Question about Microsoft Office Standard for PC
ACDsee6.0 device detector
I am having trouble with my CD ROM and DVD. They are running fine but don't show on my monitor. I think the device detector isn't recognizing them. I have an icon for the device detector on my desktop toolbar that wasn't there before this problem. How can I check and see if this is the problem
  • 62 Answers
Re: ACDsee6.0 device detector
I am not sure what you are talking about.
Are you saying you can't install your Office?
Posted on Dec 01, 2007
0 characters
3 Points
Need to fix office 2007 from compatability
Windows 7 Office 2007 Minimum Requirements b> Microsoft Office 2007 isn't the latest version of the Office suite, but it is still useful for a variety of tasks. The software package includes programs for editing spreadsheets, working with documents, creating presentations and more. Office 2007 also includes a redesigned user interface that is more intuitive than previous versions. Chances are good your computer can run Office 2007 if you already have Windows 7 installed, but you should check the system requirements anyway to ensure a trouble-free installation.
Processor and Memory Your computer needs a 500MHz or faster processor plus at the very least 256MB RAM. You may need more memory if you wish to run multiple Office applications simultaneously. The Business Contact Manager in some versions of Office requires a 1GHz processor and 512MB RAM. Turning on the grammar checker in Word requires 1 GB of RAM. Hard Drive and Optical Drive b> Make sure you have at least 1.5GB of available space on your hard disk to install Office 2007 standard and 2GB for other versions. You also need a CD-ROM or DVD-ROM drive for installation. Monitor b> Your display should have a 1024x768 resolution or higher. Older 800x600-resolution monitors are not compatible with Office 2007. 64-bit Compatibility and Windows Updates b> Note that you may run the 32-bit version of Office 2007 on 64-bit versions of Windows 7, but you cannot run Office 2007 64-bit on 32-bit editions of Windows 7. Make sure your copy of Windows 7 is up-to-date for best results. Microsoft releases fixes and other updates periodically that address stability issues and other known bugs. You can use Windows Update, on your "Start" menu, to check for updates.
Compatibility center b> 2007 Microsoft Office System Requirements
Feb 26, 2013 | Microsoft Office Professional 2007 Full...
Computer is not reading the installation disk
By installation Disk do you mean the CD/DVD-ROM? If yes
Check to see if the drive's LED flashes when the system is trying to boot. If it doesn't, open the system and make sure all the cables to the CD/DVD- ROM is properly connected and to the right slots. If the cables are properly connect and the CD/DVD- ROM is still not working replace the CD/DVD-ROM.
However, if its that the system could not install a particular program, make sure the installation files are complete and try again. If its a downloaded program, verify the completeness of the file downloaded and try reinstalling the program.
Feb 13, 2012 | Peachtree Software Business & Productivity...
I have a mini notebook and would like to install office 2007. I cannot install using a cd rom since there isn't one. is there another way I can do this?
Install it from a hard drive... or.. set your pc on a network then share the cd room on the other pc ot he network... run and install the application...
Dec 30, 2010 | Microsoft Office Professional 2007 Full...
I have an acer netbook computer running with vista and 2 mg RAM. I am using a usb CD Rom drive to lload programs. When I try to insstall Office Enterprise 2007 (licensed for students and faculty) the disk...
Sorry, but that's not the case. Most DVD drives will read CD's, but most CD drives will not read DVDs, so unless yours specifically says it's a DVD drive, It's not going to work for you. HINT: the cost of a DVD drive is far less than the cost of Office software.
Dec 08, 2009 | Microsoft Office Professional 2007 Full...
How to install microsft professional office 2003 to a samsung n130 netbook as i am having problems keeps coming up that the process was corrupted??? i just got it today so its at its basic stance??
samsung n130 has no internal cd/dvd rom you have to use an external cd/dvd drive, if you have an spare desktop computer that has cd or dvd rom and usb drive 1 or 2 gb, copy the entire installation disc to the usb and plug it to the samsung n130 from there run the setup process of ms 2003 by doing these process you will be able to install office 2003 with out corruption
Nov 20, 2009 | Business & Productivity Software
Unable to install card studio 2009 has dvd-rom instead of cd-rom
Well, you have a couple of choices:
1) You can have a DVD installed in your computer. Usually around $50.
2) You can purchase a flash drive (thumb drive) of at least 4GB. Depending on the size of the files, you may need an 8GB. You can have a friend copy the entire DVD onto the flash drive. Then you can take the flash drive and copy the entire DVD from the flash drive to your computer and install the program or install directly from the flash drive. (It may auto start when you insert it into a USB port.)
If you install it from the flash drive you will probably have to insert it every time you run the program. If you copy the DVD to your hard drive you will not have to and it will run faster.
Thanks for using Fixya.
Nov 10, 2009 | Hallmark Card Studio 2009 Deluxe Full...
Dvd read and write problem
this problem is dvd writer lense so he can't dvd read and write
Apr 09, 2009 | Microsoft Office Professional 2007 Full...
How to test if DVD rom and DVDrw drives are functioning properly
place a readable disk cd disk into the cd . Go into MY COMPUTER and see if it is there and if you can open it to see the content.
Put a blank CD into the dribve.  Open     MY COMPUTER , open CD DRAG something into the CD. see if it wil transfer and burn. It wil say "programs ready to burn"
DVD unless it is a Data DVD you have to have  softweware for the DVD player and Burner not supplied by the windows System.
Dec 30, 2008 | Microsoft Office Professional 2007 Full...
Setup problem in ms office
Were you installing from the Cd/Dvd? if so your Cd rom can't read the contents of the Cd, try with another Cd rom, or you can use your friend's pc and see if it's possible there. If not, then it's difficult to get back the files. You need to get another copy of Ms office. visit this link for alternative solution
Aug 21, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Office Standard for PC Logo
118 people viewed this question
Top Microsoft Business & Productivity Software Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Microsoft Business and Productivity Software Expert? Answer questions, earn points and help others
