Question about Refrigerators
Air filter fan not running - Refrigerators
Are there filters in a GU 2004 car air conditioner?
fans run even with blocked filters
probably find that the low speed fan resistor has burnt out or the vent control module is not operational
Jan 06, 2016 | Cars & Trucks
Fan runs but no cool air or any air coming thru ducts
Be sure the "fan running" noise you hear is actually the fan and not just the refrigeration pump. The unit would still make a running noise but the fan may not be turning.
Check to be sure the filter is clean and that all vents are open.
Jul 19, 2010 | Dometic Rooftop RV Air Conditioner
1.5 ton ac. It is getting cold near the outlet but cold air is not blowing out. Instead pieces of ice are sometimes coming out. How to troubleshoot?
Is the fan running? If the fan is running you should check your filter. If it isn't running then you should check the capacitor for the fan and the fan motor. Also make sure the evaporator coil is clean. If all of this is good then get the refrigerant charge checked.
Jun 06, 2010 | Samsung AW0503B Air Conditioner
Indoor air flow slow comiing
Have you checked your air filter(s)? Is the fan running? A weak capacitor will make a fan run slower sometimes. Also try turning the fan by hand while its off and make sure it spins freely. If its hard to turn you probably need a new fan motor.
May 20, 2010 | Heating & Cooling
After cleaning red cell light wont go off
This red light goes on when air purifier needs to be cleaned, also check out whether fan is running or fan is stopped if fan is not running and red light is on then the problem is of filter got wet inside.let the filter get dry then check out.if still the same problem the filter needs replacement. to remove the filter for cleaning or replacement Remove the ESP cell by taking hold of the handles and lifting upwards. and then Remove the Oxygen Plus filter from the unit.by lifting it up slightly. its the filter problem either its wet and needs to be dried out or the filter is got clogged by dust and needs replacement.contact the local service center for air purifier and get the replacement filter.------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Oreck Super Air 7 Air Purifier
Fan running but no heat
It could be the circuit board, relay, heat strip coil or limit. If you have the fan switch at the t-stat in auto and the fan is running constantly it's probably a high temp limit that tripped. Was your filter clean or dirty? If you had a dirty filter and/or A/C coil it will restrict air flow and cause the furnace to overheat.
Jan 18, 2009 | Carrier 38CKC042 Air Conditioner
Connecting electronic air filter to furnace fan
You may need a "current sensing relay" to clip around the neutral wire on your blower.
Run the 120v power to the main power (the power switch- hot,neutral and ground) . Run the Hot wire through the "Current Sesing Relay" wires to the EAC unit's 120v. power input. The unit will only run when the fan is on.
Hope this helps,
Matt
Dec 31, 2008 | Goodman Heating & Cooling
Air filter dirty
It means the Fan is dirty clean off dirt so fan can run,or fan might be bad. More then likely fan has alot of Dust Bunnys.
Dec 01, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Air filter
air filter message is ussally generated by a tempsensor getting hot. could indicat falulty sensor.. is the fan running. a stalled fan could cause the problem but usaally when that happens it completley shuts down
Jan 29, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
