Question about Home
Leaking water at bottom centre both sides atbottom of base
  • john livingstone
    john livingstone Apr 14, 2015
    Thanks Ray will do regards Jock.
    Top Expert:
  • Home Master
  • 51,186 Answers
Call a good plumber your wax seal has gone the trip
Posted on Apr 13, 2015
    Top Expert:
  • 10,875 Answers
Turn off water to toilet,get a new wax ring,unbolt toilet,lift toilet off floor,scrape wax off floor and under toilet put down ring wax side up,set toilet,kneel on toilet not wobbling,put bolts back on,turn on water,if it sounds to hard,it is,call a plumber follow rays answer
Posted on Apr 14, 2015
Water leak on toilet base can`t see leak?.
Try tighting the bolts on eather side, do not over tightene you can break the toilet. If that does not work you will have too remove the toilet and replace the wax seal
Apr 13, 2015 | Cars & Trucks
Water leaking atbottom moter where it bolts up to midsection 89 johnsongt200 leaking atboatside right
As long as it is pumping good and not running hot, this is not a problem. make sure bolts are tight.
Sep 11, 2010 | Boating
F1 error on top and bottom. Power won't shut off until unplugged.
Generally it means the flood switch under the drawer (inside the housing is activated). This means water is leaking from somewhere - foam in detergent, cracked or crinked hoses, door seal leak etc.
To fix, take the drawers out from housing and dry the flood switch located in the centre of the housing base. Need towels and hair dryer.
Make sure the power is turned off.
Jul 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Our Dishwasher is leaking out the sides bottom sides.
The door of every dishwasher has a compressive rubber seal. When you close the door, it compresses to prevent the water lealking out. Yours has perished and a split is allowing the water to leak out. You just need to write down the model and serial number (for good measure) and contact the makers parts supplier. Buy the new seal and install. If you are not confident to try this yourself, a repairman can be booked to do it for you, but it's not difficult, the seal slides into a guide track (at the top internal centre of the door) - the track continues down to the base of the door, across the base, up the other side and when installing, you simply inch it into the guide around the door perimeter until it joins again at the top.
A bit like putting a belt through belt loops...
Apr 07, 2010 | Weber Genesis Silver C Premium Grill
RE: Fischer paykal F1 code
F1 fault means the flood switch on the base of the dishwashers has been activated.
nine times out of ten its the lid motors.
You can remove the two kick plates on the bottom of the dishwasher.
Dry out the water in the base with a sponge.
only one draw will be leaking water??
This allows you to use the second draw until a serviceman shows up.
Dry the base out A.S.A.P, because you have a electronic board that sits on the base. cheers
Aug 04, 2008 | Fisher DD603FCSS Dishwasher
Air Conditioner 3 in 1 danby SPAC12030 leaking water on the floor. No water in right side compartiment also no water in the back reservoir. Water leak from right side of the machine. From the right side...
I had that problem last year. When I took it apart I found that the drainage hoses that lead to the reservoirs were plugged with dust build up. I clean out the hoses as well as the rest of the insides. I have since placed the entire unit inside a shallow (under bed) style rubermaid tote and have not had any more water leaking. Hope that helps you.
Aug 04, 2008 | Danby Heating & Cooling
Home Logo
192 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
