Question about Indesit Washing Machines
Display is flashing and cracking noise coming from my indesit wixe127
    Genius:
  • Indesit Master
  • 1,585 Answers
Could b bearings or may b electrics need more info on cracking
Posted on Apr 13, 2015
barkencoa
  • 3463 Answers
SOURCE: Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Posted on Nov 21, 2008
barkencoa
  • 3463 Answers
SOURCE: indesit wixe127 error code F05
F05 means that the pressure switch is jammed on full, this is the switch that controls the water level.
It could be a faulty switch, a blocked hose to the switch, or a pump blockage.
Check pump first to see if it is draining o/k.
If o/k ,then there is not a lot more that you can do, unless you are conversant with washers and know how to check pressure switch and pressure chamber and hose for blckage or malfunction.
I would suggest that you call some one in if you can not sort it yourself.
Plz rate my solution.
Thanks.
Posted on Jan 14, 2009
SOURCE: hi i have a indesit
I had the same problem with DENO, while we run the wash machine i press start button and step easier(try the start button and click buttons simultaneously until the code DOF) button until DOF code came, after everything went well. e.ladislau@yahoo.com
Posted on Jan 30, 2009
barkencoa
  • 3463 Answers
SOURCE: error code f-08 on indesit wixe127 washer
Error code F08 means that the heaterrrelay cannot be activated.
Check the connections to the Pressure switch, the Module,and the Heater element.
If you can, test the element of the heater to make sure it is o/k.
Hope this helps.
Posted on Dec 02, 2009
barkencoa
  • 3463 Answers
SOURCE: indesit washing machine wixe127 has f04 faultcode
Error code F04 indicates pressure switch jammed on empty.
to rectify, do the following
Remove lower rear panel of washer.
Remove large black hose on drum
Remove and clean filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Posted on Jan 25, 2010
Error code f-05 on idesit wixe127
F05: Pump Blocked or pressure switch empty not reached
- Check efficiency of J9 connector on card, verifying a voltage of 220V between pins 8 and 9
- Check that pump if being fed
- Check Pump Filter + wall drain
- Change Pump
- Replace Card
Dado
Feb 28, 2015 | Indesit Washing Machines
Indesit WIXE127 washing machine with a flickering display screen
This is a fault with the contoller board and it is possible that the power supply is not stabilising due to an erratic stabilisation. This can be due to faulty capacitors- in case the main filter had leaked and damaged.
If so you can replace them but with case to remove from the PCB.
Also it can be due to poor connector or dry solder on the main board. Best is to check this out without delay as it can damage the board at a later stage..
Jun 26, 2012 | Washing Machines
Indesit wixe127 f-08 error
I have the same problem. Check this info (the below link) I found on F - 08 error for someones hotpoint washing machine. It may be the same thing. There could be standard error codes for all washing machines, maybe.
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&printertopic=1&t=37910&start=0&postdays=0&postorder=asc&vote=viewresult&popup=1
Feb 07, 2010 | Indesit W 123 Front Load Washer
Indesit washing machine wixe127 has f04 faultcode starts cycle then empties and fills simultaneously
Thankyou.
Jan 25, 2010 | Washing Machines
Error code f-08 on indesit wixe127 washer
Hope this helps.
Dec 02, 2009 | Indesit W 123 Front Load Washer
Wixe127 indesit wash machine gets to 1 minute left on wash cycle and just keeps running with 1 minute on display
If all you are getting is a wash cycle and not a spinning cycle this could indicate a faulty door switch. the machine will not allow a spin cycle unless the door is locked.
Oct 10, 2009 | Washing Machines
Indesit washer not spinning
I had exactly the same problem. All seemed ok, except no spin. I followed Shaun's advice and replaced the module board. Cost of about f£23 from ebay, but similar price on espares.co.uk. Fixed it. Thank you.
Aug 04, 2009 | Indesit W 123 Front Load Washer
Hi.
Cheers.
Nov 18, 2008 | Washing Machines
Hi i have a indesit wixe127 and when i switch it on it comes up with deno and will not wash wot is wrong with it
Jun 19, 2008 | Indesit Washing Machines
Washing Machines Logo
55 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
