Question about JVC Audio Players & Recorders
When i plug in my jvc subwoofer it keeps blowing the fuse
SOURCE: Subwoofer issues
I have the Onkyo SKW-200 and the fuses are blowing also. Plug it in and the fuses blow instantly. My brother has the same sub and the same thing happened. Our subs only worked for about 1 month before they went out. Do you think it is the power supply?
Posted on Nov 20, 2008
  • 26 Answers
SOURCE: fuse on subwoofer keeps blowing
Subwoofers draw a tremendous amount of power. With the amount of heat generated by amperage flow and the movement of the voice coil, you may have burned out the coil. Do a resistance check across the coil. Easy check? Temporarily attach another speaker to replace that one. Use LOW VOLUME and slowly work the vol up,and, if the fuse does not blow, it's the other speaker.
Posted on Mar 10, 2009
mikeslab
  • 87 Answers
SOURCE: klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Posted on Apr 26, 2009
ravichetty
  • 158 Answers
SOURCE: it keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Posted on Jul 22, 2009
  • 140 Answers
SOURCE: powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Posted on Jan 15, 2010
Keeps blowing fuses
You need to be very specific about your question. When people see "Glow Plugs" one thinks about Diesel Engines and not Car Audio.
Jan 15, 2014 | Car Audio & Video
KLH ASW8 Powered subwoofer keeps blowing 3A-250V fuses
The transistors at the output stage of the sub amplifier circuit might be shorted so each time you power on, the circuit draws a very high amount of current which causes the fuse to blow. It's definitely a problem with the circuit so using a higher current rated fuse would probably just result in damaging the amp even more. You should ask a qualified electronics technician to take a look at it. I hope you can fix it.
Oct 17, 2012 | KLH ASW8100 Subwoofer
I have a cerwin vega subwoofer that keeps blowing the fuse
Take a look at the Voltage selector switch (if one is existing). It may be switched at the wrong position. In that case, I hope that the power supply is not burned out (if it is set at the wrong position).
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 13, 2010 | Cerwin Vega CLSC-12S Subwoofer
Subwoofer keeps blowing fuses.
THE AMPLIFIER "IC" MAY BE SHORTED!
IC MAY NEED REPLACED.
Apr 10, 2010 | KLH ASW10-120 Subwoofer
Powered subwoofer keeps blowing its fuse
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
My subwoofer fuse keeps blowing out , what might the problem be ?
There may be a loose wire inside that is moving from the bass and shorting out when it touches the wrong place inside. Check and see if that's what it is.
If not, try turning the Bass/Volume down some on the Subwoofer so it's not putting so much of a strain on the Amplifier.
Another thing you could try, but it's usually NOT recommended, is to use a fuse with a higher Amperage rating so it's a bit harder to blow.
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | JVC SPPWA670 Subwoofer
It keeps blowing fuses - two 12 inch cls subs 1
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Turn it on and blows fuse replace fuse and plug it in and it blow
You need to have the receiver serviced. The fuse is blowing because some part in the power supply or amplifier section has failed. A service technician will need to troubleshoot the unit to determine what parts need to be replaced.
Jul 10, 2009 | JVC TH-C50 System
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
65 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
