Question about Dishwashers
Washer will not come on where is the 10 amp fuse
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Oct 10, 2016 | Volvo 850 Cars & Trucks
Washer pump fuse repeatedly burns out
Your pump needs to be replaced, try a 15 amp fuse, if that blows you definitely need a pump. The pump is failing and is pulling more amperage than designed.
Sep 09, 2015 | 2009 Chevrolet Chevrolet Equinox LS
My fuse box cover has numbers to show what fuses go to what, I need a list of the numbers
1. 15 AMP Dome Lamps, Power mirrors (on 2 door models only), radio memory
2. 6 AMP front washer/ wiper
3. not used
4. 15 AMP stop lamps, 4 way flasher
5. 15 AMP back-up lamps, daytime running lights, rear defrost, turn lamps and turn indicator
6. 10 AMP speed control
7. 15 AMP instrument cluster warning lamps (explorer limited model #7 is 15 AMP heated outside mirrors)
8. 20 AMP horn
9. 10 AMP air conditioner switches, clutch coil
10. 15 AMP Park/ license plate lamps, trailer tow connection
11. 15 AMP radio
12. 20 AMP cigarette lighter, flash bright lights(from signal arm)
13. 10 AMP instrument panel illumination
14. 30 AMP power windows
15. 10 AMP ABS module
16. 20 AMP premium radio amplifier
17. 15 AMP rear washer/ wiper (explorer limited model #17 is 15 AMP warning gauges and lamps, 4 wheel drive)
18. 15 AMP heated exhaust gas oxygen
that's you list. hope it helps.
Aug 26, 2010 | 1992 Ford Explorer
Diagram of 1996 ford ranger fusebox which fuse is
RANGER FUSE PANEL Fuse Position Rating Circuit Protected 1 7.5 Amp Power Mirror 2 — Not Used 3 15 Amp Parking Lamps 4 10 Amp Left Headlamp 5 10 Amp On Board Diagnostic (OBD) II System 6 7.5 Amp Air Bag System/Blower Relay 7 7.5 Amp Illumination Switches 8 10 Amp Right Headlamp/Fog Lamp System 9 10 Amp ABS System 10 7.5 Amp Speed Control/GEM System/Brake Interlock 11 7.5 Amp Warning Lamps 12 10 Amp Front Washer System 13 15 Amp PCM System/Stoplamps/
4WD/ABS/Speed Control 14 10/20 Amp ABS System 15 7.5 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 15 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 7.5 Amp Radio/GEM System/Anti-Theft 21 15 Amp Hazard Lamps 22 10 Amp Turn Signals 23 — Not Used 24 10 Amp Starter Relay/Anti-Theft 25 7.5 Amp Speedometer/GEM System 26 10 Amp 4R44E/4R55E Trans./Backup Lamps/DRL System 27 10 Amp Underhood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/4x4 Sys. 28 7.5 Amp GEM System 29 10 Amp Audio System 30 — Not Used 31 — Not Used 32 — Not Used 33 15 Amp High Beam Lamps 34 — Not Used 6d47eae.gif
Nov 01, 2009 | 1996 Ford Ranger SuperCab
Nissan maxima 1996
moz-screenshot.png#1-10 amp
SRS (Aribag)
#2-15 Amp
Air conditioner
#3-15 Amp
Air Conditioner
#4-7.5 Amp
A/T TP/Sw
#5-Tail LIght, Turn Signal Switch
#6-15 Amp
Horn
#7-10 Amp
Power Mirror, Mirror Heaters
#8-10 Amp
#9-10 Amp
#10-15 Amp
Power Windows
#11-10 Amp
Turn Signal
#12-7.5 Amp
