Washed machine out and added new mix but it says freezer locked how to get it working again.All we did was cleaned it out on wash.
    Top Expert:
  • Washing Mach... Master
  • 50,218 Answers
The question is vague WHAT is the machine does not sound like a washing machine but an ice cream machine possibly .
Posted on Apr 14, 2015
    Habit-Forming:
    New Friend:
  • 41 Answers
Try un plugging it for a minute and the plug it back in
MNfisherman
  • 11896 Answers
SOURCE: washer will not start washing cycle. Machine hums like the dryer
Check the drain for clog. If the drain is dirty, the washer won't fill, rinse, or drain.
Posted on May 23, 2009
  • 653 Answers
SOURCE: My washing machine does not clean properly.
Let's start with the detergent and the water temperature. If they are the same as what you use at home,
then I have to assume the machine may be overloaded. Back off on the load by about 1/3 and see what happens. In the worst case scenario, you could let the jeans soak in the detergent/water mix over-night
Posted on Jun 17, 2009
  • 1527 Answers
SOURCE: Hotpoint Aquarius 900 WM61, washed but stopped spinning
hello carl check the module circuit board this controls the speed check the transistor on the boards for dry joints if discoloured change the board all the best
shaun
Posted on Aug 04, 2009
  • 8 Answers
SOURCE: "OE" message
This error code appears when the washer has not fully drained after 10 minutes.
The possible causes for this problem are: Oversudsing and Not Draining.
1 Do not use too much detergent. Highly concentrated detergents (HE2x and higher), require less detergent than regular detergent or non-concentrated HE detergent.
2 Check for correct drain hose routing. Make sure drain hose is not kinked or too far down the drain / stand pipe (average 6-8 inches).
3 Check for correct drain hose routing. Make sure drain hose is not kinked or too far down the drain / stand pipe (average 6-8 inches).
Steps to clean the drain pump in front load washers:
1 . Locate the access door / panel at the bottom front of the washer (If equipped).
2 . Gently, open the door or remove the panel.
3 Locate the drain hose and plug, if equipped. While using a drain pan or bucket to catch the water, remove the plug and allow the water to drain from the washer.
3(a) If the hose seems plugged and will not drain, it is most likely pulled out too far. Do NOT pull the hose until it is tight, leave some slack!
3(b) If the drain pan gets near full, plug the hose, empty the drain pan, then continue draining until all water is out of the washer.
3(c) Make sure the drain plug inserted back into the hose, it must be inserted fully.
3 (d) If not equiped with a drain hose, make sure drain pan or bucket is under the filter housing area when removing the filter.
4 Once all water is removed from the washer, the pump filter can be unscrewed by turning counter clockwise (typically 3 full turns), then pulled out of the filter housing.
5 Once removed, wash out the drain pump filter under running water at the kitchen or utility sink. Some light scrubbing may be needed to remove all soils from the filter.
6 Make sure not to damage or lose the O-ring gasket on the filter.
7 Before reinstalling the filter, check the filter housing for foreign objects and soils that could block the filter. Once foreign objects and soils are removed, then reinstall the filter, plug and door in reverse order.
8 Make sure the filter is fully seated and snug or it could leak. Do not over tighten, filter or housing damage could occur.
9 Run the washer and check for leaks.
Posted on May 28, 2010
  • 1417 Answers
SOURCE: F 12 whirlpool 6 th sense washing machine.
hello,
simple ,The "F 12" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you need to do to fix up your washer is to check on the wiring connection from the power supply to the water temperature indicator.
thank you and thanks for using fixya.
Posted on Jun 01, 2010
Testimonial: "thanks it worked"
Tip
Good care equals good results
Making great sauces, dips, dressings and chopping yummy veggies or crumble bread and other foods, rather than buying them already made, is fun and satisfactory, but, as usual, the less pleasant part is when it's time to clean up.
How can you keep a food processor, chopper or dicer clean and ready to be used again?
First of all it's important to take apart the whole of the machine, separating all the smaller parts so to clean them thoroughly and remove food residues.
They should all be washed with warm water and soap and not scrubbed too hard.
The blades should not be soaked in water, rather be gently washed and wiped down right after usage, to preserve them.
Another way for cleaning the blades without cutting yourself is by using nylon brushes.
Most removable parts can also be washed in the top rack of the dishwasher.
To clean the base or motor part, all you need is a damp cloth to wipe it down and remove stains. If done right after use the stains shouldn't resist. If they do, a baking soda paste should do the job, or a bit of soap wiped on the stain and removed with the cloth or a damp paper towel.
After all the parts are clean and dry you can reassemble the machine and store it away. Make sure that all the parts are throughly dried to prevent bacteria growth or damage.
So what if your processor/chopper/dicer is smelly?
An easy solution for a smelly machine is to mix baking soda and water at a 1 to 1 ratio and leave it in the bowl of the machine for 10-15 minutes. This will absorb odors and leave your machine smelling clean again.
on Nov 10, 2013 | Home
Whirlpoool front end loader washing machine showing an f 06 error
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
Nov 04, 2012 | Whirlpool Washing Machines
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
Hotpoint Aquarius 900 WM61, washed but stopped spinning, about 6 wks ago, new brushes fitted old 1's had split everything worked fine, 6 wks down the line machine washes but doesn't spin again, bushes are...
shaun
Aug 04, 2009 | Washing Machines
Jun 17, 2009 | Daewoo DW500M Top Load Washer
Washed
You have to try in powering it up.
Unfortunately, when such kind ofelectronics are washed, the only solution i to open it immediately, clean all the water and moisture residues, dried it, and then charge the battery again and test it.
When time passes (say 2-3 months) after being washed, there is corrosion and moisture in the electronic components and internal connecttions, and the device is permanently damaged.
Best regards,
Jan 06, 2009 | RCA Lyra RD2765 MP3 Player
Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Dec 08, 2007 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
