Question about Sansui Televison & Video
I have a sansui flat with build in DVD but don't have a remote the DVD will load but when push play it says operation not possible with disk what is this do I just need a univ.remote
  • Sansui Master
  • 5,380 Answers
First, check which input you have the TV set on. There may be an Input button on the side of the TV. (On the SLEDVD197, the button just below the DVD Eject button.) Just press Input and use the Channel Up/Down arrows to navigate the menu to change to the DVD. Press Input again to Enter the selected option.
With the TV in DVD mode, try pressing Play again. If you still have the error, check the region code for the disc. The "Operation not permitted" messages is usually that something on the disc is locked. Frequently, it's the result of using a different region code disc than the DVD player knows how to interpret. Try a different DVD.
If your TV doesn't have the Input button on the TV, you absolutely need a universal remote. However, you will want one that can match the TV/DVD button, the Input/Select button and the Menu button. Usually this requires a higher end remote; you also need a remote that was programmed at least 6 months after Sansui released the TV. If you do have the Input button on the TV, a universal remote may make using the TV easier.
I hope this helps.
Posted on Apr 13, 2015
SOURCE: sansui VRDVD4000 format
I do not believe this player plays AVI videos, not to mention whatever codec you are trying to use.
Download VSO ConvertXtoDVD and convert your AVI files to DVD and then burn them to DVD-R (NOT DVD+R), the 4.7GB discs (single-layer).
This process takes a very long time, depending on the size of the movies you are converting, some 1-2 hours, some 8-24 hours.
I suggest buying a Philips DVD Player that plays DivX and XviD AVI files, they seem to be the best. You can just burn the AVI to any disc and it will play. [Most popular seems to be Philips DVP 642]
Cheers.
Posted on Nov 28, 2007
ctf1800
  • 4402 Answers
SOURCE: sansui dvd player with no remote
purchase a generic remote
Posted on Dec 03, 2007
SOURCE: Operating manual
order a manual from orion customer service 800 289 0980
Posted on Mar 04, 2008
SOURCE: hitachi univerdal remote/sansui dvd/vcr player
So do I
Posted on Sep 30, 2008
SOURCE: No Disk
When I try to play a DVD, operation seems normal, the unit makes a slight noise like the disk is rotating and "Loading" is displayed. Then after about 30 seconds the message "No Disk" is displayed. Then just the Polaroid screen is displayed. I have lost the remote control but surely the unit will play using the front panel buttons. One thing, only the remote is named as having a Setup Button in the manual but the unit has no such button.
Posted on Nov 07, 2008
How do I operate the dvd player with a TV or competitor DVD remote
Well you can maybe try and set it up on your setting screen it might take a while but it's worth a try
Feb 01, 2014 | Sansui VRDVD4005 DVD Player/VCR
Hi, My Samsung DVD player remote would not respond when power button pushed on. When DVD power turned on Manually and DVD loaded the remote would not respond to the play, arrow buttons eirther?? My LG...
If the buttons on the case are working but the buttons on the remote don't then it's clearly a fault with the remote.
Each button in the remote is made out of 2 wires on the electronics board that are joined by a small patch of conductive paint situated on the rear of the rubber button. If something gets in there, like water or dirt or the patch flakes out, the contact is no longer made and the button no longer works. The remote will have to be dismantled by popping the clips on the periphery with a sharp tool, the rubber strip holding the buttons will have to be washed and the board wiped clean. If the buttons still don't work after that then the remote is dead, you will have to get another one.
Jul 24, 2011 | Televison & Video
I have lost my remote for my sansui tvm1916a and i want to still use my dvd player, how do i change the imput? pushing the two buttons at once brings up a menu but input isnt an option
If your DVD player is connected to your TV with a SCART cable, your TV should switch to DVD input when you insert a DVD and press' Play'. If you are connected with a standard co-axial aerial cable (fly lead) this wont work and you will need to buy a SCART cable (or new remote) if you wish to continue using your DVD player with this TV.
Hope this helps,
Regards,
BElectric
Nov 16, 2010 | Sansui TVM1316 13" TV
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
No Disk
Apr 12, 2008 | Polaroid PDV-0813A
Vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Oct 09, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD4000 format
Cheers.
Jan 08, 2007 | Sansui VRDVD4000 DVD Player/VCR
Can't get dvd out
Search your manual for "manual open", or some override. Sometimes there is a hole in the bottom of the player that lets you slide a knife in a push the door open a little bit. Should have something written on it, like "emmergency". I can't say it will work after that though. Sansui no longer makes most of the products marked "sansui", they sold the rights to use the brand name. I think orion makes it's basic level TV and Video equipment, and they tend to break after you take a few steps out of the store. Hope it works out for you.
Jun 13, 2006 | Sansui VRDVD4001 DVD Player/VCR
Televison & Video Logo
151 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
