Question about Electrical Supplies
Lost any manual that may have been with it. Where is the gas filter and where can I get a new one?
    Top Expert:
  • 10,875 Answers
My sears garden tractor has lost it's zip but still goes forward and back also noticed my brake no-longer as effective
Sounds like you need to adjust some cables. Consult your owner's manual. I will also suggest that you give it a new fuel filter, air filter and burn nothing else in it but high test gas. Lastly, put a good gas additive in each tankful - a couple capfuls of Sea Foam or equivalent.
Jul 03, 2017 | Sears Garden
Husqvarna 455 rancher new filters /plug get spark wont start put gas in cylinder and wont start what am i missing
Check to see if there is a leak in the air purge bulb (primer bulb), sometimes they crack and allow air in and don't push the gas through properly. Here is the manual for your saw.
Cheers!
http://www.manualslib.com/manual/514275/Husqvarna-455e-Rancher.html#manual
Sep 10, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Gator Manuals 150 scooter
hi Glen.
this is all i could find on manuals.
see if this link helps you out.
Gator Manuals 150 scooter Google Search
Dec 06, 2017 | Health & Beauty
Lost engine power on the road, had to be towed to gas station, then van started again. Guy said it may be fuel filter.
fuel pump could be going bad, i would try filter first(would replace anyway if needs new pump)
Nov 11, 2010 | 2006 Pontiac Montana SV6
Ford ranger suddenly lost power changed the fuel filter but that did not help.Engine picks up a little when manually primed on the fuel filter
Are in a cold climate, gas line freeze? Try puting gas line anti-freeze in the tank. Otherwise, it could be the fuel pump is going out. Check the fuel pressure or have it checked if don't have the proper tools to do it.
Dec 31, 2009 | 2004 Ford Ranger
Nissan sentra fuel problem. Put new filter and fuel pump but no gas getting to filter to get to pump. Gas line problem from tank?
I believe this is a manual fuel pump and you may have lost the prime, no fuel in hose to tank. If the hose from rear frame to tank has a break or hole, it will **** air and not fuel from tank. If this is not the case, possible clogged fuel hose, tubing, or pickup tube in tank assuming you have turned the engine over serveral times and there is enough fuel in tank. Some tanks do not pickup from very bottom because of water laying in bottom of tank from condensation.
Dec 12, 2009 | 1984 Nissan Sentra XE
200 durango starts but wont idel
No codes stored? Throttle position sensor? Do you have correct fuel pressure? 49.2 +/- 5psi?
May 02, 2009 | 2000 Dodge Durango
6yr old Craftsman Lawn Tractor - Koehler 18 HP Auto. Sputter&Dies
Try running it again and when it starts to die remove the gas cap and see if it starts to run better. It's possible that the gas tank isn't venting correctly. If that doesn't work post back and we'll try to come up with some other solutions.
Apr 22, 2009 | Craftsman Garden
Electrical Supplies Logo
51 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
