The green backlite on my honeywell programmable thermostat is not on...have to use a flash lite to see screen....is there a lite bulb to change?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
In the configuration menu, there will be a 'Backlight Display Timer" setting or somthing similar. Usually they can be turned on continuous, off or on for a timed period after the display is touched. I set them all for 30 seconds, unless it is for really old people, then I set them continuous.
Posted on Apr 18, 2015
3 Suggested Answers
  • 35672 Answers
SOURCE: why will my programmable honeywell thermostat not keep changes to my schedule
Could be batteries need replacement
Posted on Apr 28, 2013
johnawashing
  • 5 Answers
SOURCE: What extent AC do I requirement to cool my chamber?
The regular is actually 3500 in order to four thousand Btu's associated with air conditioning have to make up for the quantity of temperature created with a one thousand watts lighting. Instance: ten By one thousand watts lamps will need among thirty-five, 000 as well as forty, 000 Btu's associated with air conditioning. Five By one thousand watts lamps will need among seventeen, five hundred as well as twenty, 000 Btu's associated with air conditioning. They are common recommendations because space circumstances, background air flow temps as well as air flow techniques almost all differ.
Posted on Oct 04, 2014
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
The ''Backlit Screen'' won't light. Never has. Honeywell FocusPRO 6000 5-1-1/5-2 Day Programmable Thermostat(heat pump) Any suggestions?
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 31, 2010 | Heating & Cooling
Honeywell Programmable Thermostat Display issues
there are currently 60 honeywell thermostats made i have no idea witch one you have , but a lot of the new ones run on batterys you might be seeing a low battery signal . look for a door where batterys might be and replace them
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
Our TH8000 Series Programmable Thermostat keeps flashing "change filter" even after we changed it. The guide book does not show how to re-set so the flashing stops.
try holding the filter button in for three seconds, if that doesn't reset the timer try the filter button and the temp. up button at the same time for three seconds.
Mar 30, 2008 | Honeywell Electronic Programmable...
Thermostat
That thermostat must be used with a THM5421C1008 Equipment Interface Module. The thermostat communicates with the module and the module is connected to the HVAC components.
Feb 08, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
294 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
