Question about Rangemaster Toledo 90 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Can i fit a glass lid to my Rangemaster Toledo 90? It has never had one fitted and wondering if one can be fitted. Thanks
As above
    Problem Solver:
  • 12 Answers
No not if it has never had one fitted by the manufacturer as it wont have a safety device fitted to close the gas supply in the advent that the lid is closed while a burner is still a light which would shatter the safety glass and cause injury to the user. Some glass lidded cookers where imported to England when i was an apprentice gas engineer and no safety device fitted and the lids exploded and where soon made illegal.
Posted on May 08, 2015
TampaNative
  • 778 Answers
SOURCE: fan belt fitting seat toledo
After removing the cover, it should be obvious that one of the pulley's has an adjustment (could be the motor that drives the fan itself) to allow removal and refitting the belt, otherwise there will be a tensioner pulley that has to be released to remove and replace the belt.
Posted on Apr 04, 2008
FitzOriginal
  • 842 Answers
SOURCE: Timer instructions for a Rangemaster Toledo dual fuel 90 required
OK, here we go, this is actually a fairly lengthy explanation, but I will do what I can to explain.
The timer can be used to turn just one, or both ovens on and off automatically, however the start and stop time must be the same for both ovens, though different cooking temperatures can of course be set, so if you play around with temperatures to extend the cooking time of an item in one oven, you can often cook items needing very different settings for the fixed time you set in both ovens. Note that when the timer is on and the AUTO message is on the display, the ovens are disabled and will ONLY work during the timed period unless the timer is disabled again. (This is a common problem when you first power up, because the AUTO setting is automatically engaged on installation or power up after a power cut, disabling the ovens until you figure this out!). So, with all that garbage out of the way, how to use the timer settings:
For ease of understanding, I will refer to the buttons on the control pannel (Running from Left to Right as: BELL, HOT DISH, COLD DISH, HAND, + and -)
TO TIME SOMETHING THAT'S ALREADY COOKING (Minute Minder). Press and hold down the BELL symbol (Far left), use the + or - to adjust the amount of time you want to cook for (You can check time remaining at any point, or cancel the beeper when the time is up, by pressing the bell button.
TO STOP AUTOMATICALLY AFTER YOU HAVE MANUALLY STARTED COOKING. Press and hold the COLD DISH button at the same time use + and - to adjust your required stop time. AUTO will show on the display. When cooking is finished, the beeper sounds. TURN THE OVEN TEMPERATURE KNOB TO "0" FIRST, then press the HAND button, once to stop the beeper, and again to cancel auto and return to manual mode.
TO START AND STOP THE OVEN MANUALLY: Before you start, decide when you want the cooking to stop and how long you want the food to cook for (The cooker will work back from your stop time and figure out the START time for its self.). Press and hold down the HOT DISH button and at the same time set the minutes and hours you want the oven to cook for with the + and - buttons (You are NOT SETTING THE TIME HERE, you are setting how many minutes and hours to cook. Next, press and hold the COLD DISH button and use the + and - to set the stop time (YOU ARE SETTING A TIME IN THIS OPERATION). AUTO will show on the display. Set the temperature for the oven (or both ovens) that you want to auto cook with. When cooking stops the beeper sounds. Press the HAND button to cancel the beeper and press the HAND again to cancel AUTO and return to manual mode. (Note that the beeper stops after a while if you leave the oven attended, but the manual states you still have to press the HAND button twice to return to manual, I have not personally tested this).
GETTING BACK TO MANUAL MODE. If AUTO is showing on the display, because you have set automatic and no do not need it, or you have just powered the cooker up, any cooking time already set must be returned to 0:00 before you can return to manual, so hold down the HOT DISH button and ensure the display is set to 0:00, once you gave done this you can press the HAND button to return to manual mode
Posted on Jan 23, 2009
SOURCE: RANGEMASTER 110 Cooker FLAME FAILURE DEVICE fitting
My progress to date (20090127):
1 Turn off the gas supply to the oven
2 Turn off the electricity supply
3 Remove the oven linings
4 Remove the storage drawer
5 Remove the three screws holding on the bottom trim and the trim
6 Crank up the front roller
7 Pull out the oven carefully making sure the gas hose and electrical lead are long enough and not caught
8 Working from the rear of the Rangemaster, for the right-hand oven, remove the four screws on the corners of the large cover plate at the back of the oven about half way down on the left-hand side as viewed from the back.
