Question about Radio Communications
How do I pair my blue to my hearing aids. Blue recognizes the devices and says connected but its not.
    Top Expert:
  • 6,702 Answers
Iphone is picky when you want to connect bluetooth. Make sure your hearing aids are compatible with the iPhone. to learn more about bluetooth and the different protocol stacks, read here:
http://en.wikipedia.org/wiki/List_of_Bluetooth_protocols
Posted on Apr 19, 2015
4 Suggested Answers
  • 14 Answers
SOURCE: Pairing a motorola n136 with a lg vx5500
your phone probably is not capable of syncing into that kind of blue tooth, if not go see your cellphone dealers store they will help you.
Posted on Jan 10, 2009
  • 3 Answers
SOURCE: My H710 headset will not enter pairing mode.
Try this- first,make sure on your phone, that you have checked that bluetooth is on. You do not need to also check the box to make visible with other devices.
Then-try this, (I got mine to work (I had same problem). On headset, close boom, hold center button (and it turns pink). then, while keeping center button depressed, open boom- light remains pink. Then look on phone, and hit Add new device-- and bingo, it should be recognized now!! You'll be asked if u want to pair w/ Motorola-- and led through the process--follow those steps.
I had tried similar earlier, but the trick was to keep the button depressed, and then open the boom. I can't quite remember if I kept button depresed until I also pressed Add new device on phone or just until after opening the boom and the light stayed on ... Sorry I can't be exact; I was too excited. Hope this helps you get yours working!
Posted on Jan 02, 2010
supernova278
  • 1932 Answers
SOURCE: Trying to connect Plantronic 220
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
Posted on Nov 10, 2010
How can I pair my resound hearing aid with my iPhone Bluetooth?
Your hearing aid must be blue tooth compatible or you must have a streamer (usually designed to wear on a lanyard) that will connect to your Bluetooth on the iPhone.
First make sure your hearing aids or streamer is turned on.
Go to the Settings icon on your iPhone and click on it. Scroll down to Bluetooth and make sure it is turned to On, then click on it.
You will see a list of Devices that your iPhone senses in the vicinity. Your hearing aid or streamer should be recognized there.
If it is not, then turn the hearing aids or streamer off and and back on again and it should show up. Click on the device under My Devices. If it asks your for a pairing code, 0000 is usually the default. It might also be 1234.
That should do it for you. Enjoy!
Sep 10, 2017 | Cell Phones
I am trying to pair the jwin JB-TH130 with a MyTouch 4G cell phone and the phone will not recognize the bluetooth device.
You have to put your blue tooth device to discovery mode usually you hold the power button down for 6 to 10 seconds when turning on you blue tooth device then you will have to make sure to turn your blue tooth power on in you menu then you can add or search device once they pair you will need a pairing pin code .Most blue tooth device manufacture use a factory pin pairing code they are as follows 0000,1234,9999,or 1111 i hope this helps
Feb 19, 2011 | Jwin JBTH130 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
I WOULD LIKE TO SET UP A BLUE TOOTH CONNECTION
Take care.
Aug 20, 2010 | LG Shine CU720 Cellular Phone
How to connect a blue tooth with cell phone
HOW TOCONNECT BLUETOOTH
Take care.
Aug 08, 2010 | Cell Phones
How to connect sony ericsion w395 via blue tooth
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
BlueAnt pairing with iphone...help
Just got off the phone with Apple and Blue Ant tech support.
If everything is workon g on both devices you probably need a memory dump on your headset.
1. Power off both devises
2. Power on iphone
3. Power on blue Ant - not in pairing mode - you should see 1 blue blinking light on MFB
4. Make sure iphone bluetooth is on and searching for devices
5. On Blue Ant, hold both volume buttons and MFB at the same time until you get a fast blinking blue light.
6. Check iphone it should now recognize device.
7. When Blue Ant shows up on phone press it so it completes the pairing priocess
Jun 24, 2009 | Blueant Z9 Wireless Headset
Headset no longer working
You need to remove the device from the phone directory. Turn off the phone and the device. Wait about a minute then turn on your phone. After the phone is ready for use, turn on your bluetooth and proceed to pair the device with your phone. The phone should recognize the bluetooth and you'll be able to add it once again to your list of blue tooth devices.
Jan 02, 2007 | Motorola Mobility HS850 Consumer Headset
Radio Communications Logo
225 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
