Question about Hotpoint Washing Machines
Replacing brushes on hotpoint ultima wmd740,videos I've seen the brushes are held in by screws,but on my mums its bolts and can't get a socket over it,any ideas ?
  • tom cassidy
    tom cassidy Apr 14, 2015
    Hi Murdo Mackay, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • 693 Answers
I usually place a towel underneath the machine and tip it 45 degrees against a wall ?the towel will stop it sliding over as you work underneath?most bushes are held in by a brass shim which slides in its slot one way and then the other?the hardest bit is feeding the new spring into the tube after you push home the brush.this is why it is better to take the motor out....these are usually held on by two bolts that face the rear of the machine....then it should slide off the other two holding points...you need to take off the drive belt and disconnect the wiring loom.ALWAYS disconnect the machine from power source before you attempt any work.Once you have the motor out it is always a good idea to check the commutator for scoring or deep scratches.i always brush out any carbon dust prior to fitting new brushes.be aware that some cheap brushes are false economy as they will wear down and chip more easily than the correct brand make.if it is badly scored it is better to buy a complete refurbished motor with new brushes as that is usually around £30 complete of ebay suppliers.bear in mind shipping can be £15 -£ 20 due to the weight.good luck.
Posted on Apr 14, 2015
  • Murdo Mackay
    Murdo Mackay Apr 14, 2015
    the bushes are held on by a bolt on either side and can't get a small socket over the bolt as no room due the brush itself,there is a video on YouTube of the same model as my mums and the bushes are the same but they are held in by a screw on either side yet on my mums one its bolts
SOURCE: hotpoint ultima WT9 60
the internal circuit board has come loose, switch off power take the top off and tighten the connections on the plugs inside
Posted on Mar 25, 2008
  • 5 Answers
SOURCE: Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
barkencoa
  • 3463 Answers
The filter is located in the sump hose at the rear bottom of the m/c.
You need to remove the large clip that holds the hose on
Access is gained by removing the lower rear panel.
Posted on Nov 26, 2008
barkencoa
  • 3463 Answers
SOURCE: Broken door hinge replacement on Hotpoint Ultima
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Thanks.
Posted on Dec 27, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
Posted on May 30, 2009
My washer is French how do I change it back to English
1. Turn the power on at the wall socket.
2. Select ON/OFF at the console so that there is nothing showing in the display - ie: machine OFF.
3. Press & hold the 2nd, 3rd and 4th function buttons until the machine BEEPS (approx. 5 seconds). (centre 3 buttons below the display).
4. Select ON/OFF at the console to turn the machine ON so that the display is ON - it should now show language options scrolling through.
5. Wait until the language you want is shown or scroll through them manually using Spin Speed or Temperature then press Child Lock to select it.
Hope this helps
Mar 18, 2015 | Hotpoint Washing Machines
Hotpoint wmd740 won't spin
hi lee its worth taking motor brushes out and checking if very short could well be problem should be good inch long when new should work say 10mm or over
Dec 12, 2013 | Hotpoint Washing Machines
Where the pump on a hotpoint ultima wt960
Unfortunately the manual link won't help on this problem, it doesn't give the answer. However if you remove the rear panel ( plastic and two screws ) where the waste hose comes out, the motor will be seen on the left, the pump is on the right at the bottom corner. Hope this helps, I am unable to go further as I don't know the problem.
Apr 25, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima sdw80 45cm door will not keep closed when in use still doing the wash cycle
Door catch needs replacing. Can be done yourself. Top 6 or so screws removes the top section of the door and the catch is held in by 2 screws and has two easy to remove / replace.
Oct 31, 2010 | Microwave Ovens
My washing machine won.t spin or turn so could it be the motor as i can,t hear it or would it be the brushes.i,ve got a hotpoint aquarious
I would try the brushes before replacing the motor, or you may have a broken wire. Before attempting any repair unplug the machine from the mains. The brushes on these motors are held in with 2 screws and although it may be a bit awkward they can be changed while the motor is still attached to the machine, but it will mean tilting the appliance so it is resting against something rather than just proping it up . For Hotpoint WMA workshop manuals click here
Mar 18, 2010 | Hotpoint WMA40 Front Load Washer
Where are the brushes?
easiest way is to remove the motor - just held in by simple bolts. disconnect the electrical plug and socket wiring to the motor of course.
Sep 30, 2008 | Hotpoint WMA48 Front Load Washer
Main motor carbon brush
easier to remove the motor. the brushes are held in by 2 small bolts for each
Sep 04, 2008 | Hotpoint First Edition FEW12 Front Load...
Washing Machines Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
