Question about Eclipse Fit Clip Plus 8GB* MP3 Player
I have it set to shuffle but it always starts with the same song and plays music in the same order.
6th gen. nano has shuffle issues. plays same song over and over
The iPod's shuffle feature lets you randomize playback of albums, songs or even your entire music library. You may also find this feature useful if you want to listen to forgotten tracks in your library or discover songs you haven't listened to yet. Disabling the shuffle feature will return playback of a song list to its standard consecutive order. You can enable and disable the shuffle feature at any time.
Navigate to the main menu. Select "Settings." Scroll to the "Shuffle" option. Select "Songs" or "Albums." If you select "Songs," the iPod Classic will shuffle the songs on whatever song list you listen to. If you select "Albums," the iPod Classic will play all songs of an album you select in order and then randomly select another album. Navigate to the playlist or album to which you want to listen. Play a song to initiate the shuffle. b> iPod Nano and iPod Touch Tap the "Songs" icon on your nano home screen. If you are using an iPod Touch, open the "iPod" application. Navigate to the song list, playlist or album you want to play. Tap the "Shuffle" icon at the top of the list to activate the feature.
Feb 12, 2013 | Apple MC526LL/A iPod Nano 16GB - Silver
My ipod touch will not play in shuffle mode plays a couple of tracks then stops
you might have reset to shuffle again
Feb 11, 2013 | Apple iPod touch
How do I turn the shuffle off?? I go to settings, choose music options, choose shuffle and highlight "on" and nothing I hit makes it change to "off". Help!!
For the Sansa Fuze, the selection Shuffle Mode is correct, just like you told:
In Main Menu > Music > Submenu > Music Options > Shuffle Mode:
1. Select Shuffle.
2. Use thumbwheel to choose Shuffle on or Shuffle off.
(to play songs in random order, set Shuffle to ON).
3. Press Select to change the Shuffle mode.
See page 9 (=page 6) of the manual in pdf format for the Sansa Fuze:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Thumbwheel: 5
Select button: 9
Jan 07, 2010 | SanDisk Sansa Fuse MP3 Player
Shuffle does not play all songs
FIND AN OPTION ON THE IPOD THAT WHEN YOU SHUFFLE SONGS, IT'LL ONLY PLAY IT ONCE. i'm sure there is an option there on the audio options,.
Jul 23, 2009 | Apple iPod touch
Shuffle in a loop
The suffle playlist you have it on is probably only one album or artist or genre - from the main menu go to music and the last option is browse music - go here, press on the first song and it will play through your entire library. Every time you start it when you do this the song should start where you left off.
Hope this was helpful =)
SEE ---> Adrenaline Junkie
May 15, 2009 | Samsung YP-S3JAB Digital Media Player
Sylvania SMP2002 Shuffle?
how do i play the songs on my songs on my sylvania smp2002 mp3 player because it wont play
Mar 09, 2009 | Audio Players & Recorders
Loaded music in mp3 thru windows media but still in shuffle mode
try formating the mp3 player and then get the new frimware for it and the putting the songs back on there were did you get the song from
Dec 17, 2008 | Philips GoGear SA178 MP3 Player
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Aug 07, 2008 | Insignia Sport MP3 Player
Unknown shuffling
well when you add songs to your mp3 player it will auto shuffle just go to your settings and go to music click that and it should go back to ABC order
Feb 29, 2008 | SanDisk Sansa e200 MP3 Player
Audiobook download
Playing Songs, Audiobooks, and Podcasts on iPod shuffle iPod shuffle allows you to play your audio files in a couple different ways—you can play songs, audiobooks, and podcasts in the order in which they appear on your player, or let iPod shuffle work its namesake magic for you (that is, shuffle the files by playing them randomly).
Show Me How
If you want iPod shuffle to play audio files in the order in which they appear on the player, move the switch on the top of the iPod shuffle to the play in order (circular arrows) position. If you want iPod shuffle to play songs in random order, move the switch to the shuffle (crossed arrows) position.
ip02_playfnky_04_shuflebutton.gif This iPod Shuffle is set to shuffle.
To play music, an audiobook, or podcast, just press the Play/Pause button. To skip to the next song (or a different song if you're in shuffle mode, or a different chapter if you're listening to an audiobook or podcast), press the Next/Fast-forward button. To fast-forward through the audio, hold down the Next/Fast-forward button. To go back to the beginning of a song (or the previous chapter), press the Previous/Rewind button; press this button twice to go to the previous song or hold it down to rewind through the file.
To stop play, press the Play/Pause button during play. To turn off iPod shuffle, move the switch to the Off position (you shouldn't see green beneath the switch).
Jan 24, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Eclipse Fit Clip Plus 8GB* MP3 Player Logo
124 people viewed this question
Top Eclipse Audio Players & Recorders Experts
henrysmooth
Level 1 Expert
Joseph Hoffmann
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
