Question about Sanyo Televison & Video
How do i fix a sanyo dp46819-00 with no power
I push the powerbutton but it will not power on
How do i power this tv on
normally you push the powerbutton on either the tv. or the remote.
Oct 30, 2016 | Televison & Video
Powerbutton issue
The button has a broken hinge. Probably a new case is required but careful application of plastic cement may fix it.
Mar 08, 2016 | HP ProBook 4530s Notebook
I have a LC-42D62U TV. The powerbutton is on but there isn't anything on the screen no matter what buttons I push. The power button blinks 3 times & the opc button once when I turn it off.
The backlight probably went out. It's usualy one of the cheaper parts to fix because its easy to get to. If you are somewhat mechanically inclined you can probably do it yourself. Do you hear the audio? If so then its almost certainly a backlight. Good luck and if you need more help let me know.
Aug 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I powered off my Sanyo NVM4030 yesterday but I can't power on it today. I wonder what's the matter with it.
Push the reset button for more than 15 second and try.
Mine had the same problem I solved it this way.
May 23, 2010 | Sanyo EasyStreet NVM4070 GPS Receiver
It's frozen, won't allow me to click on anything (...
push and hold the powerbutton. or worst comes to worst pull the battery and pull the power cable
May 20, 2010 | Computers & Internet
My Acer RC500 don't start up anymore.
Check the motherboard for obvious bulging capacitors. If you don't see any you still might have bad caps. Additionally you may have a faulty power supply.
Mar 27, 2009 | Acer Aspire RC500 PC Desktop
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Oct 11, 2008 | Dell XPS 200 PC Desktop
Stays on hello panasonic ez 27
LG told me:
Power on.
Push the powerbutton again and hold it.
After exact 5 sek. remove the plug from the 220V-wallplug.
Stop pushing the power-switch.
Wait 15 min and see...
In my case it didn´t work, so, LG told me, the Software will be demaged.
Apr 10, 2008 | Televison & Video
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
