Question about Sony Audio Players & Recorders
Can't switch from tuner to photo on Sony str gx50es
Behind the switches perhaps has bad connections on the front panel pcb
or the switches need taken out and apart and cleaned a tricky job
i do all the time in studios
so you need to take this unit as it quite old and a decent sony to a dealer or the local tv repair man
and have him solder it up and clean it etc
and replace any capacitors it needs changed out.. also
cost i think about £50 to restore fully
or diy = £0
Posted on Apr 13, 2015
3 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: I need to turn the
Possible that the preamp is faulty and so the power amp is not able to deliver the sound.
it will be good to check the input through to the power amplifier with a audio signal test, you can now confirm where the missing amplification is ,even start from power amp will be good enough.
Posted on Sep 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: Sony STR-DE845 5.1 Receiver, No Sound
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 21, 2011
How do I set up receiver
HI YES YOURE GOING TO NEED A FEW RCA CABLES u. can use video 1 to plug youre tv in and use video 2 to plug in youre vcr ::::::::::connect youre speakers up to the red and black speaker terminals marked L & R..good luck
Jul 26, 2015 | Sony STR-DB1070 Receiver
Str-de985 humming noise only when using FM tuner. Everything else works fine with no humming noise
Have you got a FM Antena hook up to it for the FM ,Sations, If not that could be causeing it to hum.
Dec 06, 2012 | Sony STR-DE985 Receiver
I have sony trinitron wega t.v and when i plug in to switch on.. Light does not come, no sound. Nothing. is it repairable.
hi,
yes , it is reparable. ur tvs smps power supply have some problem. check th fuse first. also check the over surge protector MOV is short or not. also check the STR power drive in the power supply. just relapse. below is the photo of MOV and STR. if u repalce the STR also try to replase the opto coupler also. added the photo of opto coupler.
ok
Jan 06, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I need to turn the volume knob to the MAXIMUM on my Sony STR-GX50ES receiver to get just a whisper of sound.
Sep 28, 2010 | Audio Players & Recorders
Can't change FM input mode! Stuck at analog...
Tuner is only analog. As for the Video 1 input you need to go into the menu and change it to the digital port you want to use (optical, coaxial or HDMI) you can set only one input to each digital input port.
Nov 30, 2009 | Sony STR-DE597 Receiver
My Sony STR-DG500 wont turn on just clicks once and nothing.
Sounds like faulty psu (pwer suply unit) Amp is going into protection mode. Disconnected all speaker and av wires (only power) turn up volume and see if it stays on. If not psu, sounboard or volume function faulty. If on, connect one speaker L or R. Go to tuner mode to tuned radio station an listen for sounds. If on, connect speakers and av cables one by one and test each one on its own until amp switches off, Investigate from there were problem is. Make sure speakerwires is not shorting out.
Aug 29, 2009 | Sony STR-DG500 Receiver
When iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Jul 09, 2009 | Sony STR-DE325 Receiver
Sony receiver does not change components
Check to be sure that none of the buttons are stuck on. With the unit off, press each of the buttons. You should be able to feel the button engage. If they all feel like they are working, the internal switch itself may be shorted in the closed position.
Update this with what you find.
Dan
Aug 18, 2008 | Sony STR-DE197 Receiver
66 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
