Question about Samsung DMT400RHS Builtin Dishwasher
What would cause The fill valve will not activates
    Top Expert:
  • Samsung Master
  • 44,414 Answers
Well they do burn out
Posted on Apr 13, 2015
My 2004 Hyundai sante Fe will not start after gas fill up, I need to hold gas pedal down and feather the pedal till it stays running.
purge valve solenoid/ purge vent/ purge canister... NEVER TOP OFF GAS!!! ruins evap system and activated charcoal from purge canister enters lines clogging purge valve solenoid, problem often causes fuel nozzle to "click" multiple times while fueling
Dec 22, 2016 | Hyundai Santa Fe Cars & Trucks
Jacuzzi (brand) fill valve. Why does it keep filling?
The flapper is not seating correctly, causing leakage into the bowl. The tank level lowers to a point where the fill valve is activated to restore the tank level to its shut off point and the cycle repeats.
Oct 06, 2015 | Home
Why does the water valves continually pulse?
It's hard to answer such a general question. I will assume your reference refers to a toilet, and that 'pulse' is regards a recurrent slight refill action of the tank fill valve. If this is the case the cause is probably a slowly leaking flush valve. When the tank water level drops enough to activate the fill valve, there will be a slight refill action (pulse) to top up the tank water level. It will repeat until the leaking flush valve is fixed.
Jun 06, 2015 | Home
Hi, the drawer on my tumble dryer is not filling with water and the water light is on, the water must be somewhere....help
1st remove the hoses and check the filters in the hose and in the water valve.
if water valves r open and machine is in fill mode then the water valve is defective.
Timer may not be activating valve but if u can't monitor the voltage on the valve replacing the valve is cheaper than the timer.
Dec 09, 2014 | Dryers
GE Side by Side Refrigerator model GSS25jfpa cc. No water to icemaker. Replaced the ice maker and the dual solenoid water valves. Still no water to ice maker? Water to door works fine.
if you can reverse the solenoid valve wire connections,then use the door water fill to activate this valve,but not long as it will overfill the icemaker,this will certify that theres water getting up to the icemaker,then it could be the maker itself not activating the icemakers water valve assy to fill the maker
Feb 01, 2013 | GE Refrigerators
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
Jun 28, 2010 | Maytag LSE7806A Top Load Stacked...
Cold water fills very slow, hot water is fine
check your cold valve switch inside machine. might be sticking ,slows down water flow , alkali ,hard water deposits may be the cause of most,make sure it is free flowing rod assy . move manually to activate.it is an 1 hour labor min
Mar 19, 2010 | Kenmore 800 7982 Dryer
Washer wont fill enough water
Washers have a (vacum pipe) that feeds a micro switch. The air pressure in the vacume pipe caused by the water filling the washer activates a vacum switch when the correct amount of water has entered the machiene. This vacum pipe could be partly blocked or the vacume pressure switch contacts burnt of faulty. This can be tested by physicaly blowing air by mouth into the pipe and you should hear the switch click.
Jan 21, 2010 | Dishwashers
I woke to water draining from the dishwasher this morning. I looked inside and there was water in the bottom? Help?
when you say you woke to water draining i assume the pump was activated if so you water valve is not shutting completely causing your dishwasher to gradually over fill this will cause your water level switch to activate the overfill stage and bring in your water pump have a close look and if this is the case replace water valve hope this helps let me know how you go
Nov 14, 2009 | GE PDW7380NSS Stainless Steel Dishwasher
Dishwasher does not fill with water
It sounds to me like the base safety float has been activated. This will cause the unit to cancel the program it is in and activate the drain pump, hence the "run" that you hear, but no water. You need to remove the lid and two side panels. If you see water inside the base, you know that the safety float switch has been activated. Remove plug from outlet and empty water from base (by tilting to left side and using sponge to syphon water) Restart unit and check where water is leaking from. Usually from a filling hose not correctly/tightly fitted; leaky inlet valve; leaky heater asembly. Hope this helps! C.
Jun 22, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Samsung DMT400RHS Builtin Dishwasher Logo
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
