Question about Kenmore Washing Machines
I have a Kenmore he2 plus washer model number 110.46462501 that was working fine last night and then the two lines in the picture below appeared. What does this mean? Thanks in advance!!
    Genius:
  • Kenmore Master
  • 1,585 Answers
Unplug for 15mins
Posted on Apr 27, 2015
SOURCE: Kenmore HE2 Plus Error Code: F-20
You probably have this solved by now but for others who read this as I did.............
F-20 means
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Hope this helps everyone else as it did me, thanks
Posted on Dec 02, 2008
catriver
  • 878 Answers
SOURCE: f-26 error message
F-26, is a door lock switch error code. Some things to try; Unplug the washer for 1 minute and see if the error clears. If not, try entering the diag mode by pressing any key except pause/ cancel. Press for 4 seconds and release for 4 seconds 4 times. If entered correctly, all lights should light and the first error should appear. Press the same key to advance through all the errors. When the errors finish. It will start an automatic test mode that tests all componets. The first thing it will test is the door lock. If this fails you more than likley have a door switch problem. Let me know how you make out. Catriver
Posted on Mar 06, 2009
localwonder
  • 6784 Answers
SOURCE: kenmore he2 plus washing
CCU/Touchpad/LED assembly error(f21)
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. this will reset the CCU, and may reactivate the commmunication if the damage isnt sever. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU)
Replace failed component.
Posted on Sep 18, 2009
rdrsp
  • 85 Answers
SOURCE: My Kenmore HE2 Plus codes F24. What does it mean
On this model of HE washer, the F24 code indicates that the water temperature sensor is out of range (23 degrees to 217 degrees F). This usually indicates a bad thermistor (temperature sensor). A bad wiring connection or a failed control board could also cause this problem. If you have the technical ability to safely access internal washer components, you may be able to repair this problem yourself. Diagnostic steps would involve unplugging the washer and checking the wiring connections between the thermistor and the control board. A resistance check of the thermistor would be needed using a volt/ohm meter.
hope this helps....
Posted on Oct 27, 2009
  • 5 Answers
SOURCE: I need the repair manual for the Kenmore HE2 Plus washer
manual for the HE2 and Duet Sport here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
(give it time to download, big file)
Posted on Nov 06, 2009
Need part number for my kenmore he2 plus washer's drain pump. I need to replace it due to a continuing F21 error code msg
Sears has a fantastic part locator on line try that just surf the sears site you ll find it ,probalby even have a number to call just in case
Mar 09, 2011 | Kenmore HE2 Plus Front Load Washer
The latch on my Kenmore washer he2 will not stay closed. Now what
Since the Kenmore line is a Sears house brand, you can order the parts from them. Some where on the machine should be a sticker with the model number and a number, i belive its 1-800-4MYHOME. You might want to look it up. They will ship it directly to your house
Jun 24, 2010 | Kenmore HE2 Plus Front Load Washer
Can't locate stacking kit for HE2 Plus Washer and HE2 Dryer
more of the model number would help, but i can get them parts for you at www.whirlpoolpartssurplus.com feel free to give us a call
Jun 23, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore model 44142400 door lock
Try unplugging for 2 minutes and if display looks the same, then theres and elec. issue.
Mar 08, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
44 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
