Question about VitrA Aria Toilet with Round Bowl / Backsplash Tank Lid - White
Water leak onto floor at bottom centre at base not wet at topor down sides
    Top Expert:
  • VitrA Master
  • 46,416 Answers
Call a good plumber the wax seal has failed
Posted on Apr 13, 2015
Water leak on toilet base can`t see leak?.
Try tighting the bolts on eather side, do not over tightene you can break the toilet. If that does not work you will have too remove the toilet and replace the wax seal
Apr 13, 2015 | Cars & Trucks
Leaking water at bottom centre both sides atbottom of base
call a good plumber your wax seal has gone the trip
Apr 13, 2015 | Home
What is causing water to leak down onto the floorboard of my 2004 Mazda 6 when I have AC on?
this will be condensate from the fins of the ac evaporator in the car and is leaking onto the floor because the drain on the unit is blocked either in the hose or at the bottom of the ac box
Aug 24, 2014 | 2004 Mazda 6 Wagon
Floor wet in car rain
remove the door trim of the side that has the wet floor and replace the plastic membrane that should be stuck over all the openings in the inner panel. Ensure that the drain holes at the bottom of the door are open and clean and not blocked up.. Because doors are curved the water runs to the bottom of the glass and drops onto the plastic sheet that keeps the water in the door . If the sheet is missing or is not sealing the openings then the water goes to the inside of the panel and leaks inside the door onto the floor.
Nov 01, 2013 | Mazda Cars & Trucks
WET CARPET ON DRIVER'S SIDE
Could be the drain for the ac is plugged up. Usually when this happens the passenger side floor gets wet, but it could be coming out on the driver's side when you take a right turn.
The drain should be on the bottom of the firewall near the floor, you should see water dripping onto the ground when the ac is on.
Jul 19, 2012 | 2003 Buick Rendezvous
Where are the chassis drain plugs on a 2003 Pontiac bonneville? My car leaks in the trunk and onto the floor on the front passenger floor
Your trunk leak most likely is rubber seal that runs the perimeter of trunk when trunk lid is open. Leak on pass floor can be a combination of things. Heater core or if car has sunroof, there is drains that run down windshield posts. Carpet will be wet and sticky if heater core is leaking (not to mention coolant level low) If it's sunroof drain, car has to be put on a lift and drains blown out with compressed air.
Feb 27, 2011 | 2003 Pontiac Bonneville
Ford Fiesta 2003 1.3 If I run the aircon water leaks onto the floor of the drivers side (by the pedals, alot of water.
In the dashboard,set down low is a driptray.It collects water that comes off the aircon.It has a hose (sometimes 2) that drains the water out of the car via the firewall so it drips onto the road.This is blocked or the tray has a buildup of gunk.The hose is about 1/2 inch thick.If you lay on the floor where it leaks with a torch you should find it.Or look in the engine bay,just to the left or right of centre(which side leaks?)and backtrace it into the car.You may find the inside hose has fallen off allowing the water to drip inside.Hope this helps you
Jan 01, 2010 | 2007 Ford F
Our Fisher & Paykel single dish drawer unit (6 months old) is leaking limited water from its base down the front of bottom drawer below the unit's base onto the kitchen floor. One inspection by a...
One drawer leaks can cause this problem. If you don't fix it. One day it will turn on the pumps from both units without any one touching them since the floor sensor at the bottom housing detects water and it will run for ever until you unplug the power cord. This dishwasher is a state of art in design and replacing parts is very simple once a person has enough understanding of its mechanism. If the tech fail to find the problem then he is not qualified to touch this dishwasher. When there is a leak, it is a problem with the lid seal from the top not closing down tightly so during the wash cycle, water shoot up and leaks through the top opening then collecting on the bottom housing of each unit. Let say the top draw is leak, so the bottom housing of top draw if full of water then it overflows to the bottom drawer unit then the floor. Here is the idea of how it happens. The top lid is pulled down by 2 actuators from both sides at first start. That is why you can hear the motor noise turning on at the beginning of the wash cycle. That is the noise from the actuators. If the actuators are bad. only one side works then the lid can not be sealed properly there is a leak. If bothe of actuators are week the gear worn out so they can not hold the lid down during the wash cycle then it can cause a leak. You can pull each tube out and access from the left side at the bottom to touch the bottom housing to fell the wetness. Put in tower to dry them out. If there is a weteness from the bottom housing upper tube it doesn't mean the bottom drawers is leaking. It is wet just because the top is leaking. However you have to dry the bottom in order to continue use the bottom dryer. If you ignore my advice then your circuit board at the bottom housing of lower drawer will be damaged and it is not cheap. With the information that I provided you can interview a tech claiming know about the this type of dishwasher before letting him coming into your house. Good luck.
Dec 28, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
There is a water leak somewhere in my 98 toyota camry that leaks into my passenger side floor. There is no sun roof and no visible leaks from the windows or doors. Any thoughts? A/C leak maybe? water...
I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
Sep 07, 2008 | 1999 Toyota Camry
VitrA Aria Toilet with Round Bowl / Backsplash Tank Lid - White Logo
139 people viewed this question
Top VitrA Home Experts
jasbo
jasbo
woodzowl307
mrbill99
Level 1 Expert
Are you a VitrA Home Expert? Answer questions, earn points and help others
