Question about Grilling
Electrical element quit heating. Light goes on and when dial is turned up on high it will still not heat up.
    Genius:
  • 1,585 Answers
Check element or stat
Posted on Apr 13, 2015
Soft heat warming throw quit
The heating element may have failed.
Apr 16, 2014 | Perfect Fit Industries Llc Home
Control clean light keeps blinking and dishwasher will not function
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Element light staying on
sometimes this is a wireing problem....elements will heat but do they turn orange. if not then the stove may be hooked up like a 110volts..
Nov 04, 2009 | Office Equipment & Supplies
Stove working, broiler working, oven NOT working .. explain pls.
Assumption: This is an electric oven(?).
You seem to be saying that the bottom heating element in the oven is not coming on.
This can be caused by three possible failures: 1. Thermostat (this is the dial you turn to set the temperature); 2. Selector dial (this is the dial you turn to select the mode (broil, cook, etc); 3. the heating element has failed.
My guess is that the heating element has failed (usually the culprit). It is easy to remove.
1. Unplug all power.
2. Unscrew screws at back holding heating element in.
3. Pull heating element out (it may may electrical connection with a jack built into the wall of the oven cabinet or it may have wires you have to disconnect).
4. If you know how to use an ohmmeter, check the element for continuity. It should have some resistance but not MegaOhms.
5. If you don't know how to check, take it to the parts store and let the counter guy check it for you OR just buy a new one and try it out.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | GE Ovens
Jacuzzi tub not heating
O ring set may be required slow job take care
Sep 18, 2009 | Home
Lower oven does not work. Ind. light comes on but no heat
It sounds like your heater element is burnt out. Get a volt meter.unplug the stove.take off the back,disconnet one of the wires connected to the element and test it. It should read aproximately 11 ohms if good. if a high or no readind,the element needs replacing.
Feb 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Zanussi zbf 760 (9 yrs old now)
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
Sep 24, 2007 | Zanussi ZBF360 Electric Single Oven
Grilling Logo
98 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
