Question about Hunter 44360 7-Day Programmable Digital Thermostat
I have a Hunter Thermostat 44360 7 day Programable and I want to cancel all programs and just use it manually amy help?????
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
There should be a tiny unmarked hole in the front of the thermostat....if so, the thermostat 'reset' micro-switch should be under that hole. Gently stick a thin toothpick inside to depress the switch and get ready to operate it manually.
If there is no hole, separate the thermostat from its sub-base and look closely at the sub-base for a reset button.
Posted on Apr 14, 2015
Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Oct 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
I need a new manual for my 44360 Hunter programmable thermostat.
Try this URL. Should be able to download it for free.
http://homeappliance.manualsonline.com/manuals/mfg/hunter/44360.html
Click on the above link. If that doesn't work for you, copy and paste it into your browser's URL line.
Oct 13, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter fan 44360 won't turn my furnace on
List of things to check:
Are the batteries good?
Is the system switch set to heat, and not cool?
Does the fan come on when you set the fan switch to ON?
If none of these things seem to be the problem, call hunter fan tech support at 1-888-830-1326
Oct 08, 2009 | Hunter Fan Company 5/1/1 Programmable...
Replacing 2 honeywell thermostats with Hunter.
The hunter uses batteries and a ram chip to "remember" how you set it, the common is not needed with the Hunter. Some thermostats used the 24 volts of the thermostat circuit for powering up displays or for internal functions such as relays etc. Modern stats consume such a small amount of juice it is not typically required these days.
Aug 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
Need a user guide/owners manual for a hunter thermostat - model 44360. Any suggestions?
Most manufactures have all their manuals available (for free) online, if you have trouble finding their site, try google or your fav search, good luck, Chuck
Mar 16, 2009 | Hunter Fan Company 7-day programmable...
I have 5 wires, white, red, yellow, blue and green and am trying to install the Hunter programable thermostat model 44360. I am not sure which wires connect to what...help.
The standard code is red is power or [R] on your t-stat, yellow is cooling or [Y], blue is common or [C], and green is fan or [G]. This is standard across U.S.A. if the installer, installed it correctly. I as a rule of thumb look in the air handler to make sure the colors are correct. I always tell my techs. that elec. doesn't any color and this could you from burning up your t-stat. Plus, while your in the a/h you can make sure your blue common wire is connected. You will need this to run your programmable t-stat. If you are replacing a reg. t-stat then it might not be in use, but without it your running the t-stat on battery back up.
Sep 28, 2008 | Hunter Heating & Cooling
Hunter 44360 thermostat wiring
OMG! has anyone came up with a solution? I have the same problem as mlc3530b
Mar 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
google search hunter thermostat and the model number and manual and it should come up, I found mine with "hunter thermostat 44200 manual"
Nov 25, 2007 | Hunter Fan Company 5/1/1 Programmable...
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
Programmable thermostats at discount prices at hunter-thermostats.com.
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44360 7-Day Programmable Digital Thermostat Logo
247 people viewed this question
Top Hunter Heating & Cooling Experts
Jay Finke
Jay Finke
Mack Baxter
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
