Question about Scuba Diving & Snorkeling
I need to replace a regulator TOP 245y - Scuba Diving & Snorkeling
Needed to replace a defective REGULATOR TOP 245Y
What is the question?
The substitutions,where to buy, or ...?
Apr 14, 2015 | Music
Need a regulator for Thermos Grill 2 Go
I bought this to replace the regulator I lost for my Thermos Grill2Go. Little modification to the grill and it worked like a champ. Portable Propane Table Top Regulator 1 by 20 Female Throwaway Cylinder... need-regulator-thermos-grill-2-go-2i4ggwcr0e0sverpwaph0wvr-1-0.jpg
Aug 22, 2012 | Thermos Grill2Go Fire+Ice
I need a regulator valve for a thermos grill2go bbq model number UK-467638503,PART NUMBER 4158176
Jul 29, 2011 | Thermos Grill2Go Gas Grill 4656110
How would I replace my fuel Filter
The fuel filter is an integral component of the fuel pressure regulator, which is mounted on top of the fuel pump module, located in the fuel tank. When the fuel filter/regulator assembly requires service, the fuel tank must be removed from the vehicle, however, the fuel pump module does not need to be removed.
  1. Disconnect the battery ground cable.
  2. You dont have to relieve your fuel systems pressure because your jeep has an automatic bleeder.
  3. Remove the fuel tank assembly.
  4. Clean the area around the fuel filter/regulator.
Fig. Fig. 5: Remove the fuel filter/pressure regulator retaining clip from the top of the assembly
Fig. Fig. 6: Replace the old fuel filter/pressure regulator mounting gasket
  1. Disengage the retaining clamp from the top of the filter/regulator assembly. Discard the retaining clamp.
  2. Using 2 small prying tools, pry the filter/regulator assembly out from the top of the fuel pump module. The filter/regulator assembly will unsnap from the fuel pump module.
  3. Remove and discard the mounting gasket below the filter/regulator.
  4. Before discarding the fuel filter/pressure regulator assembly, inspect the assembly to verify that the O-rings are intact. If the smallest of the 2 O-rings cannot be found on the bottom of the filter/regulator, it may be necessary to remove it from the fuel inlet passage in the fuel pump module.
To install:
Fig. Fig. 7: Check the condition of the fuel filter/pressure regulator O-rings
  1. Clean the recessed area in the pump module where the filter/regulator assembly is to be installed.
  2. Check the replacement filter/regulator assembly to make sure that the new O-rings are already installed on the assembly.
  3. Apply a small amount of clean engine oil to the O-rings.
  4. Install a new gasket on top of the fuel pump module.
  5. Press the new fuel filter/pressure regulator assembly into the top of the fuel pump module until it snaps into position (a positive click must be heard or felt).
  6. The arrow on top of the fuel pump module should be pointed towards the front of the vehicle (12 O&rsquoclock position).
  7. Turn the filter/regulator assembly until the supply tube (fitting) is pointed to the 11 O&rsquoclock position.
  8. Install new retainer clamp (the clamp snaps over the top of the filter/regulator and locks to the flanges on the pump module).
  9. Install the fuel tank assembly.
  10. Connect the negative battery cable.
Jan 28, 2011 | 1996 Jeep Grand Cherokee
No sound speakers are good
May just need solder on the voltage regulators, or may need 2 capicators. If you remove the top cover and bottom panel the reglator run from front to rear in the middle of the receiver. The caps are to the left of the regulators, If they are domed on top they need to be replaced.
Est. for repair $90-$110
Nov 26, 2009 | RCA RT2500 System
I need a new regulator with a low med high knob for two burner dyna glo tank top heater propane if tou have how much if not where can I get one thank you
If you don't have an authorized dealer to get a replacement regulator, contact GHP Group Inc, (877) 447-4768. MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Here's a link to the manual for eight of their tank-top heaters
Replacement cost including shipping is a couple bits over $21.
When talking to the technician on the phone, he cautioned me against rapidly opening the tank valve, which hammers the regulator (the replacement one is more robust than the original), kinda' like how water-hammer can cause damage to water pipes and/or water appliances. Open the tank valve gently, don't just whip it open (like I used to), your regulator will last a lot longer that way.
Because of the press-fit and pins used in the regulator construction & assembly, self-repair is not possible or recommended since the regulator may not seal correctly afterwards.
Nov 20, 2009 | Grilling
2003 explorer front passenger window regulator/motor replcement
You will first need to remove the door panel on the inside. Then you will need to remove the window glass from the track it rests in. Then you need to undo all the screws that attach the regulator inside the door. At the top of the door where the glass slides up and down remove the inner and outer window track guides. Then very carefully maneuver the regulator up and out the top of the door. Reverse the procedure to replace. It sounds easy, but you need to almost be double jointed to do this. So, have great patience while doing this task. Good luck.
Feb 26, 2009 | 2002 Ford Explorer
Rear window regulator broke
The regulator is attatched to the glass using the rivets through plastic disks. You need to drill them out before the glass can be removed.Save the plastic parts for reassembly.Good Luck
Aug 25, 2008 | 2002 Ford Explorer
Scuba Diving & Snorkeling Logo
469 people viewed this question
Top Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
