Question about Furniture
Replacement part # 55813 V1A - Furniture
My mitsubishi 55 inch keeps turning its self off
I had this same problem, make sure that the TV is not plugged into a power strip. Also check to see that the sleep timer is not turned on.
Good luck.
Mar 22, 2011 | Mitsubishi WS-55813 55" Rear Projection...
I need to know if a fram ph8a oil filter will work on a 4.0 litre v6 ford ranger 1994
Yes PH8A will work, cross over part# to Group 7 # V1A
O.D 3.78"
HT 2.24"
THD. 3/4-16
will work.
May 27, 2010 | 1994 Ford Ranger Supercab
Trying to replace capacitors in dm module
it is tight, and some what glued in place just pull firmly and straight up. it will come out ok.
Apr 03, 2009 | Mitsubishi WS-55813 55" Rear Projection...
Picture won't hold it keeps flipping over and over
look for dry-joints on the guns and convergence boards
Apr 01, 2009 | Mitsubishi WS-55813 55" Rear Projection...
Ws-55813 mod. green ld light wont stop blink tv wont turn on
The DM modul is bad. Replace all 1000mF/16V capacitors( be careful with the polarity). After replacing capacitors conect to AC power. Waith about 1min. Green flashing will stop. Turn ON tv. The modul is on the raight hand side next to the main board.
Jan 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
DM module removal
Check this link for guidance with pictures about DM board removal.
Thank you.
Oct 07, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Ws-55813 reset light flashes and can not reset
can you tell me if the light flashes constantly without stopping? or does it flash for a minute then stop? Please respond to this same post and I will assist you with the problem.
Aug 10, 2008 | Televison & Video
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Timer Light Blinking
Replace four caps in DM module 1000mf/25v 105 degree...
common repair for qualified Mits tech............T.
Oct 13, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Furniture Logo
791 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
