Question about Alba Televison & Video
Alba lcd22advd hdmi port not working. Ive tried loads of things but can't find the factory reset.
5 Suggested Answers
  • 1738 Answers
SOURCE: HDMI port not working.
If your getting it to work on the regular RCA Jacks then it is your dvr box problem. I would contact your cable provider.
Posted on Dec 29, 2009
  • 8 Answers
SOURCE: Remote not working anymore for my LG 42PQ20. Ive tried changing
call LG if you think the TV is not accepting the signal from the remote the TV may have a fault in it. If you have any universal remotes try programing them to control the TV if they work but the other does not it is remote.
Posted on Mar 15, 2010
bobhifi
  • 635 Answers
SOURCE: i have an LG42LH40 and
Are you aware that all the new HDMI devices have interactive technologies . For eg: if you are watching cable TV and switch on your Blue ray player connected via HDMI, you will notice the TV will automatically switch to that HDMI input with you having to pick up the Tv remote and switch manually. Some find it irritating, but you can disable that function in your system Menu. Panasonic calls it Vierra link / Sony calls it Bravia sync etc.....
Posted on Mar 08, 2011
david_hanna
  • 58 Answers
SOURCE: lcd22advd switching to AV2 selection as far as i
ok i bit confused to your problem, is it switching on it's own and is it always to AV2, or is it when you use the remote it switches over??
they should be a source button on the remote which allows to switch between connection modes. best regards
Posted on Oct 30, 2013
HDMI ports are both out. I have tried the factory reset function, but they still will not work. I am using component video now. Can I order or replace the current. Hdmi ports?
this ports usually broke down easily with a too much pressure on it
probably yours already is
due inserting in a wrong way
check your hdmi cable before servicing
Sep 15, 2015 | Televison & Video
Lcd22advd switching to AV2 selection as far as i can tell it does not have a option to switch the only options it does have is tv,dtv/usb,dvd,ext,fav,hdmi,ypbpr,pc/vga also there is no button on the...
Oct 30, 2013 | Televison & Video
My alba lcd22advd keeps flickering while on fav channel
check for a dry joints at the inverter board for the screen back light, which may have loose contact.
Aug 10, 2012 | Alba LDVD1538WDCH LCD TV
Alba model LCD22ADVD not recognising DVD's. Message
Either a dirty or a bad optical pickup unit in the player---if bad it will have to be replaced and usually cheaper to buy a new set.
May 21, 2012 | LG Televison & Video
Cant get output ps3 on hdmi cable
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
    This resets the video settings to defaults (standard video output).
    Power up the PS3 again and it should auto-detect the hdmi at this point.
    If that does not work use the original audio/video cable that came with the system, power it on, then adjust the video settings and try the hdmi cable again.
  • May 18, 2012 | Video Game Consoles & Games
    The hdmi wont work the av works I have tried all three hdmi plugs on the the tv and it says no signal could you please help everything I have is setup for hdmi
    Tries tv and those cables or satalites boxes unplug,replug it back like about an hour later for those pay boxes to reboot and upgraded it softwares.Tv to do a whole resetting itself back to the factory setting.Than go into the tv Menu.Go into Video Setting,go down and do a resetting back to factory setting.By doing this steps for every components devices that hook to the tv HDMI hubs ports on the tv Tuner signal board to reboot and resetting too.Have very good chances all the HDMI hubs ports on the tv to work again.
    Jun 26, 2011 | LG 42LC2D 42 in. LCD HDTV
    The lg 42 in tv indicates invalid format when I connect the hdmi cable but the first time I connected it was working fine I moved it to another lg tv and it works fine
    Tries tv unplug,replug tv it back like about an hour later.By letting tv resetting iself back to the factoty setting.Goto Menu goto PICTURE go down to resetting to reset the whole tv tuner signal board back to factory.That HDMI port should work again now,If not that HDMI port is shorted and dead sorry.
    Jan 05, 2011 | LG 32LC7D Television
    Lcd22advd need unlocking code
    9,7,3,5 in DVD mode then press 0. Worked for me!
    Sep 27, 2010 | Alba DVD-108 DVD Player
    When using hdmi outlet,,,the picture comes in for 1 second then screen turns all green
    That HDMI port hub it properly shorted,tries used another HMI ports hub?Tries to reset the tv back to factory setting,by unplug,replug it an hour later,go to the tv menu go to PICTURE,go down to reset.So the Tuner board reset itself back to the factory setting,all the HDMI ports hubs,should work now or that HDMI port hub is shorted,or the Tuner board it dead.
    Jun 11, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
    Televison & Video Logo
    43 people viewed this question
    Top Alba Televison & Video Experts
    Michael Galve
    Michael Galve
    Robert Crombie
    Robert Crombie
    Level 1 Expert
    Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
