Question about Beko TLDA662
Removed water filter to wash and cannot remember how to re-fit. Diagram in manual doesn't clearly show order to put parts back together.
can you please post some pics of all the filter parts that need to be put back together to get an idea what type of filter it is ??
Thanks
G Man
Posted on Apr 28, 2015
How do i get my filter out of my bush a127ldw washing machine got E03 error am working my way through your list but cant get filter out
Water inlet filters
On the tap part of your machine's water inlet
hose and at the ends of water inlet valves, there
are filters to prevent entrance of the dirt and
foreign materials in the water to the machine. If
the machine is unable to receive sufficient water
although your water tap is fully opened, these
filters should be cleaned.
x Remove the water inlet hose.
x Remove the filters found on the water inlet
valves by using a pincer and wash thoroughly
with a brush. (1)
x Clean the filters of the water inlet hoses
located on the tap side by removing manually
together with the seal. (2)
x After you clean the filters, you can fit them
the same way as you have removed them.
Pump filter
The pump filter system elongates the life of your
pump, which is used to drain the dirty water. It
prevents lint to enter the pump. Cleaning of your
pump filter in every 2-3 months is
recommended. To clean your pump filter:
x Open the kickplate's cover, by pulling the
handle. (2-A & 3-A)
x Before opening the filter cover,place a cup in
front of the filter cover to prevent flow of the
remaining water in the machine.
x Loosen the filter cover by rotating it counter
clockwise and drain the water. (4-A)
x Remove the foreign materials from the filter.
x Check for the rotation of the pump manually.
x After you have cleaned the pump, fit the filter
cover by rotating clockwise.
x Put the kickplate cover into place.
x Do not forget that if you do not fit in the filter
cover properly, it will leak water.
Jan 21, 2013 | Washing Machines
How do i put filter bag on dolphin
Here is a copy of the users manual for these pool cleaners. Page 7 has step by step instructions for putting the filter bag back on after washing it. There is also a detailed diagram on the last page that shows how the whole cleaner fits together. I think this should help you out.
http://www.backyardcitypools.com/images/smartpool/Dolphin-3002-Manual.pdf
Jul 20, 2011 | Dolphin Maytronics Diagnostic Robot...
The top part (not the fabric softener cup) of my Roper top loading washing machine came out when I took a blanket out of the machine. I tried reassembling the agitator, but, it doesn't fit correctly. ...
If this is the split agitator (two piece), the top part should not come off without tools. The part of the agitator that receives the fabric softener dispenser has a clear plastic cap that comes off to reveal a bolt. If this is the piece that you have described, something broke.
The bolt in the picture must be removed to release the upper agitator from the machine.
Is this the part that came off? If so, the bolt came off or the upper agitator is broken.
Jul 11, 2011 | Roper RAS8445KQ Top Load Washer
Hello, I have a RCA 61" M61WH74S rear projection
I am not sure which fan you are putting back as there are a couple. I am attaching 2 pics that show the fan locations. You may want to get the service manual for your model which shows the dissassembly proceedures. You can get it on page 2 of the service manual catagory from www.tvrepairworld.com by download within minutes of ordering service manuals are indispensable when serviceing a Television.
Jun 14, 2011 | RCA Televison & Video
When the washing machine is started it shows PE on the panel and nothing happens
PE error.
Pressure sensor error. Cause: the sensor switch assembly is out of order.
Check the pressure switch -the system that determines correct water level in the drum.
If its giving an incorrect indication to the program timer machine will either overfill, refuse to fill or refuse to spin.
Its an air operated diaphragm switch triggered by rising air pressure induced by the entry of water into an airtight vessel attached to the base of the drum.
It tells the program timer that the water has reached the correct level, allowing it to proceed to the water heating stage in the cycle.
Power off.
drag machine out onto the floor.
remove back cover and top cover.
The pressure switch is a round item about 3 inches across with several wires and a thin rubber pipe attached.
It generally sits just under the top cover. Disconnect the thin rubber pipe from the switch and blow down through it to clear any blockage.
Switch itself may be faulty but its more likely the pressure pipe or the vessel attached to the other end of the pipe is blocked.
Some machines have the pressure vessel integrated as part of the filter unit, with a pressure chamber moulded into the top of the filter body.
Remove the pressure vessel, put a small nut or screw in it, fill it with water and shake vigorously till any crud or residue is removed.
Refit all parts, check that joints and connections are water tight.
Also check the filter itself - generally located behind a panel at the foot of the machine.
Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine.
Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction.