9 Remove the cover plate.
10 Go to the front of the oven. Above the burner assembly, towards the left is a thin metal rod running front to back. This is held in place by a clip at the back and by the hole in the metal frame at the front. Remove the metal clip at the back using a pair of long-nosed pliers. Retain the clip.
11 This should release the metal rod (flame sensing device) and you should be able to push it through the hole and out at the back. It is attached to a long copper wire.
12 Go to the back of the range. You should be able to work the wire back through the hole in the rear metal plate and up to the gas valve. The wire is held in place at the gas valve by a bent clip on the rear right. Carefully bend this clip back towards the oven to release the wire.
13 The wire goes down under the gas valve and to a threded bolt end into the bottom of the gas valve ad the bolt is held in place using a locking nut.
14 Remove the locking nut using a small spanner. The threded bolt should now turn, with the aid of long-nosed pliers.
15 The next trick is to remove this threaded bolt on the end of the copper wire and I have not figured out how to do that. It will unscrew a good way but becomes tight and will not come out, as though something inside the valve is holding it in place. Could it be that the flame sensing device has to be removed and inserted from inside the gas valve? If so, what a daft piece of engineering this is.
16 HELP.
Posted on Jan 27, 2009
FitzOriginal
  • 842 Answers
SOURCE: Rangemaster toledo DF 90 what is the minimum door width through which these cookers can be fitted?
Yes, the handle, doors and knobs can all be removed, in fact (If I remember correctly) the unit is delivered with at least the handle/rail at the top not fitted. I would still suggest that you visit the supplier with a tape measure and suggest that if they want sell you a unit, they reassure you by showing you a packaged unit, or demonstrate the removal of the handle.
Posted on Feb 15, 2009
  • 136 Answers
SOURCE: Rangemaster Toledo 30 - The glass in the oven door
junk it and get a new one !!!!
Posted on Oct 25, 2009
Height above sea level of my house in Southampton
3 metres
Geographic coordinates of Southampton, United Kingdom. Latitude ...
dateandtime.info/citycoordinates.php?id=2637487
Latitude of Southampton, longitude of Southampton, elevation above sea level of Southampton. ... Coordinates of Southampton in degrees and decimal minutes. Missing: my ‎house
Southampton - Wikipedia
https://en.wikipedia.org/wiki/Southampton Southampton is the largest city in the ceremonial county of Hampshire, England. It is 75 miles .... The city walls include God's House Tower, built in 1417, the first ..... [hide]Climate data for Southampton, elevation 3 metres (9.8 feet), 1981-2010 ... The centre of Southampton is located above a large hot water aquifer that ...
Frequently asked questions about Southampton in Queensland - Bonzle
www.bonzle.com > home > homesteads > Southampton
myBonzle menu: Add to my places Add picture Add story Add note. Skip to map ... What is the elevation/altitude/height above sea level of Southampton? Southampton is at an ... Old Parliament House, East Parliament House Picture relating to ...
An Oceanfront Home Built Above Sea Level ' Southampton, House ...
https://www.pinterest.com/pin/172122016986387096/
Southampton · House · House beautiful ... Balconies · An Oceanfront, Southampton Home Built 17 Feet Above Sea Level ...
Height above sea level of my house in Southampton Google Search
Oct 16, 2017 | Computers & Internet
Tip
Perform Nozzle Check Pattern of Canon Inkjet Printer without Computer
Models:
BJC3000 and above,S300 and above, i450 and above,Pixma ip2000 and above
Procedure:
  • Set A4 paper in paper tray.
  • In stand by condition,hold down Resume/Cancel button until LED indicator blinks twice then release the button.
Models:
Pixma ip1200,1300 ,1600,1700,1800,1900,2200
Procedure:
  • Power on the printer, immediately after printer standing by press Resume/Cancel button 5 times within 2 seconds.
The printer start printing nozzle check pattern after procedures above performed properly.
on Dec 02, 2008 | Canon S400 InkJet Printer
Question mark key and slash plus 2 keys above it have turned to eee with accent above
https://support.microsoft.com/en-ca/kb/258824 - I suggest you check out this article - or you can google yourself - How do I change my Keyboard Mapping? and then see what comes up.
