Question about Invicta Watches
How do you take the back off a Invicta watch model 14862
3 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Invicta 2875 wrist watch band too large
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
  • 5 Answers
SOURCE: My invicta stainless steel band has two bent
Most watch pins go for an average of 5 to 10 dollars per pin. If the band is in good condition there is no need to replace it. Most invicta metal bands can retail from 35 dollars and up. We are located in the Holyoke Mall in Holyoke MA
Posted on Aug 11, 2009
Battery type invicta watch model 4889
  • Remove back
  • Locate battery and mounting. Note mounting details for later.
  • Identify battery
  • Obtain replacement
  • Install
  • Check operation
  • Reinstall back
  • Set time, etc.
Or,
For a few dollars, have a jeweler replace it
For a few dol
Oct 25, 2016 | Invicta Watches
I would like to know how to remove the back and change the battery.
There appear to be several models in Invicta Signature Watches.
Your best bet is youtube. one is shown below Battery Change Invicta Men 2770 Force Collection super easy
Apr 02, 2016 | Invicta Signature Watches
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
How to set?& manual required invicta.15343 pro dive
Invicta Pro Diver - View model
invictawatch.com/collections/view-model/15342-pro-diver
INVICTA COLLECTIONS click to view models · AKULA ... Instruction Manual Print. More models of the same style. 15343. Invicta Pro Diver · share watch. 15341.
Sep 25, 2015 | Watches
Watch battery replacement
I believe that model's back screws in. You can get a rubber jar opener if you are having trouble gripping it. In general, the key is unscrewing it.
Elisa Jed ' http://keepingtimewatches.com/mens-chronograph-watches
Feb 15, 2014 | Invicta Watches
How do you remove the back of an invicta model 3459
here's is a video on how to open the caseback of your watch. i hope this will help you. just click the link below.
http://www.youtube.com/watch?v=bYTlqox3aA8&feature=player_detailpage
Jul 30, 2011 | Invicta Vintage Collection Chronograph...
How to reset an automatic invicta watch?
You don't say which model you have, so if you go to http://www.invictawatch.com/invicta/collections, you should be able to fin your model.
All the ones I looked at included a link to its manual.
Dec 11, 2010 | Invicta Automatic Watch
Lost manual to set atomic 4045 watch
Unfortunately no. You will need to try contacting Invicta direct. Sometimes you can go to Invicta retailers and they will have some left over or they will have instructions for similar models.
Mar 26, 2009 | Invicta Atomic Autotech 4051 Watch
Watches Logo
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
