I have a may tag epic z which the lights come on clicks when press start and cancel button but does nothing is my control board shot
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Try inter lock
Posted on Apr 13, 2015
  • lisa zemrose Apr 14, 2015
    I think may be thermal fuse
Coldcut
  • 1554 Answers
SOURCE: Maytag Epic
the control board has loose solder connections around the relays.
see this
diff model same issue with new boards as they make them all.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
being it is in warranty its too early for you to fix it yourself.
you will have to wait for them to come out and say the parts are on backorder.
Posted on Feb 04, 2008
  • 1294 Answers
SOURCE: control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Posted on May 09, 2008
  • 1028 Answers
SOURCE: Whirlpool 9400 Front Loader Washer Control Button Locked
find button with lock emblem beside it hold 3-5 secs
Posted on Oct 09, 2008
  • 26 Answers
SOURCE: Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Posted on Dec 19, 2008
SOURCE: Frigidaire F/L Washer - Delay Start will not reset?
I had this EXACT problem this morning and ended up calling the Sears Home Central Team out (I have an extended maintenance agreement). This is an error code that CAN BE RESET by the end user (you and me!) and doesn't need a repairmain. Here's what you do:
PRESS AND HOLD the START and CANCEL BUTTONS.
The four lights above the START button will begin to flash.
Continuing holding the START and CANCEL button and "spin" your wash selector knob to "SPIN".
Release the START and CANCEL buttons and Press the START button.
This will RESET the error codes within the system and allow you to "cancel out" of the DELAY START.
IF the error codes are "bad ones", then the system will stay locked and you'll need to call a repairman; however, this "fix" should work for MOST of the routine system error codes.
Worked on mine and we're a happy washing family once again!!
Posted on Aug 26, 2009
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
Nov 25, 2012 | Washing Machines
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Have a Frigidaire Gallery Series front loading dryer and it keeps giving me an error(?) code, E68. When I start the dryer, it runs for a couple of minutes and then It starts beeping and flashing this code...
Sorry to read about your problem. this should be your E68 problem
You have a defective button on the control board.
The best thing to do is go into the diagnostic mode.
Turn the dial to Normal. Press and hold the Select and Pause/Cancel keys for 6 seconds, or until the Drying/Cool Down/Press Saver/Clean Lint Filter lights come on.
Then press the Start and Pause/Cancel Buttons 4 seconds. This puts you into the diagnostic mode to check the keys. Now, turn the dial 4 O'clock position, or 75. This will allow you to check all your buttons. As you press each key, it will light all the lights above it. When you press a key and it does nothing or the lights above any certain key stays on without pushing it, this button is stuck. If you can't clear it, you probably have to replace the control board.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Frigidaire Dryers
My dryer when to begin to work stop and show E68 the dryer is gallery series thanks for help me
Dec 21, 2010 | Dryers
The Locked Light is on. I've tried to hold the stop and cancel button, but those aren't unlocking hte machine. I cleaned the lint trap as well. Help
If you are referring to the "Control Lock", this is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button that unlocks it. Using the STOP or CANCEL buttons will not turn the feature off. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Whirlpool Duet or Maytag Epic), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
May 04, 2010 | Whirlpool Dryers
My new Epic Z is only one month old
sounds to me like there is a short in the wiring or control board i would call the warranty company to come fix it
Dec 30, 2008 | Maytag EPIC MFW9700S Front Load Washer
Control locked light on
The button on my Epic version is called the "Cycle End Signal" button.  I pressed it for 3 seconds and the "control locked" light went off and the washer started.  This button is on the far right, just like premm said, near the "Off" button.
May 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic
see this
Feb 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Apr 13, 2007 | Maytag 24 in. MDB5601AWS Stainless Steel...
Washing Machines Logo
Top Washing Machines Experts
