Question about Miscellaneous
Car AC help
Our AC for the Volkswagen Jetta 2000 doesn't want to work. There's no air coming out from the blowers and we need help solving it since summer's right around the corner.
  • 46 Answers
Silly question here, but in your clip the fan switch is on zero right?? Try on full speed. If it only works on full then the resistor is dead
Posted on Jun 24, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
If you mean the blower motor isn't running I would suspect these in this order
fuse
switch
relay
resistor
blower motor
Posted on Apr 14, 2015
Vw jetta Air conditioner buttons are stuck
U HAVE AN AC OR CLIMATRONIC?NEED MORE INFO TO GUIDE U!!
Mar 26, 2014 | 2000 Volkswagen Jetta TDI
Dodge Stratus R/T fan doesn't come on while car is running and car is getting hot.
FAN NOT WORKING
It can be issue with faulty motor or its faulty fan control relay.
Bother are to be inspected.
Test volt at fan relay and fan motor.
For more help, I suggest you to go through the troubleshooting links mentioned below:-----
Click the link below: ------
How to replace Cooling Fan on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
OBD Code P1490 low speed fan relay ckt open-short
http://schematicsdiagram.blogspot.com/2012/11/obd-code-p1490-low-speed-fan-relay-ckt.html
Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works?
http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
Hyundai Sonata cooling fan not working
http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html
Fuel pump relay and cooling fan relay troubleshooting on 1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Fan belt routing diagram for 2004 Volkswagen Jetta?
http://carbeltrouting.blogspot.com/2011/12/fan-belt-routing-diagram-for-2004.html
Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
A/C, heater, defroster fan, not working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Blower fan not running on Isuzu trooper?
http://technoanswers.blogspot.in/2012/02/blower-fan-not-running-on-isuzu-trooper.html
How to replace blower motor fan assembly on 2000 GMC Yukon?
http://repairhelpcenter.blogspot.com/2012/01/how-to-replace-blower-motor-fan.html
Heater AC or defroster fan not working on KIA?
http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
These will help.
Thanks.
Nov 27, 2012 | Cars & Trucks
2000 vw Jetta ac not cooling, ac compressor is on, freon level good, with ac manifold gauges high and low side fluctuates from 50-60 psi on low side.
try to throw cool water on the condencer front of the engine radiator and see whether any cool air comes in the car. If so see whether the pressure valve is working okey or not because might the pressure is not sufficient.
Sep 05, 2012 | 2000 Volkswagen Jetta TDI
2000 vw jetta overheating, coolant doesn.t appear to be circulating thru engine
vw have always problems with thei water pumps check ur water pump
Oct 15, 2009 | 2000 Volkswagen Jetta TDI
My 2000 Jetta GLS AC stopped working. It worked fine that morning and went to use it after work and it will not blow air at all No idea what happened. Please help!!!!
check the condenser it looks like a radiator it is right behind the grill if it looks wet or streaky you need anew one and a recharge probably over 400.00 very common with the jetta
Jun 29, 2009 | 2000 Volkswagen Jetta TDI
A/c problem
If the lights where you change the settings for the ac aren't lit up, or come on and off, or if you smell a burning type smell, check your blower motor control module. I have a 2000 Jetta GLS and was having those problems...Changed the blower motor control module and that fixed it. Unluckily, I now think I have a leak. :( Hopefully my information will help you out!
Jun 19, 2009 | 2001 Volkswagen Jetta TDI
VW Jetta GL 2000, AC - Heater Fan stopped
blower motor or resistor or the blower motor control switch.
Jun 01, 2009 | 1998 Volkswagen Jetta
Ac not working
yo may need to have it re-earthed, same happened on my car!!....cost me £60 at garage...good luck, hope this helps.
May 09, 2009 | 2007 Volkswagen Jetta 2.5 Sedan
Miscellaneous Logo
618 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
