Question about Copystar Copier Cs 1505
Do you know where I can find a manual for a copystar cs 1505 copier?
I was looking for a manual for my copystar. It won't print. The add toner light was on and I added toner. It still do not print.
wayneard
  • 1901 Answers
SOURCE: CS-2030 Manual
Here is a link to Copystar support for your copier:
Copystar CS-2030 Documentation
There are links to several handbooks and guides.
Posted on Dec 05, 2008
  • 990 Answers
SOURCE: COPYSTAR CS-1810
Hello sir; "AP" isn't a problem, just let it run for a little while, it will disappear.
Posted on Feb 19, 2009
krizanto81
  • 65 Answers
SOURCE: how to put an IP address on the CopyStar CS-1820 printer
putting an ip to 1820, just go to system menu, scroll down look for the network setting, you will find ip address, then fill it up.
Posted on Jun 27, 2009
SOURCE: Copystar CS-1815 waste toner
There are two screws on the drum unit. They are on the left hand side and one on the right hand side. Remove the screw from one side and take off plastic small side cover. Dump the waste toner. Do the same for the other side and then put it back together. Turn machine off then on and the error code should be gone......
Posted on Aug 06, 2009
n25an
  • 622 Answers
SOURCE: Copystar CS-2550 Set up add'l scan folders - need to reset psswrd
try 6482... or call kyocera support or call a kyocera service tech
Posted on Dec 26, 2009
We replaced the toner cartridge and the waste receptical and the little red light "Add Toner:" is still on and the machine won't copy. We have removed the cartridge and did the dance...
If it is a Kyocera toner than that is the problem. The key to turn the toner is different for the Kyocera toner cart. It will fit and appear to work but won't. Also turn the unit off and unplug for 15 sec. will reset and perform boot up procedures might help.
Jul 07, 2011 | Copystar CS-1810 Copier
What does the code c-620 mean on a cs 1505
This is a fuser related error. Either the thermostat or thermister is faulty. The error can be rest by pressing and holding down stop, start, left exposure or light. Release the keys and press stop. The display will show U000. Press 163, press Start twice. the machine will initialize.
Nov 09, 2010 | Copystar CS-1505 Copier
What does error code ap mean?
AP means ADD POWDER........Toner
Jun 24, 2010 | Copystar CS-1505 Copier
The add toner light stays on with a new toner cartridge
Yes, the machine will only make single copies if the toner light is on. Was the toner cart genuine Copystar? Or perhaps Kyocera cart? The machine is made by Kyocera and marketed under both name brands, however, the toner carts are different for both machines. I have seen many times that aftermarket carts will not always work properly.
Jan 06, 2009 | Copystar CS-1510 Copier
C 610 Error Code on a CS-1505 copier
There is no 610 code ,there is 620&630 which are fuser problems.press and hold down these keys,stop/reset key /start key/copy density key.Press stop/reset keyb again. enter U163,press start."CLE"will display.Press start again to clear.Exit the mode with 001.
Dec 04, 2008 | Copystar CS-1505 Copier
Black page
Main charge unit is shorting out.
Pull the main charge unit out of machine.
Take cleaner (included with toner) and clean.
--Look at front and rear for toner build -up on the charge grid.
This build -up causes a short.
After cleaning, reinstall and run.
Oct 21, 2008 | Copystar - CS-3035 Printer
Pls. help!
Hi, If you go to this web page you can download the manual for that machine.
http://usa.copystar.com/CopyStarPub/jsp/upload/resource/3389/0/1505ENIHR1B.PDF
The Copystar cs 1505 should be the same as the Kyocero
Hope that helps...
Sep 03, 2008 | Kyocera KM-1505 Copier
Copystar Copier Cs 1505 Logo
32 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