Power Windo, Door Locks, Sunroof, Time control unit
#13-10 Amp
Meter, ABS, ASCD, Back-up Lights, Air bag, Warning Chime
#14-7.5 Amp
Corner, Turn
#15-10 Amp
ABS
#16-7.5 Amp
#17-10 Amp
A/C, Fuel Pump, Canister, EGR, Cooling Fan, ASCD
#18-7.5 Amp
Illumination
#19-7.5 Amp
Wiper Motor
#20-20 Amp
Wiper washer timer
#21-10 Amp
Horn, Audio, Power Antenna
#22-15 Amp
Audio
#23-10 Amp
#24-10 Amp
#25-15 Amp
#26-7.5 Amp
Step/L, Room
#27-10 Amp
#28-7.5 Amp
#29-7.5 Amp
Heated Seats
#30-20 Amp
A/C
#31-10 Amp
#32-15 Amp
Fuel Pump
#33-10 Amp
Theft Warning System
#34-10 Amp
Fuel, RO2H
#35-15 Amp
#36-7.5 Amp
#37-10 Amp
TLID, MULTI
#38-7.5 Amp
Rear Defogger
#39-7.5 Amp
Rear Defogger
#40-20 Amp
Door Lock, Horn, Multi, SRS, Power Antenna, Timer
Aug 01, 2009 | 1996 Nissan Maxima
Need fuse box pannel to see what fuse is what
FUSE USAGE
1. 10 AMP LOW BEAM-LEFT
2. 10 AMP LOW BEAM-RIGHT
3. 30 AMP BRKR POWER WDO/SUNROOF
4. 30 AMP BRKR PWR ACSRY
5. 20 AMP BRKR LIGHNG CONTROL MODULE
6. 15 AMP IGN/REM ACSRY CONT/INST CSTR
7. 10 AMP SUPPLEMENTAL INFLATABLE RST
8. 20 AMP CORNERING LPS/TURN SIG
9. 10 AMP CRANK SIGNAL-SIR
10. 20 AMP TRK REL/FUEL FILL REL/BACK-UP LPS
11. 15 AMP BAT/RADIO/PWR ANT/CIG LGTR/ INST CSTR
12. 20 AMP ELECTRONIC LEVEL CONTROL
13. 20 AMP BRAKE & HAZARD LAMPS
14. 15 AMP PARK LAMPS
15. 15 AMP COURTESY LPS/PWR MIRRORS
16. 10 AMP COOLING FAN
17. 25 AMP HEATING/AIR CONDITIONING (C67)
18. 15 AMP A/C AUTOMATIC ELECTRONIC (CJ2)
19. 10 AMP ANTILOCK BRAKES
20. 10 AMP LOW COOLANT/LAMP MONITOR
21. 10 AMP IP LIGHTS
22. 10 AMP HI BEAM-RIGHT
23. 10 AMP HI BEAM-LEFT
24 10 AMP IGNITION/RADIO
25 25 AMP WIPER/WASHER
FOR ACCESS TO ADDITIONAL FUSES
REMOVE RIHT SOUND INSULATOR
May 16, 2009 | 1991 Buick Park Avenue
Main fuses for the horn and air bag
Fuse #8, #18 and #22.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Apr 02, 2009 | 2004 Dodge Intrepid
Radio fuse/cd changer
Number Fuse Amperage
Rating
Circuits Protected
7 7.5 amp Illumination switches
8 10 amp Right headlamp, fog
lamp system
9 10 amp Autolamps
10 7.5 amp Rear blower, speed
control, GEM system,
brake interlock,
overhead console
11 7.5 amp Warning lamps
12 10 amp Liftgate wiper/washer,
front washer
13 15 amp Brake on/off switch
14 10 amp Anti-lock system
15 7.5 amp Air bag system,
instrument cluster
16 30 amp Wiper run relay
17 15 amp Cigar lighter
18 15 amp A/C system
19 25 amp Ignition coil, PCM
system
20 7.5 amp Radio, power antenna,
GEM system,
anti-theft
21 15 amp Turn/hazard flasher
22 10 amp Turn signals
23 10 amp Rear wiper system
24 10 amp Anti-theft relay
25 7.5 amp Instrument cluster,
GEM system
Nov 11, 2008 | 1997 Mercury Mountaineer
Jetta electrical problems
hi, i recently bought a used 2001 jetta and had the same problem...auto locks, sunroof, windows, interior lights, trunk switch on door all stopped working all of a sudden. replaced fuse #14 and everything works like magic again...
