Question about John Deere Garden
My John Deere 35 starts runs for a little bit sometimes and shuts off
    Sergeant:
  • John Deere Expert
  • 187 Answers
Tracking down fuel problems.
  1. Make sure there is plenty of fresh fuel in tank. High Octane less than one month old. Water in the fuel system will often cause hard starting, low power, backfiring, surging or stalling
  2. Is there a cut off valve at the gas tank? If so check that it is open or working if it is electric.
  3. This step comes from repeated personal experience with JD gas tanks. Remove fuel line from filter and remove the filter, gas should pour out of the hose coming from the tank. (look at the filter before removing it, it should look at least 1/2 full of fuel.) If gas does not pour out remove gas tank cap. If fuel flows now, you need to unclog the cap vent or replace the cap. The vent is that tinnnny little hole in the center of the cap. If the fuel still does not flow then blow air from the filter end of the hose back up through fuel line to blow out any blockage inside the gas tank.
  4. Consider my own experience when my engine to quit in the middle of a mowing job: I was mowing along on my LA145 (200 hours on it) when it slowed down and died. Before it died, it acted like it was losing power. It thought it was only firing on one cylinder. I waited about 20 minutes and it restarted after a lot of cranking and some priming. I made a couple more mowing passes; the same thing happened again.
    I knew this mower was in top running condition. There were no engine misses, no backfires. It was not abnormally hard to start. The carburetor was clean, the coils were good, the plugs and fuel filter were recently changed. Lifting the hood, I noticed the fuel filter was nearly empty. It should be ½ full, or more. I pulled the hose off the tank side of the fuel pump and saw there was no fuel flow.
    Gas should gravity flow from the tank to the fuel pump, if the tank has a good supply of fuel. I wiped the hose off and blew air back into the fuel tank. It helps to take the gas tank lid off first. After I got a good flow of air going back into the tank (you can hear the bubbles) the fuel began to gravity flow back through the hose at a decent clip. This fixed the problem. There is likely silt build up in the tank and it settles at the output port blocking the flow of fuel.
    The problem repeated itself several times last summer. Back at the shop, I used compressed air (turned down to 20 psi) to blow the line clear. The problem reoccurred this spring. I used the same method to clear the line.
  5. Do your self a favor, leave the gas cap off and turn the outlet air on your compressor down below 20 psi. If the tank is nearly full you will blow gas out of the tank. Do this outside if possible; at the very least you need a well ventilated area. After blowing air from the air filter back to the tank, you may have to reverse the process and pressurize the tank to get the fuel started. I place my hand over the open tank and hold the air hose between the joint of my thumb and forefinger to seal the tank, and then squeeze the trigger. Once you have a good fuel flow out the line to the filter, put on a FRESH FILTER. Try cranking the engine. If it still does not start move on to the fuel pump and carburetor
  6. Check the fuel pump. The fuel pump system on the twin Koehler and the Twin Briggs (and others) are almost identical. Watch this excellent, eight minute, video to learn how to check the fuel system, including the pump, up to the carburetor. . Small Engine Repair Checking Vacuum Fuel Pump Fuel System on Kohler Twin...
  7. Note: My engine was starting hard and dying in the field this year (March 2015). While doing a valve adjustment, I found a hairline crack in the bend of the vacuum hose powering the fuel pump. It's the short hose running from the valve cover to the fuel pump. The fuel pump will not work if this hose is cracked.
  8. Many systems have a fuel shut off solenoid. This is a small cylinder on the bottom of the carburetor. It has two wires running to it. It should make an audible click when you turn the key on. If it does not click you will have to replace it or track down an electrical problem.
  9. If this has not solved the problem you may have to remove and disassemble, clean, or rebuild the carburetor at this point. You may have water, dried fuel (varnish) or trash in the carburetor bowl. Before removing and disassembling the carburetor try draining the bowl. Or, take the bowl off, careful not to drop the small parts inside. Clean the bowl and replace. I often remove the bowl on small engines and save the hassle of a complete carb removal.
NOTE: Connect a volt meter across the two battery posts. If battery voltage drops below 9 volts when cranking or while the engine is running, the fuel cut off solenoid will not function. That means the engine will not start or will die soon after starting. So check your battery voltage before, during, and after cranking. If the battery voltage is good before but drops below 9 volts while cranking this is generally a sign the battery has one or more bad cells. Replace the battery. If the battery is in fact good, and the voltage is still dropping, you may have a bad starter motor which is drawing too much amperage.
If you find this fuel checkup does not solve the problem, repost your question with updated info and I will walk you through the next step. Tracking down a spark problem; yes, your problem could involve the coil or any part of the ignition/spark system. (Not as likely as fuel)
Posted on Apr 14, 2015
  • John Deere Master
  • 2,478 Answers
Unhook fuel line from carb. Should have fuel. If not screw off fuel cap,fuel may start running. The cap vent may be plugged.
Posted on Apr 13, 2015
    Genius:
  • 1,585 Answers
Change fuel filter also air
  • Chris Apr 13, 2015
    I've already changed the fuel filters and everything
  • tom cassidy
    tom cassidy Apr 13, 2015
    sorrie cant help
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
buffalonyman
  • 1865 Answers
SOURCE: John Deere L118 / 22hp Briggs stalling when it is hot
Have you replaced the fuel filter?
Posted on Aug 08, 2009
SOURCE: john deere runs then stops
I fixed my mower stalling issues on the L111 by loosening the gas cap. I ultimately drilled a hole in the gas cap and screened the hole. Sounds ridiculous but without that venting the engine would run approximately 20 mins and die. It was also much more difficult to start the next time. Something else to pass along to whomever might view this... I replaced the cranking battery with a battery that had allot more cranking amps and I no longer had hard start issues ( this was after I vented the gas cap). Hope this helps.
Posted on Aug 11, 2009
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
wireguy212
  • 1627 Answers
SOURCE: john deere 2210 keeps stalling/
If you have already replaced the fuel filter then you need to check the fuel tank to see if it has debris in it that is restricting the fuel to the filter.If you are not having a fuel delivery problem then you may need to replace the rubber fuel lines,they may be sucking in air,you will not see this as a fuel leak because of the vacuum on the lines but air in the return lines will cause problems and also air in the delivery side of the fuel will also give you grief.
Posted on Jul 27, 2010
Will start and run then it will die sometimes like you shut switch off other times like it is running out of gas.
Strip carbs they could be filthy and a jet slightly blocked also check there are no bits in fuel tank if so you need to get them out otherwise it will just keep happening. if this is the problem I would put a little fuel filter in it will stop muck reaching carbs and they are good for a thousand miles on a bike not sure on tractor though, Hop you solve your problem.
Apr 06, 2016 | John Deere 325 345 Tractor Service Pricing...
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
My John Deere srx75 was running good I shut it off and now can't get it restarted. The battery is fine and when I turn the key there is no sound at all.
Hold key in the start position and move or wiggle the transmission lever a little; you'll hit the sweet spot and it will fire!
Sep 08, 2010 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John Deere L2 150\r\ntractor is running hig or
Check to see if return spring has broke or came off.
If just stuck sometimes a little wd-40 goes a long ways.
Jun 05, 2010 | Garden
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
Lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
May 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
156 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
