Question about Westinghouse LD-2240 22" LED TV 1920x1080, 60 Hz, HDTV, LED Backlight
Códigos de acceso mediante antena ATSC - Westinghouse LD-2240 22" LED TV 1920x1080, 60 Hz, HDTV, LED Backlight
  • Anonymous Jan 15, 2016
    nesecito codigo de acceso a canales de la LD-
    2240
    New Friend:
Necesito codigo de acceso a canales TV westinghouse.
Modelo VR-3730
Serie: 6561V14301725
Posted on Nov 07, 2015
2 Suggested Answers
  • 413 Answers
SOURCE: Necesito codigo de acceso a canales de TV westingnhouse Mod.uw32s3pw serie:6990y24703339
click on this link:
www.documentlib.com/.../westinghouse-digital-lcd-uw32s3pw-user-manual
Posted on Jan 17, 2015
Necesito código de acceso a canales mediante antena atsc Westinghouse Modelo 3237 Serie 6500Y15103977
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts
Jan 30, 2017 | Westinghouse Televison & Video
CODIGO PARA PROGRAMAR CONTROL REMOTO
¡Hola
Cuatro d?gitos de los c?digos de control remoto universal para TV Insigina son los siguientes
0103 0189 0217 0135
0133 0116 0167 0456 0029
Cinco d?gitos del c?digo remoto universal para TV con RCA Insigina RCR312W modelo de control remoto son los siguientes
11423, 11564, 10171, 11204, 11326, 11517, 11710, 11963, 12002
Entrada directa de c?digos
1.Pulse y mantenga presionado el bot?n SETUP hasta que el indicador rojo permanezca encendido y luego suelte el bot?n SETUP.
2.Pulse y suelte el bot?n del modo deseado (TV, VCR, etc.) El indicador rojo parpadea y luego permanece encendida.
3.Introduzca el c?digo de 4 d?gitos a partir de las tablas de c?digos. Nota: despu?s de una entrada de un c?digo v?lido, el indicador rojo se apaga. De un c?digo no v?lido, el indicador rojo.
4.Con el dispositivo, la prensa de canal hacia arriba. Si el dispositivo responde, sin necesidad de programaci?n adicional es necesario. Nota: Si algunos botones no funcionan el dispositivo, pruebe uno de los otros c?digos para su marca.
M?todo de b?squeda de c?digo
Si despu?s de intentar "Entrada directa de c?digos" el dispositivo no responde, o si su marca no est? en la lista, trate de hacer una b?squeda en la biblioteca de c?digo para el c?digo, siga estos pasos. OK.
Sep 19, 2011 | Insignia IS 20" TV040919 TV
Como desbloquear codigo de seguridad motorola Q9 IMEI 358305010095173
ur defalt tel?fonos c?digos es 12345 o 00000 u puede utilizar
Predeterminado del usuario de 4 d?gitos del c?digo: 1234 ? 0000
Por defecto 6 d?gitos de seguridad: 123456 o 000000
Por defecto 6 d?gitos de seguridad: 000999 o 1122
Escriba * # 06 # en la pantalla del m?vil para saber el IMEI de su m?vil no.
enviar el IMEI no a m?, y yo le contestaremos con el desbloqueo de c?digo.
SI no Problema resuelto lo tanto
Por favor, instalar nuevo software en el problema del tel?fono se resolver?n
O:
Si por problemas de bacalao y puk pin As? que por favor
Mejor soluci?n: ir a la Oficina de Servicio y Sim y obtener el c?digo PUK y c?digo PIN de la Oficina oprator
Introduzca el c?digo PUK y el S?
Introduzca el c?digo pin y el S?
As? Puk c?digo abierto y el problema se resolver? r?pidamente
Bueno, si est?n vinculados a una red en particular todo lo que tienes que hacer es desbloquear el tel?fono para el uso que cualquier otra red GSM. Usted puede conseguir el c?digo de desbloqueo a trav?s de Internet. Dar su n?mero de IMEI y obtener el c?digo de desbloqueo de m?viles ur ........ ... .. Usted tambi?n consigue a trav?s de Internet .......... voy a sugerir el sitio web de Unlock-Zone.com que se haciendo un buen servicio ..... usted puede acercarse a este sitio web.
