S.M.A.R.T Capable and Status Bad - 5 hard drives how to find which one has failed or about to fail?
    President:
  • 778 Answers
Depending on your PC Make and Model you may be able to enter BIOS setup on boot and check in there, it should show you under one of the hardware or hard drive categories which one is failing?
Let us know how it goes? If no luck there Post Make and Model and we can give more accurate information about your system and how to determine which one it is other than unplugging one at a time and starting your computer over and try another one and keep on until you don't get the S.M.A.R.T. Bad Hard Drive status???
Let us know how it goes? If no love, give us the information on your system and we will try and nail it down for you.
Sincerely,
Frank
Posted on May 16, 2015
  • 13433 Answers
SOURCE: hard drive failing?
you may have alot of problems installed or your hard drive needs to be defragmented.
yes it also may be failing, but before replaceing it either clean up your pc also defrag the hard drive.
how to defrag
http://support.microsoft.com/kb/314848
if that doesn't help try reinstalling windows and starting from a clean plate.
Posted on Jun 26, 2008
  • 998 Answers
SOURCE: Computer will not boot.
Form the info you provided, you have a RAID (Redundant Array of Independent Disks) disk array. RAID 0 (striped disks) distributes data across several disks in a way that gives improved speed and full capacity, but all data on all disks will be lost if any one disk fails. Apparently Diagnostics has determined that “Drive 2” is defective. You will have to replace the defective hard drive and reload the Windows operating system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 21, 2008
  • 24 Answers
SOURCE: bad hard drive?
the hard drive is damaged. install a new hdd and connect the old one as a secondary so you can extract your files after you reload the new one.
Posted on Mar 29, 2009
benwabnick
  • 2404 Answers
SOURCE: My HP a1700n hard drive is failing. Can I replace
Its not difficult at all. Find a hard drive that you want to use, next get a case that you want to use as well then install the drive into the case. Next you need to figure out whether you want to hook it up by usb, firewire, SATA, etc. Then hook it up that way and fdisk, format and then install the operating system you want to on it.
In fact some hard drives now come with there own cases as well and can be as low as like $99 so really its the way that you want to do it. Just make sure you get the size hard drive you want and then the case you want to use for the connection type you want to use, with USB just plug it into a slot outside of the computer, SATA will require you to plug it into the inside of the computer and firewire would hookup outside of the computer.
SATA would be the fastest but would require you leaving the side panel off cause it would need to hook up inside of the computer.
Posted on Jun 21, 2009
  • 1738 Answers
SOURCE: fail on hard drive diagnostices return code 7
Bad hard drive, sorry.
Posted on Nov 16, 2009
Hard disk smart capable status bad
SMART is a hard drive utility built into some computer bios'. SMART is informing you that the hard drive is bad.
Jan 20, 2014 | Toshiba MK6028GAL 60 GB EIDE Hard Drive
When i power up my laptop this message appear: S.M.A.R.T. Status Bad, Backup and Replace. Press F1 to Resume" After i press F1 windows starts but then my desktop freez. Can i do something to repair this...
SMART stands for 'Self-Monitoring, Analysis and Reporting Technology' and a bad status means that your drive has errors and is likely to fail soon. There is generally very little if anything you can do to repair such drives.
I recommend backing up any important data on the drive as soon as you can and replacing the drive.
Most computer repair shops will be able to retrieve data from a failing drive and supply and fit a new one for you, charges for these parts/services will vary depending on where you go.
Jul 31, 2013 | Western Digital (WD6400BEVT) 640 GB SATA...
Pri master hard disk s.m.a.r.t. status bad, backup and replace press del to resume
Hard drive is bad or is going to fail soon.
Solution
Backup your information and contact the maunufacturer of the computer or the hard drive for replacement or additional help.
In some very rare cases the S.M.A.R.T. implementation on your computer may have issues of its own and may need to be patched before replacing the hard drive.
If I am receiving the S.M.A.R.T. error, is it ok if I continue to use my hard drive and do not replace it?
As stated above, S.M.A.R.T. is designed to detect upcoming failures in the hard drive.
While it is possible that the hard drive may not fail for several months, it is still inevitable that the hard drive will fail.
It is ok to continue to use the hard drive, however, we highly recommend that if you are still under warranty that you consider getting the drive replaced before your warranty runs out.
hope this helps
Sep 20, 2012 | Western Digital WD AV WD2500AVJS hard...
Ai got an old computer and it it work but it show me an error with American Megatrends
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps you
Jan 07, 2012 | Computers & Internet
Repair of harddisk failure
Hard drive destroyers/crushers are capable of physically destroying various media, including hard drives, CDs/DVDs, cell phones, and floppy disks, ensuring that the data on the media is completely unreadable. Our fast & reliable solutions are ideal for environment-friendly and low-cost media disposal, parts recycling and data loss prevention.
Sep 16, 2011 | Computers & Internet
A hard drive is reporting a SMART event
If your hard drive has reported a smart event then it will probably fail soon. The smart status is normally related to the health of the hard drive when there is a problem the SMART status will notify you. The best option is to backup everything and have an extra hard drive on hand to replace it when it does fail.
May 11, 2011 | Acer Aspire 3680 Laptop
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Samsung sp0802n. s.m.a.r.t capable and status ok
please check if the data cable or the controller might be bad or it cud be even the hadd if alls fine then try doing a format reinstall
Jun 23, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Master hard disk s,m,a.r.t.status bad,backup and replace
A failure message from the SMART system of this nature indicates that a catastrophic hard drive failure could be imminent. Without delay, back up ANY data you want to keep. This error isn't going to go away, and is being reported by the drive controller.
Whilever you can access the drive, move any data you want onto another media (such as DVD or external USB hard drive) because chances are it's not going to work much longer. You need to look at buying a new hard drive as soon as you possibly can, and migrating the data to it.
Files and Settings Transfer Wizard will be able to backup your data to another media.
Jun 02, 2008 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
