Question about Building Materials
I have a 4 garage door system but just one door working. The other 3 doors could not be opened.
The remoter has 4 buttons that control 4 garage doors respectively, but just one button works.
    Genius:
  • 1,585 Answers
Try replaceing rem or try new battries
Posted on Apr 13, 2015
How do you connect the home link garage control to your car & garage?
Things You'll Need
  • Remote garage door opener
Suggest Edits
    • 1
      Turn your Chrysler vehicle off and press and hold the two outside buttons on your onboard opener system. Release the buttons once the red indicator light begins flashing. This will erase any previous codes programmed to your system.
    • 2
      Hold your garage door opener remote two inches away from the onboard system.
    • 3
      Press and hold the button you wish to program on your onboard system and the open button on your remote simultaneously. Release the buttons once the indicator light on the onboard system begins flashing.
    • 4
      Press the training button on your Chrysler's system until the light glows solid. If it does not glow solid, continue to the following steps.
    • 5
      Press the "learn" button on your garage door remote, located near the antenna wire on the back or side of the system, and return to your vehicle.
    • 6
      Press the training button on your on board system, hold it for two seconds and release. Repeat the press/hold/release step two more times and your remote will be programmed and ready for use.
Dec 10, 2011 | 2002 Chrysler Town & Country
On the Liftmaster remote control, there are two smaller push buttons to the left of the large button which opens the door. What are the two buttons used for?
You could program these buttons to operate other garage door openers or to control other devices that work on the same frequency. http://www.liftmaster.com/consumerweb/products/pflHomeConvenience.htm has light controllers that let you turn on or off a light in your home with the garage door opener. You can easily program one of the small buttons to control the lighting system instead of the main button. (Thus the light would be controlled independently of the door opening and closing.)
Single button remotes can be purchased but currently most garage door openers are sold with the 3 button versions. http://www.liftmaster.com/consumerweb/products/pflRemoteControl.htm
I hope this helps.
(In my household, there are 4 garage door openers installed. When three of the door openers were on the same frequency, we could have had each one respond to a different button on a three-button remote. Now two are on a separate frequency so only two buttons have been programmed on the various remotes. (One group opens the house and workshop; the other opens the house and barn.))
Apr 30, 2011 | liftmaster 83lm Billion Code 3-button...
Button in the garage works, but remote will not open or close garage door?
That button on the wall is called a wall control. If you have a wall control with 3 buttons and the light in the control is flashing you need to press the lock button and hold for 3 seconds. Make sure the battery in your remote is good.
Mar 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener remote does not work.I have a craftsman garage door opener manufactured in 1999. The garage door opener remote panel has a green light on and will open the garage door. The remote,...
Make sure the green light in the wall control is not flashing. That locks out the remote. If it is press and hold for 3 seconds the lock button on the wall control. It could just be that your remote has failed.
Dec 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
My remote controls for my garage door opener don't work. The wall switch does work. The batteries in the remotes are new. Any solutions?
If you have the 3 button wall control check to see if the light in the wall control is blinking. If so press and hold the lock button for 3 seconds. If not, your logic board has most likely failed.
Sep 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Where to buy remote control and reset My garage door opener also
To erase the memory of the opener so that your old remote will no longer work you need to locate the smart/learn button on the rear of the motor unit. Press and hold this button for 6 seconds. No remotes will now work.
To program the new remote when you get it, hold the button down on the remote and then press and immediately release the smart/learn button.
Call any local door opener repair company from the yellow pages and you should be able to buy a remote from them.
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a 3 stall garage with two garage doors, we also have 3 garage door openers. When I push the button on one opener both doors open or close. How can I fix this?
You will need to clear the memory of both openers by holding the smart/learn button in for 6 seconds. After doing this none of your remotes will work but your wall control will. Now you need to program the openers making sure you don't program any remotes for both doors.
Dec 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Model 139.53684 Security+ Keyless Entry Garage Door Opener... Green light flashing on door control push button. Remotes no longer work. Can open and close garage door from keypad. Why is light...
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote control for garage door suddenly stopped working.
Press and hold for 3 seconds the button on the wall control with the lock icon. There you go.
Nov 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote
It sounds like the lock function has been toggled on. Press and hold the button on the wall control with the lock icon for 3 seconds. This will toggle that function off.
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
54 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
