Question about Marantz SR6006 Home theater receiver 3D-ready HDMI AirPlay
Can't get ARC to work with my samsung ue48hu7500
Ihave my sat box and bd player connected to AV Reciever and the reciever connected to TV but when using smart Hub or apple tv ( connected to tv) i get no sound to my speakers, using source sat or bd it works fine. Using hdmi 1.4 cable between arc on reciever and TV. Just switched tv from samsung ue37d6500 and with that tv it worked even if I hade problems getting it work on that tv aswell, don' t remember how i got it to work last time since I tried everthing more then once, i am a bit frustrated now
  • Niclas Palmqvist
    Niclas Palmqvist Apr 14, 2015
    Yes as far as I understand I have tried to make sure that Anynet+ is ON on the new TV and HDMI Control is ON on the AV Reciever
  • Niclas Palmqvist
    btw thank you for taking the time and answer my question
    Genius:
  • Marantz Master
  • 1,054 Answers
Have you checked the settings on the tv? You may have to enable the ARC functions in the setup menu.
Posted on Apr 14, 2015
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
I have a Samsung HLP5063. Just bought a Onyko AV receiver with HMDI hook ups. Also connecting Dish 211VIP, and Samsung DVD connected to the receiver. I was able to get the DVD player to work, but no...
Have you gone through your onkyo receivers setup manual. You will most likely need to adjust the settings on your Onkyo receiver. I also have an onkyo reciever and I have to assign the inputs to the video source. Being that you got sound out of the front speakes. I am assuming when you were playing out of the dvd player your reciever was only on stereo sound. Once I get feedback I can assist you further
Thanks,
Lee
Sep 28, 2008 | Samsung Televison & Video
I need help hooking up my system from cable box to old toshiba 52 inch tv does not have hdmi on tv red, green , blue wires i also bought today a sony blue ray player speakers are not working ...
Please indicate the brand and model of your receiver, BD player and your speakers. Basically, you just need to connect the cable box and blue ray player to the receiver. The 5.1 speakers should be connected to the blue ray player, then another set of cables from your BD player to your TV. When you want to use the speakers while watching TV, you need to turn on the blue ray player too.
Sep 15, 2011 | Audio Players & Recorders
Denon AVR 1609 7.1 Channel Receiver turns on but i get no sound thru the optical to the tv. what could be wrong?
If you have your video equiptment hooked to your reciever input, then, out to TV, This isn't the best way to go. Of course it depends on what you have for input and output on your TV but, the ideal way to hook your system would be to hook all video equiptment to TV, ie:, cable/sat box, DVD player, etc., to TV via, HDMI, Composite, RCA, etc., then run your digital optical out from TV to reciever. You would use the TV's menu to choose what you watch and would only have one input(audio) to reciever. Some recievers are set up to transfer video, but, it uses more cables, creates more connections, and more room for error.
Jun 13, 2011 | Denon Audio Players & Recorders
I have a AVR-591. I hooked everything up and all works great. The only thing I want to know is when I turn off the receiver I have no TV. How do I bypass the receiver so I can watch TV without the reciever...
You said the magic word - BYPASS.
Your TV source is probably a cable or sat box. They usually have multiple audio and video OUTputs and most TV's have multiple audio and video INputs.
Run the box's analog RCA Audio Out to the TV (assuming it has speakers). Set the box's internal volume setting (if it has one) to FIXED and modulate theTV volume with ITS control.
HI-DEF:
Lacking sufficient hi-def inputs on the TV, I'd elect for Component Video from the box and HDMI from your BD player, if you have one. Cable video is bit-rate compromised while BD source is NOT so BD should get the best connection.
I personally have NO high-end video going into my receiver and no high-end audio going to my TV. Why bother with hops?
Jan 30, 2011 | Denon AVR991 Receiver
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
I have just purchased a home cinema system: SONY 46" LCD, KEF3005 SPKS, SONY STRDA2400ES RCVR, SONY S55O BLURAY. ALSO A VIRGIN HD+ BOX. CAN YOU ADVISE BEST WAY TO CONNECT THIS ALL TOGETHER FOR BEST...
connect all source devices to the Sony LCD tv inputs. and connect the audio output from the tv to the aux input or any one input of the audio reciever. This way you can just leave the av reciever on and control all the input switching with te tv remote. Avoid connecting all the av sources to the reciever and the tv as a monitor from the video out of the av reciever. Just use the av reciever to reproduce the desired audio and do all the input switching with the tv remote. This will simplify the operation an lessen the chance of someone changing the audio settings of the av reciever.
Aug 29, 2009 | Audio Players & Recorders
The TV loses the signal from the dish reciever. I've checked all connections. I have to turn the TV off and then back on to fix it.
since you have a dish reciever you could try connecting the dish box to the television with the AV cables.. (yellow, white and red cables) to the television. once that is done press the source button on the remote until it displays composite then you will have the picture from the sat box. Try it like this to see if it still loosing the signal..
Also you could try is turn off the sat box then back on and see if that fixes that problem if it does could be something wrong with the sat box.. also test a dvd player to see how that reacts.. if that plays good and you connect the sat box on that same connection then the sat box could be having some issues.
Jun 21, 2009 | Olevia 237T 37 in. LCD TV
Can't record from tv to dvd
I think you would have to run your sat line through the DVR-1600 first (Line In) then connect directly from the DVR to one of your TV Line-Ins (Audio R, Audio-L, S-Cable Video).
And then use the Cyberhome TV Tuner to record off your sat.
Jan 24, 2009 | Cyberhome DVR 1600 DVD Recorder
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Marantz SR6006 Home theater receiver 3D-ready HDMI AirPlay Logo
222 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