Aug 20, 2011 | Motorola Mobility Q9 Cell Phone
Problema con mi impresora codigo u2
Codigo de estado U2 / Sub Codigo 01 AVERIA DE LA MEMORIA
La PWB principal detectó una avería de la memoria
Codigo de estado U2 / Sub Codigo 02 AVERIA DE LA MEMORIA
La PWB (Placa de circuito impresa) principal detectó un error de acceso
Procedimiento para ambos casos
Realice el procedimiento de anulacion del codigo de estado U2:
  • Introduzca el código de diagnóstico 16.
  • Pulse Impresión.
Si todavia existe el problema , substituya la PWB principal.
Aug 20, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
Me podrian dar el codigo de seguridad del nokia 1661-2 IMEI: 352676/04/285835/8
O:
Jul 26, 2011 | Nokia 1661 Cell Phone
_CUAL ES EL CODIGO DE PANTECH215 LIBERAR
El c?digo de desbloqueo de red lo que significa que el c?digo llegar desde el sitio en l?nea, de seguridad El c?digo de desbloqueo significa obtener el c?digo maestro de reinicio del proveedor de servicio y restablecerlo ... El c?digo de desbloqueo gratis no es posible obtener de los tel?fonos antiguos, como Nokia M?viles DCT, pero este tel?fono PDA usted tiene que pagar para el c?digo de desbloqueo, puede obtener el c?digo de aqu? Wickedunlock y desbloquearlo ...
Jul 24, 2011 | Pantech VZW PN 215 Cellular Phone
Estoy buscandao el sensor po 700 y el 846 que puede ser
P0700 - Transmission Control System malfunction
El código P0700 se describe mal funcionamiento del sistema de control de transmisión. Básicamente lo que esto significa es que un mal funcionamiento ha sido detectado en la transmisión y los componentes asociados. Hay buenas noticias y malas noticias. La buena noticia es que podría ser cubierto por la garantía. No aclaró si su vehículo está en garantía, ser conscientes de que aún puede tener cobertura de la garantía en esto desde el coche está a sólo 3 años de edad. La mala noticia es que el código P0700 realmente significa que hay códigos de transmisión específica que no puede acceder con un lector de código de regular. Hay una parte llamada TCM - Módulo de control de la transmisión que funciona en forma similar a su PCM. La medicina tradicional china se encarga de la transmisión eléctrica de "cosas" y que almacena más códigos de transmisión.
Si quieren seguir el tema usted mismo, usted tendrá que conseguir sus manos en un lector de código de fin más alto, o llévelo a su distribuidor o una tienda de la transmisión para obtener los códigos de transmisión real de problemas leer. Personalmente, le recomendamos que obtenga una tienda de leer los códigos para usted. Los códigos de los otros códigos de comunicación, le recomendamos que borre los códigos después de corregir el código P0700 y ver si vuelven, que podría estar relacionado con el tema "principal" de transmisión. La otra buena noticia es la solución para este sólo puede ser una actualización de software que el distribuidor puede hacer.
P0846 -
Trans Fluid Press Sens/Switch A Circ Range/Perf
espero ayudar.
Mar 06, 2011 | 2002 Chrysler Concorde
Mi ipod touch se me deshabilito y no me acuerdo de mi codigo de acceso al ipod y no me lo detecta el itunes como dispositivo
Para ello retire la batería teléfonos y otra vez battery.You insertará el código maestro @ http://wiki.answers.com/Q/Is_there_an_iPod_classic_master_unlock_code_if_you_forgot_the_passw
si el problema persiste tiene que el flash de su teléfono
a parpadear necesita un cable USB, conexión a Internet de alta velocidad,
se puede encontrar software formateo @ http://www.ipodtouchfans.com/forums/showthread.php?t=39550
NO TE OLVIDES DE VOTAR
Jan 13, 2011 | Apple iPod touch
Hola yo quicera saber como puedo desbloquear mi nokia 6120 classic que se me olvido el codigo de acceso y no lo puedo usar grasias
Para el mejor código de desbloqueo para su modelo de móvil,
puedes probar este sitio http://www.mobileunlocksolutions.com/nokia-6120-classic/rs1wp9/
Tiene las instrucciones paso a paso y fácil de métodos para el desbloqueo de sus teléfonos móviles .........
Listen Read phonetically
Nov 11, 2010 | Nokia 6120 classic Cellular Phone
Westinghouse LD-2240 22" LED TV 1920x1080, 60 Hz, HDTV, LED Backlight Logo
648 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
