/rxv465 Home Theater Receiver Questions
Yamaha Rx-v465/rxv465 Home Theater Receiver Logo
125 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
