Question about Video Game Consoles & Games
The controller wont hold a charge what can I do
    Master:
  • 147 Answers
Xbox controller? Yeah those are known for short battery lifes. You need to just change the battery dude.
Posted on Apr 17, 2015
Why controller wont turn on
the batteries in these controllers are rechargeable yes. But there comes a time when these won't hold charges anymore and that is normal. Thats when you have to replace the controller. with the release of the ps4 i've seen sony ps3 controllers as low as $20. great time to pick up a pair or two or three
Nov 10, 2013 | Sony Wireless Controller for PS3
My dreamgear chargepack works but when I but my sliver remote control in it lights up which means that its charging but when I try to charge my blue control the lights wont turn on. how do I make the light...
I have several controlers in several different colors, but "coincidently" several of the blue colored controls have had the LED lights stop working completely. I am begining to think that many blue colored Sixaxis PS3 controlers were made during a version that had problems with the LED lights going out and no longer working, or simply a bad batch of controlers.
Did you try letting it charge for a while, even if the ligfhts won't light up, then press and hold the PS3 button to check and see if it took the charge?
On my blue controlers, they still charge and still work, but none of the LED lights illuminate anymore.
Solution would be to buy a new controler, or ignore the lights not working.
Sep 20, 2013 | Video Game Consoles & Games
Usb device fully charged
Try pressing and holding down the PS button and see if any menu comes up.
If noting then you will have to contact the controllers manufacture for further assistance. I believe at this point the controller is no longer functional.
Dec 19, 2012 | Sony Playstation 3 (PS3) Console
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My deville has lost all power wont turn over wont unlock doors no power whatsoever but its fairly new battery what could it be besides the battery
You need to check the battery terminals and make sure they are cleaned and have a proper charge. Test your battery and make sure it is holding a charge. See if there is moisture on the battery. If so, it may be leaking or it may have busted. Either way, it won't hold a proper charge. Your battery controls all the power. Make sure your wires are getting current to them. You can check them with a voltage meter. Your battery should hold at the least 12V to work properly. You can also check your fuses. Make sure none is blown. If you have any questions, let me know. I am here to help.
Feb 24, 2011 | 2002 Cadillac Deville
My xbox 360 controller wont turn on and i use the charge and play batteries and when you plug it in it works but when you unplug it does not work.
From time to time the actual charging capacity of the play and charge battery will fizzle out as will regular rechargeable batteries.
If you know someone else with a play and charge ask to use theirs on yours and see if it charges and holds charge when you unplug it.
If it does then you need to purchase a new play and charge, if it doesn't the connection to the battery pack is damaged and more then likely you will need to buy a new controller. Or just keep it wired.
Hope this helps.
-- JD
Jan 12, 2011 | Microsoft Xbox 360 Wireless Controller
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
My controller wont turn on
if you have a charger then try to charge it maybe that should help nif it doesnt then buy a new controller
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
Ps3 controllers wont charge or hold charge so in the middle of a game there is not charge left in controllers. Hardly charge up at all
Have you tried Connecting them to your computer and seeing if they charge.
It might be a problem with your PS3 Usb port.
Otherwise you can try resetting your controller by holding down the reset button on the back for 5 secs.
Jan 09, 2010 | Sony Playstation 3 (PS3) Console
My xbox wireless controller keeps turing off wheN CHARGED
it could be one of many things,
1)battery wont hold its charge
2)if the bottom corners of the battery pack holder are cracked it will keep disconnecting
3)could be controller.
Jul 04, 2009 | Microsoft Xbox 360 Wireless Controller
Video Game Consoles & Games Logo
47 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
