Question about Watches
How do I change the time mode from 24 hour mode to 12 hour mode on my Sportline 5141? I go through the mode options but it doesn't give me the option of changing from military mode to 12 hour mode.
I have the time set but when I push the mode button it doesn't give the option of changing the mode from 24h to 12h. This happened after replacing the battery.
  • 12 Answers
SOURCE: 24 hour-12 hour time
Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
Posted on Jul 05, 2007
  • 29 Answers
SOURCE: How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
Posted on Mar 12, 2008
  • 2501 Answers
SOURCE: how to change a swatch beat watch to 12 hour from
Go to the Swatch web site "www.swatch.com"
Select "watches"
Scroll down to "Customer Services", select "manuals"
Select and download the manual for your watch.
Posted on Jan 02, 2010
cmcduncand
  • 714 Answers
SOURCE: The time is set to military (24 hr) and I can't
A little bit more information would help our staff address your question.
Please be as specific as possible adding as much information as you can provide will ensure a more accurate response to your question.
The below information is currently requested:
-Name brand.
-Model.
Posted on Mar 17, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a timex 1440 .It is set in 24 hour mode. I
http://assets.timex.com/user_guides/W207_M115/W207_M115_NA_EN.pdf
Posted on Feb 23, 2011
I cannot get it off of military time. Help!!
push the MODE button until you find the 12 hour setting not 24 hr .
Apr 27, 2016 | Watches
How do I get the watch out of 24 Hour (military time) display mode.
You will need to press the adjust button the same way you change the time and then by clicking the mode button you will get to an option to switch from 24-hour to 12-hour watch.
Mar 09, 2011 | Watches
HOW DO I CHANGE MY WATCH FROM 24 HOUR MODE TO 12 HOUR MODE?
click on mode or setting option.then you will see the default time.edit it..try to change it using select or any mode available.there you can see 24hr clock and 12 hr clock.select which one you want.if it is in 12 hr then the time will be displaying like eg:7:00am or 7:00pm it means that it is in twelve hours.if it is showing 7:00 or 19:00 it means it is in 24hr clock.
Jan 29, 2011 | Casio W71-1V Wrist Watch
How do you get the time from military to normal? and how do yo set the date and time?
  1. Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  2. Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  3. Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  4. Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  5. Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
Sep 19, 2010 | Watches
How do I get my WR 100 ft model # AW60724W off army time.
Aug 31, 2010 | Watches
Trying to convert to military time
Best regards. Jewel
Aug 30, 2010 | Watches
How to change from military time back to regular time on a digital indigo watch with 4 adjustment buttons?
Thank you for contacting FixYa.<br /> <ol id="ecxintelliTxt"> <li id="ecxjsArticleStep1"> Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.<br /></li> <li id="ecxjsArticleStep2"> Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.<br /></li> <li id="ecxjsArticleStep3"> Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.<br /></li> <li id="ecxjsArticleStep4"> Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.<br /></li> <li id="ecxjsArticleStep5"> Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.<br /></li></ol> Contact TIMEX for further assistance at:<br /> http://www.timex.com/info/Product_Instruction_Guides_Downloads
Aug 25, 2010 | Timex 1440 Nylon watch
How do you change the time setting to 24 hours?
  • Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  • Step 2 Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  • Step 3 Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  • Step 4 Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  • Step 5 Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
  • Aug 17, 2010 | Columbia All Sport Digi Watch l
    I need to find someplace to download the instructions, since mine didn't come with any
    I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
    I hope this helps.
    SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
    FEATURES:
    24 hour stopwatch
    Time-of-day and calendar
    Alarm clock
    BATTERY:
    Replace with LR41 battery
    TO SET TIME AND CALENDAR:
    From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
    Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
    Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
    Press and hold START/STOP SET button to advance digits rapidly.
    Press MODE button once to return to normal time display.
    From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
    TO SET ALARM:
    From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
    Press SPLIT/RESET button to cycle through minutes and hours.
    Press START/STOP SET button to change digits.
    Press MODE button to return to normal time display.
    From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
    TO ARM/DISARM ALARM SOUND:
    From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
    Alarm will sound when indicator shows in upper right corner.
    Release SPLIT/RESET button to return to normal time display.
    TO ARM/DISARM HOURLY CHIME SOUND:
    From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
    Chime will sound when dashes appear along top of display.
    STOPWATCH OPERATION - GENERAL:
    From normal time display, press MODE button once to reach stopwatch timer display.
    After use of any stopwatch feature, press MODE button once to return to normal time display.
    START-STOP (TIME-IN/TIME-OUT) TIMING:
    With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
    SPLIT TIMING:
    With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
    1-2 FAST FINISH:
    Press SPLIT/RESET button for STOP #1.
    Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
    Press SPLIT/RESET button. The stop time for #2 will now be shown.
    Press SPLIT/RESET button to reset the timer to 0.
    Apr 17, 2009 | Watches
    Cannot change from 24 hour to 12 hour also did not change to daylight savings time
    To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
    Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
    Watches Logo
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
