Question about Garden
How much oil does a Karcher k3000G pressure washer pump take.
  • 883 Answers
SOURCE: Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Posted on Jun 10, 2007
SOURCE: Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Posted on May 21, 2009
  • 92 Answers
SOURCE: Can't fine where to put pump oil in
Dear glenoaks06,
I handled various Karcher washers, but the 2500 I never came across it. Just the same I will give you a few hints and maybe the solution for the problem. When the oil is milkey this means it has water in it. This means that there are faulty seals for sure. Now in many Power Washers the compartment where the oil is located is filled with oil prior to assembling the head unit that contains the pistons. So you have to take apart the the complete head change all seals( HP seals, LP seals and OIL seals). There are pumps that take multi-grade oil(15/50) and others 90 grade oil. If your pump is fan cooled, it probably takes 15/50 oil. Now one of the main biggest problem of water in oil is Faulty and Scratched PISTONS.
So when you have the pump apart....check condition of pistons. It is useless to change seals if pistons are damaged.
Now one thing regarding your problem, is that you have to put together the head with the pump upside down, so that you can fill the compartment (where the pistons are pushed by the swash plate), with OIL, before you put back the complete head with good pistons,springs,seals, valves...etc..etc. These few hints are relevant to quite a number of Karcher washers.
Regards,
Fulltech.
Posted on May 22, 2009
  • 174 Answers
SOURCE: My 2200 Gc Karcher pressure washer oil got mixed
If you are talking about the oil in the pump then it should be 10W30 but must be NON DETERGENT. Remember the reservoir should only be 1/3 full
Posted on Aug 09, 2009
  • 583 Answers
SOURCE: Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Posted on Sep 05, 2009
What is oil type for my pressure washer pump (K2300G)?
PDF]Service Handbook High-Pressure Washer Pump 3.532-629.0
www.mymowerparts.com/...Pressure-Washer.../Karcher-Pressure-Washer...
Sep 28, 2001 - For Karcher Pressure Washer Parts Call 606-678-9623 or 606-561-4983 .... Oil Bath. The swash plate and pistons are bathed in oil. (oil type ...
Oct 21, 2015 | Garden
How do I fix a Karcher 2600 PSI pressure washer has water in oil..
you mean water in the pump oil ??? or engine oil ???
im suspecting pump oil... you didn\'t seal it properly or you have a crack somewhere in the main housing. rarely is it viable to repair these pumps... if you search a little you can find replacements pretty damn cheap !!!
Aug 09, 2014 | Karcher G 2600 VH Gas Pressure Washer
Oil type in Karcher gearbox
If you are talking about the water-pump gear box only, the correct oil type is 30W NON-Detergent oil. "ONLY"
Mar 15, 2014 | Karcher Garden
I WOULD LIKE TO KNOW, WHAT OIL TO USE FOR ANY KARCHER PUMP. Thanks. Richard V. Tucker
This depends on the brand of pump that you have, there are many different pump oils out there, getting the correct one is essential to increase the life of your pump.
Oct 06, 2010 | Karcher 2500 PSI Pressure Washer
Need to know what oil to use for oil change in the kracher by honda
engine oil....10-30...sh/sj.......19.52 oz do not over fill
oil in pump is a special oil through karcher....3.52 oz of pump oil
Jul 15, 2010 | Karcher 2500 PSI Pressure Washer
My 2200 Gc Karcher pressure washer oil got mixed with waer and I need to replace it. What oil should I use?
Aug 09, 2009 | Karcher K 5.85 M Electric Pressure Washer
Dear glenoaks06,
Regards,
Fulltech.
May 19, 2009 | Karcher 2500 PSI Pressure Washer
Karcher pressure washer leaking oil
Usually electric pressure washers only have oil on the pump, so its very likely that you will find the problem there. I'd say check all the pump seals and if that doesnt solve the problem, you can check to see if all bolts are tight when you close the pump back.
If by any chance you are looking for a new machine and/or parts for your machine, log in to www.roncoshop.com where you will be able to find pretty much anything for your preassure washer.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
