Question about Whirlpool Home
Not able to get cover off of control buttons on a cetra jaquzzi whirlpool bath to replace air button.
    Top Expert:
  • Whirlpool Master
  • 44,333 Answers
Put your hand up under the edge of the button and push in the two plastic prongs in and push the switch up out of the spa
they normally just push in and the prongs spring out to hold the switch in place
Posted on Apr 14, 2015
  • Bill Boyd Apr 14, 2015
    they seldom fail as they are only a rubber diaphram that produces air pressure to control a switch at the pump
    Check the air line by removing it and placing the end in a glass of water. pressing on the button will produce air bubbles if the switch is good
  • 2712 Answers
SOURCE: Difference tubs and air baths
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
Posted on Aug 27, 2008
  • 4 Answers
SOURCE: Air actuator button hard to push in.
the best plave for you to get a diagram is wholsey.. tell them name brand and size of your tub. and they should be able to help you.
Posted on Jan 13, 2009
  • 19 Answers
SOURCE: How do I use my Whirlpool bath?
youneed to make sure that the switch is on first .their should be a switch for the tub on the wall somewhere.find the switch than push the button on the tub,also make sure that their is water in the tub that is past the jets before pushing the button on the tub.
Posted on Feb 09, 2009
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
co7196
  • 3433 Answers
SOURCE: I have a whirlpool jaquzzi with no diagram on how
Go on searc and enter the manfasturer, model and manual. see what pops up.
Posted on Nov 10, 2009
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
The air switch on my whirlpool tub will not toggle, i must hold the button in to keep motor running.
What you are experiencing when you push the Air Button down and it engages the BATH PUMP but when you release the the Air Button is a bad Air Switch in the BATH PUMP.
When you push the air button down it sends a column of air to move a small switch in the BATH PUMP. When the switch in the BATH PUMP is bad it will not engage.
What you need is a new Air Switch model TBS-339.
Rod
US Parts Center
888-521-6183
Feb 28, 2013 | Home
I just bought a home that has a 3 year old white Jacuzzi Cetra H526 000 Whirlpool Jetted tub. It was not well maintained. I need 4 new Thermo Pro Jets, 2 Accu Pro Lumbar Jets, a square grille,and a product...
Jacuzzi Cetra Comfort Bath home page:
http://www.jacuzzi.com/baths/options/models/cetra
Installation and Operating Instructions:
http://www.jacuzzi.com/admin/files/files/4cfd8269-e7b0-4286-9908-7b9743.pdf
For replacement parts your best bet is to you use the on-line dealer locator:
http://www.jacuzzi.com/baths/pages/dealer-locator
or you can shop on-line from one of their authorized retailers; however did not see any of the parts you are looking for at the sites I checked:
http://www.jacuzzi.com/baths/pages/buy-online
Mar 17, 2011 | Jacuzzi Home
The button on the jacuzzi 536 RH will not start the motor when pushed. The motor is tested to work however.
Sorry to read about your problem, I hope this helps you out.
The unit uses a air switch, you should see a plastic tube going from the switch to the power switch.
remove the tube at the power switch end, and then push the switch, you should feel air, come out.
If you feel air, then you must have a defective power switch.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Jacuzzi R100-959 Cetra 536 RH R100...
You push the button and the unit keeps running
TO SOLVE YOUR PROBLEM YOU WILL NEED TO PELACE THE PUSH BUTTON OR POSSIBLY THE AIR HOSE CONNECTED TO IT CAME OFF
Dec 10, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Whirlpool bath won't turn on.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Nov 30, 2009 | Jacuzzi Amiga, Soaking Bathtub - 9180
Jan 12, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Home Logo
315 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
