Question about Optics
Aligns to three known stars ok but then why does it go to completely wrong area and slews in slow speed?
  • 3,961 Answers
Ha, a familiar problem with Synscan and similar. You must do these things exactly right. Set up the hand controller properly for
- time (daylight saving or not)
- location, lat and long.
- hemisphere N or S
The mount must be
-levelled (don't trust the bubble on the mount, they are rubbish)
-pointed at the celestial pole (if an EQ mount)
-pointed due S or N (if alt-az)
You will find that most of the time a 2-star alignment is sufficient. Attempting a 3-star alignment is usually only successful if you have also taught the controller about geometry errors in the mount itself (they all have such errors), which is a tedious procedure you ought to leave until later. Even a 1-star alignment may be enough for planetary and lunar obs.
Don't neglect to use the "sync to object" feature it probably has in the hand controller. To use this you slew to an object using a medium to low power EP, activate the sync feature, center the object in the EP, and press enter. This has the effect of fine tuning the pointing accuracy in that segment of the sky.
Posted on Apr 14, 2015
What is the nickname for the constellation hydra
I believe the nickname is "The Sea Serpent" . Hydra is the longest constellation in the sky and is also the largest in terms of area. It is so long that it takes more than six hours to rise completely. Along its northern side, we can observe the zodiacal signs of Cancer, Leo, Virgo and Libra.The stars in the serpent's head appear to be at the same distance but they are really very far away from each other. The northernmost of the six stars in the head of the serpent, Epsilon Hydrae, is a quintuple star - a system of five stars. Alphard (Arabic for "the solitary one") is Hydra's brightest star.
In Greek mythology, Hercules slew Hydra, a horrible serpent with many heads that grew back as soon as they were cut off. Killing the Hydra was one of Hercules' twelve labors, during which he also defeated Leo, the lion, and Draco, the dragon.
Feb 04, 2015 | Cars & Trucks
I have mercury villager 1999 ,when started in morning idler ok , after run for 20 mnts engine stall in idler turn off ,end stared back up ok give gas go normal , and star again idler low like lose power...
Read the following and follow the instructions for this problem.
Here are the most common causes of idle surge, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Sep 28, 2017 | 1999 Mercury Villager
My Mr Zippy moves throughout the pool, but constantly gets "stuck" against the wall.
With these pool cleaners, I would first check your Star Control settings. It could definitely be a problem with your flow. Blue or black means insufficient flow (increase flow by turning clockwise until the black indicator line aligns with the yellow area on the indicator gauge). Yellow is optimal and orange is slightly high but may be ok for larger pools. If you are getting red, your flow is too high and is driving the cleaner into the wall area. Turn the star control counter-clockwise until the black indicator line aligns with the yellow area on the indicator gauge.In addition to flow, check for hose memory and to make sure that the hose floats are evenly spaced. Assure that the nozzle assembly swivels freely.
Apr 25, 2011 | Zodiac Baracuda Zippy Pool Cleaner
CG5 is brand new-not 30days old yet. Mount slews before a star is selected for alignment and continues to slew about the RA until power is cut. What is wrong. Tried 2 different power sources and factory...
You should return the scope under warranty-- however a bad power supply-- and or a bad hand controller cable can cause these symptoms called a "runaway slew".
Get a separate 12 volt power supply and the proper cigarette lighter style power plug.
Feb 12, 2011 | Celestron CG-5 Mount Telescope
When I slew to an object sometimes the mount continues to move back and forth, very slightly. Ant ideas on the problem and fix?
This is normal. Do a two or three star alignment and or use the Celestron All Star polar alignment feature.
Dec 12, 2010 | Celestron CG-5 Mount Telescope
Meade LX200GPS The scope does not complete the 'Auto Alignment'
Once the scope has taken a GPS fix and knows TIME, and SITE, and you do a two star alignment your alignment stars overide any automatic alignment issues.
You could turn off the GPS put in Time, Date, and Site, do a two star alignment and everything would be fine. Centering the alignment stars is the "trick". Apparently the scope also finds NORTH OK, or the alignment stars would be way off. Since you pre-level the tripod already the software can FAIL on "tilt" and you still get good gotos.
I would not worry about it, especially since your gotos seem perfectly fine.
May 28, 2010 | Meade LX200GPS Telescope
Aligning my scope and slewing problems
You need to synchronize the telescope with stellarium. Center the telescope on a known star, then select the same star on the laptiop and 'synch' with it.
Apr 14, 2010 | Celestron NexStar 102 SLT 102 mm (4.0)...
I've made every possible alignment on my 10 inch Meade LX200GPS telescope, training,set-up, calibration, etc...but when I slew to a star....it is ALWAYS very far off in Dec....though RA seems to be well...
You might want to join the following Yahoo group:
http://tech.groups.yahoo.com/group/LX200GPS/
I am not familiar with the LX200, but there are probably folks on the Yahoo group that can help.  The only thing I can think of is if you are using a wedge and the wedge isn't at the correct angle (should match your lattitude).  Or you are not using a wedge and the Meade controller thinks that you are.  But one would think the calibration would solve that.
Apr 26, 2009 | Meade LX200GPS Telescope
GoTo Problem
Be sure that the telescope is configured for EQ SOUTH mode to tell it is in the southern hemisphere. Once a star alignment is completed NEVER manually move the telescope. Use only the control panel to slew. Everytime the telescope is move by hand, the motors do not know it has been done, and assume it is still pointing at the old direction. Check the manual for setup.
Here: http://www.celestron.com/c3/images/files/downloads/NexStar_SLT_manual.pdf
Apr 06, 2008 | Celestron NexStar 130 SLT (306 x 130mm)...
Optics Logo
283 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
