0281,0288,0238. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
SOURCE: code for sanyo tv phillips universal remote cl034
the code is 0506 Ihave the same remote and tv
SOURCE: I need codes for a phillips tv and a phillips universal remote?
Hi michaeljlent,
There are a number of codes for your remote that correspond to Phillips TV models. They are:
002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
For your reference, here's a web address where all the codes for your remote are listed (along with programming instructions):
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
SOURCE: durabrand tv model#BH2004D need code for GE universal remote
The code for GE universal remote for th Durabrand BH2004D is "0157"
SOURCE: I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
