Question about Toro Garden
How do I change the belt on a toro proline 32 walk behind lawn mower model 30157
buffalonyman
  • 1865 Answers
SOURCE: Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Posted on Jun 12, 2009
  • 133 Answers
SOURCE: Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Posted on Aug 16, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
SOURCE: I have a Toro self
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Posted on Dec 14, 2011
  • 6468 Answers
SOURCE: how to replace drive belt on self propelled toro commercial push mower
the should be a plastic cover under the engine
Posted on Mar 29, 2012
I need the size of the traction belt for my Toro 6.75 190cc walk behind? Can you HELP
you will need the model, code, serial numbers. get the from the engine and off the frame. take them to your local mower parts store and they can sell you the belt you need, if you have a manual for it that will help with part numbers.
Dec 18, 2016 | Toro Garden
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Oil mixture for 1985f series 2 cycle lawn-boy mower
Contact your dealer ! but 32:1 sounds correct. 8 ounces of Lawnboy oil to two gallons of gasoline ....is 32:1, 8 ounces of oil to one gallon of fuel is 16:1 for the real old lawnboys,
When Toro bought out OMC,and started using Tecumseh mowers,the ratio changed in the late 80's or early nineties ! IIRC :o)
Jun 11, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Proline toro commercial 32 inch won't run
try starting fluid that will see if its a fuel problem then check for spark
Apr 19, 2012 | Toro Garden
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I have a Toro Proline walk behind . Problems with the self propel
I suspect the drive belt, not the Hydro. Especially if the drive belt was never replaced. The belts are known to stretch and wear out over time. It's a cheap part.
Jun 04, 2010 | Toro Lawn Mower With Toro Power Tools
Gaining access to change a drive belt on mower
the belt cover should have screws with the heads on top of the deck, then there is a guide which keeps the belt in the engine pulley with 2 or 3 bolts you might be able ot get it on the gearbox with just those off and a bit of prying etc.
Sep 13, 2009 | Garden
I have an old Toro proline 52 inch commercial walk behind 18hp kohler and I don't know how to put the transmission belt on right.
Simple rule. V of the belt goes in V pulleys
The back of the belt goes on flat or idler pulleys .
It may take several tries but I am sure you can figure it out.
Sep 10, 2009 | Garden
Garden Logo
83 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
