While washing the child lock button came on. I cant use it unless I get child lock off how do I do it please
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Try unpluging it 4 15mins
Posted on Apr 13, 2015
Testimonial: "Thank you Tom for your quick reply, it has helped, how it happened I dont suppose I will ever get an answer. But you have helped to get the washing down again :-)"
  • tom cassidy
    tom cassidy Apr 13, 2015
    glad it worked 4 u god bless if i can help just ask.
Machine displyas CL. Why
It means the Child Lock feature which locks the controls is turned on. Look for the two console buttons, usually adjacent, with the lock and child symbols between them like the one shown below. Press and hold those buttons simultaneously until the CL light turns off to unlock the controls.
Mar 02, 2011 | LG WD-1045FH Front Load Washer
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Feb 09, 2011 | Washing Machines
Hi, my front loader washing machine (Bosch Logixx 8 sensitive) has child lock written on the screen and will not start the load. ive tried switching it on and off again but it does nothing. the door is...
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Dec 22, 2010 | Bosch Washing Machines
Why does my lg washing machine dissplay CL on it and i cant turn power on
Hi
CL means you have activated the child lock or it may have activated after some buttons were pressed. Try holding down the temperature and eco/rapid options together to turn off child lock. If this doesn't work then unplug the washer for 5minutes and try again. Hope this helps... Please post back if you need more information.
Dec 11, 2010 | Washing Machines
Cant get child lock off
Hello,look for a button with possibly a lock emblem beside it ..usually has to be held down 3-5 sec to unlock.
Thanks
May 23, 2010 | Siemens WM14S794GB Front Load Washer
Hotpoint WF865 Child Lock Button Stuck 'On'
you should be able to turn it off by holding it in for a while longer,5-10 seconds, unless the circuit board is at fault.
Jan 07, 2009 | Hotpoint Ultima WF865 Front Load Washer
Child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
Jul 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Samsung wf337aa front loader
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jul 13, 2008 | Samsung WF337AA Front Load Washer
Hotpoint ultima 840
hold child lock button down for 2 seconds you will then hear a beep done.
Jun 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