I found this fuse diagram A LIFE SAVER!!!
-----------------[ S8 ][S 12][S 16][S 20]
-----------[ S5 ][ S9 ][S 13][S 17][S 21]
[ S1 ][ S3 ][ S6 ][S 10][S 14][S 18][S 22]
[ S2 ][ S4 ][ S7 ][S 11][S 15][S 19][S 23]
[ S 24 ] [ S 31 ] [ S 38 ] -- -- --
[ S 25 ] [ S 32 ] [ S 39 ] R R R
[ S 26 ] [ S 33 ] [ S 40 ] S S S
[ S 27 ] [ S 34 ] [ S 41 ] -- -- --
[ S 28 ] [ S 35 ] [ S 42 ] R R
[ S 29 ] [ S 36 ] [ S 43 ] S S
[ S 30 ] [ S 37 ] [ S 44 ] -- --
S1=10 AMP=Heated washer nozzles, glove compartment light, memory seat...
S2=10 AMP=Turn Signal System
S3=5 AMP=Fog Light Relay, Instrument Panel Dimmer Switch
S4=5 AMP=License Plate Lamps
S5=7.5 AMP=Comfort System, Cruise Control, Climatronic, A/C, Heated Seat Control Modules, Day/Night Dimming Mirror, Control Module and Control Unit for Multifunction Steering Wheel.
S6=5 AMP=Central Locking System
S7=10 AMP=Back-up Lights, Speedometer Vehicle Speed Sensor.
S8=OPEN
S9=5 AMP=Anti-Lock Brakes.
S10=10 AMP for GAS/5 AMPS for Diesel=ECM
S11=5 AMP=Instrument Cluster
S12=7.5 AMP=B+ (battery positive for data-link connector) (DLC).
S13=10 AMP=Brake Lights
S14=10 AMP=Interior Lights, Central Locking System
S15=5 AMP=Instrument Cluster, Automatic Transmission Control Module (TCM).
S16=10 AMP=A/C Clutch, After Run Coolant Pump.
S17=Open
S18=10 AMP=High Beam Right
S19=10 AMP=High Beam Left
S20=15 AMP=Low Beam Right
S21=15 AMP=Low Beam Left
S22=5 AMP=Parking and Side Marker Lights, Right
S23=5 AMP=Parking and Side Marker Lights, Left
S24=20 AMP=Front Wiper Motor, Washer Pump
S25=25 AMP=Fresh Air Blower, Climatronic, A/C
S26=25 AMP=Rear Window Defogger
S27=15 AMP=Rear Wiper Motor
S28=15 AMP=Fuel Pump, Gas Engine Only
S29=15 AMP Gas/10 AMPS Diesel=ECM
S30=20 AMP=Sunroof Control Module
S31=20 AMP=Automatic Transmission Control Module
S32=10 AMP Gas for Fuel Injectors/15 AMP Diesel for ECM
S33=20 AMP=Headlight Washer System
S34=10 AMP=Engine Control Elements
S35=30 AMP=12 VDC Outlet in Trunk
S36=15 AMP=Fog Lights
S37=10 AMP=Radio Terminal 86S, Instrument Cluster
S38=15 AMP=Central Locking System (w/ Power Windows), Luggage Compartment Light, Remote Fuel Tank Door, Rear Lid Unlock.
S39=15 AMP=Emergency Flashers
S40=20 AMP=Dual Tone Horn
S41=15 AMP=Cigarette Lighter
S42=25 AMP=Radio System
S43=10 AMP=Engine Control Elements
S44=15 AMP=Heated Seats
hope this helps ; )
Sep 14, 2008 | 2001 Volkswagen Jetta TDI
Diagram fuse inside car
Your fuse panel is located by the emergency brake.Depress the two tabs and the fuse box will swing down, the panel diagram is written on the panel door.
Jul 22, 2008 | 1992 Buick Park Avenue
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
