Question about Toro Garden
How do I change the blade belt on toro proline 32 walk behind lawn mower
  • 6 Answers
SOURCE: i need to change the blade belt on my troy bilt 33 inch walk behind mower
look up on the internet the make and model of your mower and look under diagrams
Posted on May 22, 2009
buffalonyman
  • 1865 Answers
SOURCE: Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Posted on Jun 12, 2009
  • 28 Answers
SOURCE: gaining access to change a drive belt on mower
the belt cover should have screws with the heads on top of the deck, then there is a guide which keeps the belt in the engine pulley with 2 or 3 bolts you might be able ot get it on the gearbox with just those off and a bit of prying etc.
Posted on Oct 03, 2009
harlan301
  • 205 Answers
SOURCE: Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Posted on Oct 13, 2009
  • 3 Answers
SOURCE: I have an old Toro proline 52 inch commercial walk
with ur dikki pemole
Posted on Jul 02, 2010
Oil mixture for 1985f series 2 cycle lawn-boy mower
Contact your dealer ! but 32:1 sounds correct. 8 ounces of Lawnboy oil to two gallons of gasoline ....is 32:1, 8 ounces of oil to one gallon of fuel is 16:1 for the real old lawnboys,
When Toro bought out OMC,and started using Tecumseh mowers,the ratio changed in the late 80's or early nineties ! IIRC :o)
Jun 11, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
My toro walk behind self propelled blade disengages how do I adjust it
No adjustment, ensure no obstruction on drive end of cable, replace cable, probably stretched over time.
Jun 17, 2012 | Toro Power Lawn Mower
Proline toro commercial 32 inch won't run
try starting fluid that will see if its a fuel problem then check for spark
Apr 19, 2012 | Toro Garden
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
I have a Toro Proline walk behind . Problems with the self propel
I suspect the drive belt, not the Hydro. Especially if the drive belt was never replaced. The belts are known to stretch and wear out over time. It's a cheap part.
Jun 04, 2010 | Toro Lawn Mower With Toro Power Tools
I have an old Toro proline 52 inch commercial walk behind 18hp kohler and I don't know how to put the transmission belt on right.
Simple rule. V of the belt goes in V pulleys
The back of the belt goes on flat or idler pulleys .
It may take several tries but I am sure you can figure it out.
Sep 10, 2009 | Garden
How do you replace the belt
this is not easy you have to turn the mower on its side <make sure the carb is down > take off the blade belt guide and look at it the space is really tight and you have to hold the trans with two fingers and then walk the belt on. its hard because the trans is spring loaded to twist backwards to keep the belt tight
Aug 13, 2009 | Toro Garden
Toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
62 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
