Whats causing shaky picture after about 30 minutes
  • 1,602 Answers
This is a shorting out or a capacitor blown, what i mean when the capacitor builds up it charge and when the capacitor discharges it shorts across another circuit and shorts out the unit this may be the warm up or delay. depending how long you have had it,WARRANT IS WHAT i would check first, if no warrant is call tv repair man ask what cost to repair, troubleshoot, parts cost, labor per hour, see if it is cheaper to buy new one vs. old one
i think you'll find it would be cheaper to buy a new and better option lcd lead tv
Posted on Apr 13, 2015
2 Suggested Answers
SOURCE: Shaky/Unstable Picture
This is power supply issue, one or more of your filter capacitors either bursted and/Or over heats (this is why it becomes better when system cools down after turning it off for 1/2 hour..You have two choices.1. buy a replacement power supply may set you back a couple hundred dollars but it will be plug and play. 2nd you can replace these filter capacitors make sure the can handle 105 deg celsius not the 85 deg. celsius, if you know how to trace the bad ones and desolder and solder new ones on the power supply board, or hire a techinician to replace them for you. Good Luck...
Posted on Feb 06, 2009
The picture on our Toshiba 50H82 rear projection tv is shaky, any diy solutions for this?The picture will sometimes clear up after about 30 minutes. Can this be fixed? The sound is fine, it's just the...
Thats almost always caused by the surface mount capacitors which get weak on the hyper board. Hyper boards are going to be hard to find. But the capacitors can be replaced which will usually solve the issue. However it will require precise soldering skills to do the repair.
Oct 06, 2011 | Toshiba 50H82 50" Rear Projection...
When I first turn on the TV the picture is messed up sometimes it shows a double picture.If I turn it on then off and back on again the picture is fine.Whats wrong? My second problem is that when I turn on...
Ur tv covergence board it is dying.Tv are developing a convergence picture problems.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it dying must require replacement like 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 30, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Shaky picture AKAI PDP4298ED1
THERE MAY BE SOME CONDENCER LEKAGE SOMEWHERE IN THE HORIZONTAL SECTION
Mar 23, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Anyone know why the picture would shake slightly
Does this tv have hdmi input and if so does the problem exist there?
If so I suspect the av input board could have a problem.
Mar 03, 2009 | RCA HD52W58 52" TV
Dec 14, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Shaky distorted picture first 5 minutes when tv turned on.
Those have a problem with the capacitors going bad in power supply. Yes, it's worth having checked out because a GOOD shop will be able to fix the problem and not have to change a board. Very common problem with these sets. Mine did the same thing until I fixed it. Just do your homework when finding a shop. Call around and talk to other people in the area to see who they use etc.. Good luck. Could be a very simple repair. Have it checked.
Dec 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Picture won't come in clear until TV "warms up" for 15 minutes or more
Change the capacitors first per the instructions in the link below. Symptoms could be anything from high-pitched hum to no picture at all. On these defective models, I would start at the caps and work back. It won't hurt to replace them anyway.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Aug 28, 2008 | Polaroid FLM-323B Television
Extremely loud fan...shaky picture
I would suggest to replace the fun to keep the light running cooler, the reason you loose the video after a period of time is because the fun is not providing enough cooling.
If the fun is noise it means the bearings inside of it are not working well anymore.
Let me know if you need more help.
Feb 21, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
LAMP IS GOOD, THE PICTURE IS SHOT
First do self diagnosis and see what error code you get then we go from there.
Dec 16, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
