Question about Dewalt Dc618k 18v Xrp Cordless 16 Gauge 1-1/4-in - 2-1/2-in Angled Finish
Stop working.sounds like its working but doesnt go threw the whole cycle
Open the top gray cover to have a look and saw that the nail driver isnt going all the way to the nail to drive it out of the nailer any thoughts this?
  • 3,289 Answers
3 items to check.
1) Is the battery low, so it does not have enough power to drive the nail?
2) Does it need lubrication, like is there dirt or stuff blocking its action? You might need to blow it out with a high pressure air hose and the lubricate it with a light oil, and
3) Is there a blockage or is something slightly bent somewhere? You know, some nail sets are so poorly made they have tiny extra pieces of nails on the nails in the clip.
Be blessed.
Posted on Apr 14, 2015
Fires first nail will not fire second nail
Ez test. With nails removed, and door open driver should be at top of cylinder. If driver is down replace piston oring. If driver is up, lightly strike nose of gun against softwood. The driver should stay at top. If driver drops with light tap replace piston oring. If driver stays at top dry fire the nailer against softwood. The driver should hit the softwood leaving a mark and return to top. If driver stays down or does not travel all the way up pull the cylinder and make sure checkband is installed. Checkband is oring or rubber band covering series of holes on lower part of cylinder. Good luck
Jun 21, 2015 | Stanley Bostitch Coil Framing Nailer
Nailer wont advance the nails then it shoots blank
Try ez test to check for proper operation. Remove nails and air supply, point nose of gun up then down again. The driver should not move from the top of cylinder position. If driver is moving up then down replace the driver oring. If driver oring seems ok then connect air supply and bump fire the nailer without nails against soft wood and door open so that you can see the driver and feeder moving. Bump fire the gun and make sure that the driver is moving all the way back up to top of cylinder and the feeder is moving rapidly back and forward. If movement seems ok then hold the nose down on soft wood and depress and hold the trigger. This will fire the gun but driver will stay at the bottom position and not return until you release the trigger or lift the gun. When holding the gun with the driver down position, no air should leak out the top or bottom of the gun. If air leaks out bottom, replace lower bumper, if air leaks out the top replace the upper bumper. Good luck
Mar 19, 2015 | Porter Cable Coil Roofing Nailer
Not locking
I had this problem also with my Maytag Neptune TL. The door lock would click multiple times before displaying the FL code. I was able to fix this by removing the left door look(the one with the door close sensor) and cleaning the 2 metal pones on top of the left door mechanism, which had rusted and no longer was able to since the door closed. I use a nail file i sure either that or sandpaper will do. After that it went through the whole cycle without stopping or displaying the "FL" code.......hope this helps
Jan 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
Inoperable nail gun
replace trigger , sounds like your trigger is keeping the firing valve in the open position allowing air to push the driver down, and exhausting the air out of the top, could also be that the firing valve itself is worn or broken
Aug 08, 2012 | Air Tools & Compressors
Hotpoint DF52 stopping after 4 on the timer
Replace the timer control is my advise
Jun 27, 2017 | Dishwashers
Cigarette plug does not work
Try plugging something else into the lighter socket,,,if it is getting power then you should suspect the phone charger, if it isnt,,then suspect the fuse,,,just open the fuse box cover and you will find the list and description of all the fuses and their locations there.
Jan 19, 2009 | 2004 Dodge Stratus
D51844 nails jam
The problem that you are experiencing could be caused by several conditions within the gun. Lets work thru the possibilities. First make sure that the nails are correct for the gun. Place a stick of nails on the outside of the magazine with the first nail aligned with the path of the driver. The stick of nails should align perfectly with the path of the driver and also with the magazine. If they do not, don't use the nails. Check with dealer for correct nail. I find that short nails (around 2") will have a tendancy to jamb.
The driver will not travel to top of cylinder if the driver oring/ring is too worn or the driver is bent. The driver should fit snug into the cylinder but be able to travel rather freely . At the bottom of the cylinder check that the bumper is not missing pieces or is cracked. Some nailers have a washer below the bumper that fits snugly around the driver shaft. The bumper and washer prevent too much air from leaking down thru the nose and helps to push the driver back up to top. There is a check valve around the med section of the cylinder that is what actually caused the piston to return to the top with force. You must remove the cylinder to check. Parts are available at www.toolpartsdirect.com. There is also a rebuild kit for this gun. Enjoy
Dec 12, 2008 | Dewalt D51844 Framing Nailer
Spin cycle complete; door refuses to open
check if the water has completely emptied - maybe the filter needs clearing.
otherwise. switch off mains. take top off. feel down the front of the machine to the door lock. you can usually find the peg and operate it with thumb nail but difficult
i assume you have'nt broken the door handle
Sep 18, 2008 | Belling SGE12X Front Load Washer / Dryer
Ice maker
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Sep 10, 2008 | KitchenAid Superba Architect KSCS25INSS...
Removing front cover
The gray framing around the unit will lift up. You only need to place you finger nail in the notch on the top of the framing in order to gently pry it open. Once you open it up the reset button will be on the right side of the unit.
Nov 02, 2007 | Garmin StreetPilot c340 GPS Receiver
Dewalt Dc618k 18v Xrp Cordless 16 Gauge 1-1/4-in - 2-1/2-in Angled Finish Logo
131 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
