Question about Klipsch Audio Players & Recorders
My klipsch icon sb 1 will not turn on. - Klipsch Audio Players & Recorders
Hi. I have a Klipsch sw-350 subwoofer and my problem is that it doesn't turn on. A fuse checked..and it checked out fine. Are there more then one fuse?
Only 1 fuse. Sound slide the auto turn on sensing circuit is out. Will need to be taken or sent for repair. Contact manufacturer for repair or replace the entire amp. Replace amps are available from sources like partsexpress.com
Oct 29, 2016 | Klipsch Audio Players & Recorders
Asko repair melbourne
it's more likely the amp, which klipsch provides as a complete unit.
Apr 08, 2014 | Klipsch Audio Players & Recorders
Does not recognize optical digital
I know this sounds insulting, but I made this mistake. When you buy an optical cable, it has a protective piece over both ends to keep the cable from getting damaged in transit. I worried for hours that my receiver was broken because the cable wasn't putting through a signal. if it si new cable, it'll have this protective piece, too.
Dec 25, 2013 | Klipsch HD Theater SB 3 Soundbar System
Klipsch soundbar (SB1) won't power on ... green light on power adaptor seems to trip and go off when I power on the SB
I have read that this may be due to the order in how the AC adapter is attached to the sound bar. After some research I found that you need to unplug the AC adapter from the wall and the sound bar and let it sit for about 15min. Then flip the power switch "ON" on the sound bar and connect the AC adapter to the rear of the sound bar. Lastly, plug the adapter into the power outlet.
Feb 21, 2013 | Klipsch Audio Players & Recorders
Klipsch cs500 will not power up
I have klipsch Cs500 has a problem it turn on the green light but screen not on it no sound come out
Aug 25, 2012 | Klipsch Audio Players & Recorders
My klipsch ten inch subwoofer is making a high pitch whinding sound when the sub is turned on
my fuse keeps poppin everytime i put a new one when i turn it on how can i fix dat?
Aug 01, 2012 | Klipsch Synergy Sub-10 Subwoofer Speaker
71 people viewed this question
Top Klipsch Audio Players & Recorders Experts
rhodesworks
Tom Chichester
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
