Question about Element ELCHW402 40 in. LCD HDTV
Element 40 led will not accept any remote control codes supplied by element technical support also Comcast technical was at my residence for 1hr tried 5 different remotes nothing works?
  •  Bob Buchholz
    Bob Buchholz Apr 15, 2015
    You are unclear about whether you are trying to use your original remote or the Comcast remote. Does the TV work with the original Element remote?
  • Element Master
  • 722 Answers
Hi Larry,
What did the Comcast Tech say in the end? In such cases either the remote senser inside the TV goes bad or the micro processor stops accepting the command. Unfortunately there is nothing you can do about it yourself. Ask the Comcast or someone else who can fix it.
Posted on Apr 15, 2015
Testimonial: "Comcast said it was the TV so I returned it for another one and it is the same way I paid 70.00 dollars to Comcast to tell me it was the TV Nobody can tell me if this TV has the sensors are installed in this TV 40 Model#eleWF408 so I'm going to return this also but, this time I'll refund and get a brand that does work with Comcast universal remote."
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
Jan 27, 2016 | Element Electronics Televison & Video
Can't find this on any list except for sale nobody has codes
This is the only code to check with Element brand TV; I can see. It is 0159.
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 15, 2015 | Element Televison & Video
What is the Comcast remote code
Comcast has a web page with the newest codes. If the codes listed won't work, the page tells you how to code scan.
start here:
http://customer.comcast.com/remotes/ Comcast Remote Codes Program Your Comcast Remote Control
Dec 08, 2014 | Proscan 40" Class 1080P LED HDTV -...
Looking for remote code
If you are wanting to operate a Element TV using a Phillips RC1445302 remote the Element's code should be 3264
Jul 24, 2014 | Element ELEFT405 40" LED TV 1920x1080, 60...
How can I program a directv remote to operate tv 40" led tv ?
Marion, Check the attached links,instruction and guides to program direct TV remote. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://manuals.solidsignal.com/directvrc64forweb.pdf
How to program your DirecTV universal remote to your TV with just one...
Remote Control Codes For Element TVs Codes For Universal Remotes
May 19, 2014 | Element Electronics 40 in. LED HDTV
Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Jul 21, 2009 | Sylvania LC420SS8 LCD TV
Need remote code for a element tv
I have an Element HD LCD TV and have Comcast as a cable provider. I used the code 11523 and the comcast remote now works with our TV. Yeah!
Apr 25, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Remote Control Code for Element LCD TV -- & Direct TV
We cant find our original element remote control. I just tried 10178 on the direct tv remote control and it worked YEAH!!!! We just can't do the screen size edit thing with it :(. Might still have to order a replacement element remote. This works for now. Thanks.
Oct 03, 2008 | Olevia LT32HVM 32 in. LCD Television
Element tv remote code flx-2210
For the Direct White remote it is 10178
Jan 18, 2008 | Televison & Video
Element ELCHW402 40 in. LCD HDTV Logo
130 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