Some hotpoint, indesit and ariston filters are located in the big black sump hose
(the one that leaves the bottom of the outer drum and connects to the pump).
Power off.
remove back cover or tip machine up at an angle.
Locate sump hose, remove the tensioner clip by squeezing the tabs together with a large pair of pliers or vise grips.
Remove the hose.
Take out filter and clean. Be prepared for spillage of water.
May help if the machine is tilted backwards at an angle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 16, 2010 | Whirlpool Washing Machines
Dyson animal is giving me fits
Try this quick repair and see if this fixes your Dyson in terms of not going in the upright position: This is a frequent problem that we see come in on Dysons. If this doesn't fix it, please feel free to just use the clarification request and let me know this didn't fix it. The suction problem is happening because when the machine is put in the upright position it diverts the suction from the floor to the hose automatically, and it's probably stuck in between the lower part and the hose part.
Step 1.
Turn power off and unplug the machine.
Tilt the machine backward to a 45° angle.
Step 2.
  • Hold the section under the airway inspection pipe.
  • The black forward lock button must be held down simultaneously, otherwise the valve carriage will not move.
  • Pivot this section upwards until it clicks into place.
  • Release the black button once the valve pipe carriage is moved up into place.
    Step 3.
    • Tilt the machine forward.
    • The cleaner head should now slide underneath the part you have just clicked into place.
    • The machine should now stand upright.
    In terms of the machine not picking up, this could be caused by a few things.
    The first thing you should check is the filter. The DC14 has a motor filter that is recommended to be washed every 90 days. Here's how to access this filter:
    • To remove the washable filter: Remove the clear bin; and cyclone top from your machine by pressing the cyclone release button.
    • Lift clip to remove the filter from the machine.*
    *The post-motor filter located under the clear bin should last the lifetime of the machine and does not need to be washed.
    There are two different types of filters that were used on the Dyson DC14, and One part filter, and a two part filter. Here's instructions on how to clean both of them:
    ONE PART FILTER:
    • Wash the filter in cold water only. (Please do not use detergent, do not wash in a dishwasher or washing machine).
    • Repeat the steps shown below until the water runs clear.
    • Leave to dry in a warm place for 24 hours. DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame.
    • Please ensure the filter and filter case are completely dry before refitting into the machine.
    1_part_filter_drying.jpg TWO PART FILTER:
    • Wash the filter in cold water only. Please DO NOT use detergent on the filter, or wash the filter in a dishwasher or in a washing machine.
    • Leave the filter to dry in a warm place for 12 hours, until completely dry.
    • DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame.
    The filter should be washed at least once every 6 months.
    Also, since you have removed the bottom plate, a common problem on the Dyson's is when this plate is reinstalled. It is very easy to put the plate on incorrectly, which prevents the brushes from hitting the carpeting. This can seriously decrease the pick up on carpets. Check the bottom plate to make sure that it was put back on properly. Here's pictures of both the correct, and incorrect way to reinstall the bottom plate:
    Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
    Here's another picture, that is the RIGHT way to install the soleplate:
    I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
    I hope that this was helpful to you. Please feel free to use the Clarification Request form here on Fixya if you have any questions.
    Thank you,
    Chris J.
    GoVacuum.com
    May 01, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Fabric softner still in draw when wash finished
    There is a blockage in the dispenser that is causing the prob.
    Remove drawer from dispenser, and thoroughly clean every part of it, taking all the pieces out to do it.
    To test it is working, put it back together, and before you put it back in, fill the conditioner compartment with water until it starts to overflow, turn water off, and the remaining water should continue to run out, until it is empty, if it does not , then it is still blocked.
    Plz rate my solution.
    Thanks.
    Jan 04, 2009 | Washing Machines
    Hotpoint WT540 1400 spin. Flashing Rinse hold and Mini load LED
    Had exactly the same last week - Jan 09 - and had to call out Hotpoint engineer - £99.98 all inclusive of parts - it was the main controller board, so thats under guarantee for another 12 months. all working and spinning as should be and only took around 30mins.GS :)
    Dec 29, 2008 | Hotpoint Washing Machines
    Does anyone have a diagram of 1994 F150 manual wheel hub
    Are both sides apart? Don't have any diagram to give you, go to Ford and ask for the exploded parts diagram, it shows the parts in order, they will usually print the page for you no charge, it is good business. I am sorry can't be more help, call if you like 925-459-0571
    Aug 02, 2008 | 1993 Ford F150 SuperCab
    Beko TLDA662 Logo
    93 people viewed this question
    Top Beko Refrigerators Experts
    John Tripp
    John Tripp
    mike cooper
    Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