I would appear that you have somehow setup something on those keys - e with an accent above is most likely French
May 28, 2016 | Logitech Computers & Internet
Why is water leaking into cool (deli) drawer?
Hi,have you got a drain at the back of the fridge just above the veg draw,if yes is there eney food above that that is tuching the back wall of the fridge above the veg tray,if so then the water that runs down the back wall will be going onto the food that it tuches and into the veg draw,hope this was some help,all the best.
Sep 16, 2015 | Refrigerators
I just bought a 46 inch SAMSUNG LED HD TV from Best Buy and will be mounting it on a brick wall above the fireplace. The fireplace has gas logs with a an 8 inch mantle that extends 8 inches off the...
it is not safe to mount the TV 8 inches above the mantle.
Secondly, the heat will certainly be a danger if the TV is mounted above the mantle.
I would advice you look for another position to mount the TV.
I hope the above is clear.
Regards.
Sep 27, 2011 | Televison & Video
What is the fluid capacity for a 1986 monte carlo ss
Engine Coolant - Volume: 12.00QTS. ( 11.4L ) - [50/50 mixture of Ethylene Glycol Base Antifreeze and water] - 4.3L Eng - [GM Specification 1825-M.]
Engine Coolant - Volume: 16.30QTS. ( 15.4L ) - [50/50 mixture of Ethylene Glycol Base Antifreeze and water] - 5.0L Eng - [GM Specification 1825-M.]
Engine Oil - Volume: 4.00QTS. ( 3.8L ) - [SAE 5W-30 (Preferred) (Below -20Deg.F to Above 100Deg.F), 10W-30 (0Deg.F to Above 100Deg.F), 30 (40Deg.F to Above 100Deg.F)] - 4.3L Eng
Engine Oil - Volume: 4.00QTS. ( 3.8L ) - [SAE 5W-30 (Preferred) (Below -20Deg.F to Above 100Deg.F), 10W-30 (0Deg.F to Above 100Deg.F), 30 (40Deg.F to Above 100Deg.F)] - 5.0L Eng
Fuel Tank - Volume: 17.60GALS. ( 66.6L ) - 4.3L Eng
Fuel Tank - Volume: 18.10GALS. ( 68.5L ) - 5.0L Eng
Feb 07, 2011 | 1986 Chevrolet Monte Carlo
How to calculate above ground volume. 60' x 30' x 7' house with sloped side yard. house is 1' above ground in front and slopes to 7' above ground in the back. For sizing heating and air conditioning...
Total volume of home is 12,600.
total volume below grade is (6' x 60' x 30')/2 = 5400.
total - below grade volume = above grade volume
7200 cubic feet.
Feb 22, 2010 | Carrier Heating & Cooling
Media show 4 will not start. It says i dont have the right vga hardware or driver to run media show
Well..
I checked the system requirements for this software to run in youir PC.
Do you have any of the following requirement
VGA
  • Minimum Intel 945 GM and above
  • Minimum Nvidia Geforce 6600 and above
  • Minimum ATI X1600 and above
  • 64MB-VRAM and above
  • Some animation effects may be turned off or degraded for lower-end graphics system
Jan 22, 2010 | CyberLink MediaShow 4 for PC
Wifi
Acer Extensa 2000/2500 Series --- Far right launch button above the keyboard
Acer Travelmate C Series ---Far left hot key and then choose WLAN from menu that appears
Acer Aspire 1000 Series --Launch Keys above the keyboard
Acer Aspire 1640Z ---- Launch Keys above the keyboard
Acer Aspire 1690 ---- Launch Keys above the keyboard
Acer Aspire 2000 Series ---- Button on the front of the laptop
Acer Aspire 2012 ---- Launch Keys above the keyboard
Acer Ferrari 3000 ---- Button on the front of the laptop
Acer Ferrari 3020 ---- Button on the front of the laptop
Acer Ferrari 3400 ---- Button on the front of the laptop
Acer Ferrari 4000 ---- Button on the front of the laptop
Dec 30, 2008 | Acer Aspire 5003WLMi Notebook
Htc p3450 touch gprs and mms settings
you need to get the settings from your service provider (people who supply your sim) and enter the settings into the connection settings screen on the phone
May 23, 2008 | HTC Touch P3450 Smartphone
Rangemaster Toledo 90 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
107 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
